3568android以太网与wifi共存
2023-12-29 13:35| 发布者: 安道尔| 查看: 789| 评论: 0
类目: RK3568系列产品  >  Android     文档编号: 1255
文件位置:
/OK3568-android11-source/frameworks/libs/net/common/src_servicescommon/android/net/NetworkFactory.java
在229行位置找到如下代码,注释掉下方两行标红语句
    protected void handleRemoveRequest(NetworkRequest request) {
        NetworkRequestInfo n = mNetworkRequests.get(request);
        if (n != null) {
           // mNetworkRequests.remove(request);
           // if (n.requested) releaseNetworkFor(n.request);
在292行位置找到如下两个函数,对标红部分语句,进行修改为下方状态,不再根据网络评分来加载和释放网络资源
    private boolean shouldNeedNetworkFor(NetworkRequestInfo n) {
        // If this request is already tracked, it doesn't qualify for need
        return !n.requested
            // If the score of this request is higher or equal to that of this factory and some
            // other factory is responsible for it, then this factory should not track the request
            // because it has no hope of satisfying it.
//            && (n.score < mScore || n.providerId == mProvider.getProviderId())
            // If this factory can't satisfy the capability needs of this request, then it
            // should not be tracked.
            && n.request.canBeSatisfiedBy(mCapabilityFilter)
            // Finally if the concrete implementation of the factory rejects the request, then
            // don't track it.
            && acceptRequest(n.request, n.score);
    private boolean shouldReleaseNetworkFor(NetworkRequestInfo n) {
        // Don't release a request that's not tracked.
        return n.requested
            // The request should be released if it can't be satisfied by this factory. That
            // means either of the following conditions are met :
            // - Its score is too high to be satisfied by this factory and it's not already
            //   assigned to the factory
            // - This factory can't satisfy the capability needs of the request
            // - The concrete implementation of the factory rejects the request
//            && ((n.score > mScore && n.providerId != mProvider.getProviderId())
                   && ( !n.request.canBeSatisfiedBy(mCapabilityFilter)
                    || !acceptRequest(n.request, n.score));
/OK3568-android11-source/frameworks/base/services/core/java/com/android/server/ConnectivityService.java
2726,注释nai.asyncChannel.disconnect();
6683,注释nai.asyncChannel.disconnect();
当前状况为两个网络都能ping通外网,但是默认优先使用以太网,需要进行以下修改,降低以太网网络评分,以优先使用wifi
以太网网络评分:
/OK3568-android11-source/frameworks/opt/net/ethernet/java/com/android/server/ethernet/EthernetNetworkFactory.java
在538行,修改网络评分,改为return 55
        private int getNetworkScore() {
            // never set the network score below 0.
            if (!mLinkUp) {
                return 0;
            int[] transportTypes = mCapabilities.getTransportTypes();
            if (transportTypes.length < 1) {
                Log.w(TAG, "Network inte**ce '" + mLinkProperties.getInte**ceName() + "' has no "
                        + "transport type associated with it. Score set to zero");
                return 0;
            TransportInfo transportInfo = sTransports.get(transportTypes[0], /* if dne */ null);
            if (transportInfo != null) {
                return 55;
            return 0;
