T507+Android10更换桌面默认壁纸
准备壁纸图片 壁纸图片为png格式,位深度24bit,命名为sbc1308_wall**.png(名称可以随意命名),保存到T507_android_SDK源码的以下三个文件夹: android/frameworks/base/core/res/res/drawable-nodpi/ android/frameworks/base/core/res/res/drawable-sw600dp-nodpi/ android/frameworks/base/core/res/res/drawable-sw720dp-nodpi/ 修改Wall**Manager.java android/frameworks/base/core/java/android/app/Wall**Manager.java diff --git a/core/java/android/app/Wall**Manager.java b/core/java/android/app/Wall**Manager.java index 325a54bf..67be96b6 100644 --- a/core/java/android/app/Wall**Manager.java +++ b/core/java/android/app/Wall**Manager.java @@ -1874,7 +1874,8 @@ public class Wall**Manager { return null; } else { whichProp = PROP_WALL**; - defaultResId = com.android.internal.R.drawable.default_wall**; + //defaultResId = com.android.internal.R.drawable.default_wall**; + defaultResId = com.android.internal.R.drawable.sbc1308_wall**; } final String path = SystemProperties.get(whichProp); if (!TextUtils.isEmpty(path)) { 按照手册重新编译烧写镜像 |
