安卓12 5G模块开机拨号成功后面断连问题(基于3588)
2024-1-22 21:12| 发布者: mafumafu| 查看: 531| 评论: 0
类目: RK3588系列产品  >  Android     文档编号: 1277
diff --git a/opt/telephony/src/java/com/android/internal/telephony/dataconnection/TelephonyNetworkFactory.java b/opt/telephony/src/java/com/android/internal/telephony/dataconnection/TelephonyNetworkFactory.java
index 279da92b6..653ae228c 100644
--- a/opt/telephony/src/java/com/android/internal/telephony/dataconnection/TelephonyNetworkFactory.java
+++ b/opt/telephony/src/java/com/android/internal/telephony/dataconnection/TelephonyNetworkFactory.java
@@ -344,10 +344,10 @@ public class TelephonyNetworkFactory extends NetworkFactory {
             // to remove network requests from both DcTrackers.
             // Note that this part will be refactored in T, where we won't even have DcTracker at
             // all.
-            releaseNetworkInternal(networkRequest, DcTracker.RELEASE_TYPE_NORMAL,
-                    AccessNetworkConstants.TRANSPORT_TYPE_WWAN);
-                    AccessNetworkConstants.TRANSPORT_TYPE_WLAN);
+//            releaseNetworkInternal(networkRequest, DcTracker.RELEASE_TYPE_NORMAL,
+//                    AccessNetworkConstants.TRANSPORT_TYPE_WWAN);
+//                    AccessNetworkConstants.TRANSPORT_TYPE_WLAN);
