8mp-USB1总线取消OTG修改为USB的host接口
| 8MP的USB1总线是接入了CC芯片,做成Type-c的形式,默认配置为otg的一个形式,需要去掉相关电路,然后在设备树中屏蔽掉这部分芯片,才能够正常识别u盘等外设 以下是设备树的修改部分: diff --git a/OK8MP-linux-kernel/arch/arm64/boot/dts/freescale/OK8MP-C.dts b/OK8MP-linux-kernel/arch/arm64/boot/dts/freescale/OK8MP-C.dts index 72fcc7f37..dfc6d74db 100644 --- a/OK8MP-linux-kernel/arch/arm64/boot/dts/freescale/OK8MP-C.dts +++ b/OK8MP-linux-kernel/arch/arm64/boot/dts/freescale/OK8MP-C.dts @@ -143,7 +143,7 @@ regulator-always-on; }; - cbtl04gp { + /*cbtl04gp { compatible = "nxp,cbtl04gp"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_typec_mux>; @@ -155,7 +155,7 @@ remote-endpoint = <&typec_con_ss>; }; }; - }; + };*/ bt_sco_codec: bt_sco_codec { #sound-dai-cells = <1>; @@ -601,7 +601,7 @@ pinctrl-0 = <&pinctrl_i2c3>; status = "okay"; - fusb302: typec-portc@22 { + /*fusb302: typec-portc@22 { compatible = "fcs,fusb302"; reg = <0x22>; pinctrl-names = "default"; @@ -639,7 +639,7 @@ }; }; }; - }; + };*/ codec: wm8960@1a { compatible = "wlf,wm8960"; @@ -1007,7 +1007,8 @@ }; &usb3_phy0 { - vbus-power-supply = <&fusb302>; + vbus-power-supply = <®_usb1_host_vbus>; //加入供电部分 + //vbus-power-supply = <&fusb302>; fsl,phy-tx-vref-tune = <6>; fsl,phy-tx-rise-tune = <0>; fsl,phy-tx-preemp-amp-tune = <3>; @@ -1022,18 +1023,8 @@ }; &usb_dwc3_0 { //去掉无用配置 - dr_mode = "otg"; - hnp-disable; - srp-disable; - adp-disable; - usb-role-switch; + dr_mode = "host"; //只配置为host status = "okay"; - - port { - usb3_drd_sw: endpoint { - remote-endpoint = <&typec_dr_sw>; - }; - }; }; &usb3_phy1 { |
上一篇:sdio降速后WiFi带宽数据下一篇:linux 内核修改打印信息等级
