6254使用按键gpio
| 1.引脚配置 mcu_gpio_key_pin_default: mcu-gpio-key-pin-default { pinctrl-single,pins = < AM62X_MCU_IOPAD(0x040, PIN_INPUT, 7) /* (D4) MCU_GPIO0_16 */ >; }; 2.节点配置 gpio-keys1 { compatible = "gpio-keys"; autorepeat; pinctrl-names = "default"; pinctrl-0 = <&mcu_gpio_key_pin_default>; key-mcu16 { interrupt-parent = <&mcu_gpio0>; label = "GPIO Key UP"; linux,code = <30>; gpios = <&mcu_gpio0 16 GPIO_ACTIVE_LOW>; interrupts = <16 IRQ_TYPE_EDGE_RISING>; }; }; 3.编译内核替换设备树 4.查看是否生成节点 root@OK62xx:/# cat sys/kernel/debug/gpio gpiochip0: GPIOs 0-23, parent: platform/4201000.gpio, 4201000.gpio: gpio-16 ( |GPIO Key UP ) in hi ACTIVE LOW 5evtest测试 root@OK62xx:/# evtest /dev/input/by-path/platform-gpio-keys1-event //按下是1,松开是0,长按是2 Event: time 1719645537.990880, type 1 (EV_KEY), code 30 (KEY_A), value 1 Event: time 1719645537.990880, -------------- SYN_REPORT ------------ Event: time 1719645538.172304, type 1 (EV_KEY), code 30 (KEY_A), value 0 Event: time 1719645538.172304, -------------- SYN_REPORT ------------ Event: time 1719645558.377843, type 1 (EV_KEY), code 30 (KEY_A), value 1 Event: time 1719645558.377843, -------------- SYN_REPORT ------------ Event: time 1719645558.649860, type 1 (EV_KEY), code 30 (KEY_A), value 2 Event: time 1719645558.649860, -------------- SYN_REPORT ------------ Event: time 1719645558.689855, type 1 (EV_KEY), code 30 (KEY_A), value 2 Event: time 1719645558.689855, -------------- SYN_REPORT ------------ Event: time 1719645558.729848, type 1 (EV_KEY), code 30 (KEY_A), value 2 |
上一篇:ntp服务下一篇:6254去除屏上打印信息
