OK3588 修改Ubuntu开机欢迎信息
2024-8-27 08:52| 发布者: hai| 查看: 482| 评论: 0|原作者: hai
类目: 知识库  >  RK3588系列产品     文档编号: 1492
Ubuntu20修改开机forlinx信息:
  Ubuntu 20.04 LTS ok3588 ttyFIQ0
ok3588 login: root (automatic login)
_____         _ _
| ___|__ _ __| (_)_ __ __ __
| |_ / _ \| '__| | | '_ \\ \/ /
| _| (_) | | | | | | | |> <
|_| \___/|_| |_|_|_| |_/_/\_\
Welcome to Ubuntu 20.04 LTS (GNU/Linux 5.10.66 aarch64)
* Documentation: https://help.ubuntu.com
* Management:     https://landscape.canonical.com
* Support:       https://ubuntu.com/advantage
接下来将forlinx图像修改为Ubuntu20.04
打开文件/etc/update-motd.d/00-header,修改一下内容:
TERM=linux toilet -f standard -F gay Ubuntu 20.04
查看效果:
        [   10.309571] mali fb000000.gpu: Protected memory allocator not found, Firmware protected mode entry will not be supported
_   _ _                 _           ____   ___   ___ _ _
| | | | |__ _   _ _ __ | |_ _   _ |___ \ / _ \ / _ \| || |
| | | | '_ \| | | | '_ \| __| | | |   __) | | | | | | | || |_
| |_| | |_) | |_| | | | | |_| |_| | / __/| |_| | |_| |__   _|
\___/|_.__/ \__,_|_| |_|\__|\__,_| |_____|\___(_)___/   |_|
