解决6254使用ec20,偶发性无法注册wwan0节点的问题
解决6254使用ec20,偶发性无法注册wwan0节点的问题 使用 GobiNet or QMI WWAN,需要阻止第四个接口注册为串口。 kernel/drivers/usb/serial/option.c /* * Allow matching on bNumEndpoints for devices whose inte**ce numbers * can change (e.g. Quectel EP06). */ if (device_flags & NUMEP2 && iface_desc->bNumEndpoints != 2) return -ENODEV; #if 1 //Added by Sky //Quectel UC20's inte**ce 4 can be used as USB Network device if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9003) \ && serial->inte**ce->cur_altsetting->desc.bInte**ceNumber >= 4) return -ENODEV; //Quectel EC20's inte**ce 4 can be used as USB Network device if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9215) \ && serial->inte**ce->cur_altsetting->desc.bInte**ceNumber >= 4) return -ENODEV; //Quectel EC21&EC25&EC20 R2.0's inte**ce 4 can be used as USB Network device if (serial->dev->descriptor.idVendor == cpu_to_le16(0x2C7C) \ && serial->inte**ce->cur_altsetting->desc.bInte**ceNumber >= 4) return -ENODEV; #endif /* Store the device flags so we can use them during attach. */ usb_set_serial_data(serial, (void *)device_flags); |
