MX6UL_C OTG烧写问题
2018-3-19 10:09| 发布者: Forever| 查看: 1093| 评论: 0
类目:  >  知识库     文档编号: 173
    有客户反应MX6UL自制底板使用OTG烧写失败,打印信息卡到cpu_id is 0。造成这种情况的原因是USB_OTG1_ID引脚电平被拉低,设备不能作为从设备,接收不到windows的命令。
    客户在自己做底板的时候需要注意:
1、USB_OTG1_ID引脚在硬件原理设计上不被下拉(如果客户只想作为主设备使用,不用OTG烧写可忽略此项);
2、硬件上修改USB_OTG1_ID引脚后要相应的修改驱动;
3、排除在焊接上将USB_OTG1_ID拉低。
    打印信息如下:
U-Boot 2015.04-g5d63276bfe-dirty (Jan 10 2017 - 15:40:43)
CPU:   Freescale i.MX6UL rev1.1 at 396 MHz
CPU:   Temperature 45 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C:   ready
DRAM:  256 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
Card did not respond to voltage select!
MMC init failed
Using default environment
clk: Not disabling unused clocks
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 360K (808c1000 - 8091b000)
Starting UTP
uuc 0.5 [built Aug 18 2015 20:29:48]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
random: nonblocking pool is initialized
