android5.1修改默认开机显示方向
| Android5.1的显示方向默认为0度,可以更改为90、180、270来修改其显示的方向,下面是更改为顺势针旋转90度的方法: diff --git a/frameworks/base/cmds/bootanimation/BootAnimation.cpp b/frameworks/base/cmds/bootanimation/BootAnimation.cpp index b2474f2..8c133c7 100644 --- a/frameworks/base/cmds/bootanimation/BootAnimation.cpp +++ b/frameworks/base/cmds/bootanimation/BootAnimation.cpp @@ -239,7 +239,7 @@ status_t BootAnimation::readyToRun() { // create the native su**ce sp<Su**ceControl> control = session()->createSu**ce(String8("BootAnimation"), - dinfo.w, dinfo.h, PIXEL_FORMAT_RGB_565); + dinfo.h, dinfo.w, PIXEL_FORMAT_RGB_565); Su**ceComposerClient::openGlobalTransaction(); control->setLayer(0x40000000); diff --git a/frameworks/base/core/res/res/values/config.xml b/frameworks/base/core/res/res/values/config.xml index e23ca9a..eedf7ee 100755 --- a/frameworks/base/core/res/res/values/config.xml +++ b/frameworks/base/core/res/res/values/config.xml @@ -558,7 +558,7 @@ <!-- The number of degrees to rotate the display when the keyboard is open. A value of -1 means no change in orientation by default. --> - <integer name="config_lidOpenRotation">-1</integer> + <integer name="config_lidOpenRotation">90</integer> <!-- Indicate whether the lid state impacts the accessibility of the physical keyboard. 0 means it doesn't, 1 means it is accessible diff --git a/frameworks/base/services/core/java/com/android/server/wm/WindowManagerService.java b/frameworks/base/services/core/java/com/android/server/wm/WindowManagerService.java index 089d897..a928d64 100644 --- a/frameworks/base/services/core/java/com/android/server/wm/WindowManagerService.java +++ b/frameworks/base/services/core/java/com/android/server/wm/WindowManagerService.java @@ -478,7 +478,7 @@ public class WindowManagerService extends IWindowManager.Stub /** All DisplayContents in the world, kept here */ SparseArray<DisplayContent> mDisplayContents = new SparseArray<DisplayContent>(2); - int mRotation = 0; + int mRotation = 1; int mForcedAppOrientation = ActivityInfo.SCREEN_ORIENTATION_UNSPECIFIED; boolean mAltOrientation = false; diff --git a/frameworks/native/services/su**ceflinger/DisplayDevice.cpp b/frameworks/native/services/su**ceflinger/DisplayDevice.cpp index 6ac1af0..f966a29 100644 --- a/frameworks/native/services/su**ceflinger/DisplayDevice.cpp +++ b/frameworks/native/services/su**ceflinger/DisplayDevice.cpp @@ -130,7 +130,7 @@ DisplayDevice::DisplayDevice( } // initialize the display orientation transform. - setProjection(DisplayState::eOrientationDefault, mViewport, mFrame); + setProjection(DisplayState::eOrientation90, mViewport, mFrame); } DisplayDevice::~DisplayDevice() { @@ -434,12 +434,13 @@ void DisplayDevice::setProjection(int orientation, const int h = mDisplayHeight; Transform R; + orientation = DisplayState::eOrientation90; DisplayDevice::orientationToTransfrom(orientation, w, h, &R); if (!frame.isValid()) { // the destination frame can be invalid if it has never been set, // in that case we assume the whole display frame. - frame = Rect(w, h); + frame = Rect(h, w); } if (viewport.isEmpty()) { diff --git a/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp b/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp index 04d7850..e672169 100644 --- a/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp +++ b/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp @@ -2331,7 +2331,7 @@ void Su**ceFlinger::onInitializeDisplays() { DisplayState::eLayerStackChanged; d.token = mBuiltinDisplays[DisplayDevice::DISPLAY_PRIMARY]; d.layerStack = 0; - d.orientation = DisplayState::eOrientationDefault; + d.orientation = DisplayState::eOrientation90; d.frame.makeInvalid(); d.viewport.makeInvalid(); d.width = 0; |
