imx6 Linux4.1.15版本自动登录root用户方法
2021-11-29 09:45| 发布者: whl| 查看: 1276| 评论: 0
类目: 知识库  >  I.MX6系列产品     文档编号: 571
修改/etc/init.d/rmnologin.sh文件
在:exit 0上边添加一行/bin/login -f root 效果如下:
#!/bin/sh
### BEGIN INIT INFO
# Provides:          rmnologin
# Required-Start:    $remote_fs $all
# Required-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:
# Short-Description: Remove /etc/nologin at boot
# Description:       This script removes the /etc/nologin file as the
#                    last step in the boot process, if DELAYLOGIN=yes.
#                    If DELAYLOGIN=no, /etc/nologin was not created by
#                    bootmisc earlier in the boot process.
### END INIT INFO
if test -f /etc/nologin.boot
then
rm -f /etc/nologin /etc/nologin.boot
fi
/bin/login -f root
: exit 0
