android-3399-android固定USB串口设备端口号
2022-7-17 20:05| 发布者: PaperLove| 查看: 1038| 评论: 0|来自: 百度文库
类目: RK3399产品系列  >  Android     文档编号: 684
使能客户所需串口驱动(例如ch340)
修改/kernel/arch/arm64/configs/rockchip_defconfig文件,添加CONFIG_USB_SERIAL_CH341=y将ch340驱动编译进内核
android固定USB串口设备端口号
采用打补丁的方式修改/kernel/drivers/usb/serial/usb-serial.c文件。
参考链接:https://wenku.baidu.com/view/c6a00d1240323968011ca300a6c30c225901f02b.html
通过USB设备名去识别USB转串口插入的哪个U口,再根据不同的U口分配一个不同的节点。
static int allocate_minors(struct usb_serial *serial, int num_ports)
struct usb_serial_port *port;
unsigned int i, j;
int minor;
dev_dbg(&serial->inte**ce->dev, "%s %d\n", __func__, num_ports);
mutex_lock(&table_lock);
for (i = 0; i < num_ports; ++i) {
port = serial->port[i];
minor = idr_alloc(&serial_minors, port, 0, 0, GFP_KERNEL);
//固定USB转串口设备名
if(!strcmp(dev_name,"5-1"))
minor=1;
else if(!strcmp(dev_name,"7-1.1"))
minor=2;
else if(!strcmp(dev_name,"7-1.2"))
minor=3;
if (minor < 0)
goto error;
port->minor = minor;
port->port_number = i;
serial->minors_reserved = 1;
mutex_unlock(&table_lock);
return 0;
error:
/* unwind the already allocated minors */
for (j = 0; j < i; ++j)
idr_remove(&serial_minors, serial->port[j]->minor);
return minor;
static int usb_serial_probe(struct usb_inte**ce *inte**ce,
       const struct usb_device_id *id)
...内容省略...
if (allocate_minors(serial, num_ports)) {
替换为
if (allocate_minors(serial, num_ports,dev_name(&port->serial->dev->dev))) {
dev_err(ddev, "No more free serial minor numbers\n");
goto probe_error;
...内容省略...
配置环境变量
source build/envsetup.sh
lunch rk3399_all-userdebug
单独编译内核文件。
./mklinux.sh
打包镜像烧写文件。
./mkimage.sh
将/kernel/rockdev/Image-rk3399_all/boot.img分区烧写到开发板。
