KSZ8081 变更
2017-1-25 10:51| 发布者: 飞凌-peacelove| 查看: 1218| 评论: 0
类目:  >  知识库     文档编号: 87
目前客户自己做底板,如若遇到百兆网口不通的,可以参照一下一下文件:
需要在现有的驱动打补丁:
具体链接如下:
https://community.nxp.com/docs/DOC-333163
Overview
In latest i.MX6UL/i.MX6ULL EVK boards, Ethernet PHY chip is upgraded with new revsion ID (01) although the same part number KSZ8081RNBIA is used. The detailed change is as follows:
Mark on old Ethernet PHY chip (Silicon Revision ID is 0, Mark is A2):
            KSZ8081
            RNBIA
            1439A2T
            M147J18M02
Mark on new Ethernet PHY chip (Silicon Revision ID is 1, Mark is A3)
              KSZ8081
              RNBIA
              1602SA3T
               M159S28M23
发表评论
