文档编号:911 移植的是2518 SPI转CAN FD芯片,本文移植的是2515 SPI转CAN芯片,只满足普通CAN功能,不支持CAN FD。 说明:OKMX8MP开发板内核源码中已经包含了2515的驱动,直接修改设备树及驱动配置即可。 驱动路径:OK8MP-linux-sdk/OK8MP-linux-kernel/drivers/net/can/spi/mcp251x.c 1.1.1添加驱动配置forlinx@ubuntu:~/OK8MP-linux-sdk/OK8MP-linux-kernel/$ vi arch/arm64/configs/OK8MP-C_\ defconfig |
在任意位置添加: 1.1.2修改设备树forlinx@ubuntu:~/OK8MP-linux-sdk/OK8MP-linux-kernel/$ vi arch/arm64/boot/dts/freescale/\ OK8MP-C.dts |
1. 添加时钟节点: [……] / { model = "Forlinx OK8MPlus-C board"; compatible = "forlinx,ok8mp-c", "fsl,imx8mp-evk", "fsl,imx8mp"; clocks { //添加时钟节点 mcp251x_clock: mcp251x_clock{ compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <8000000>; //对应模块上晶振的频率 }; }; reserved-memory { #address-cells = <2>; [……] |
2. 在ecspi2节点下屏蔽之前的子节点spidev1,添加2515的子节点: [……] &ecspi2 { #address-cells = <1>; #size-cells = <0>; fsl,spi-num-chipselects = <1>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_ecspi2_cs>; cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>; status = "okay"; /* spidev1: spi@0 { reg = <0>; compatible = "rohm,dh2228fv"; spi-max-frequency = <500000>; }; */ can0: mcp2515@0 { compatible = "microchip,mcp2515"; reg = <0>; //地址从0开始 spi-max-frequency = <10000000>; //spi最大频率设置,此处为1MHz clocks = <&mcp251x_clock>; //使用刚刚写的时钟 interrupt-parent = <&gpio4>; //中断引脚配置,中断引脚是GPIO4_IO21 interrupts = <21 0x2>; //中断引脚配置,参数0x2代表触发方式 }; }; [……] |
3. 添加中断引脚配置: [……] pinctrl_ecspi2: ecspi2grp { fsl,pins = < MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x82 MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x82 MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x82 MX8MP_IOMUXC_SAI2_RXFS__GPIO4_IO21 0x40000 >; }; [……] |
4. 编译源码并烧写。 1.1.3开机验证1. 在开发板上SPI2接口处接上2515转接板,启动开发板。 2. 查看驱动是否成功挂载: root@OK8MP:~# lsmod Module Size Used by can_raw 20480
