linux下通过串口给stm32烧录程序的方法
2023-12-31 20:52| 发布者: Espoir| 查看: 511| 评论: 0
类目:  >  知识库     文档编号: 1267
linux下给stm32烧录程序,以imx6ull为例:
1.移植stm32flash
下载地址:stm32flash download | SourceForge.net
$ tar -zxvf stm32flash-0.5.tar.gz
$ cd stm32flash/
$ . /opt/fsl-imx-x11/4.1.15-2.0.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabi
$ make
$ make install DESTDIR=./__install
$ file usr/local/bin/stm32flash
usr/local/bin/stm32flash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, BuildID[sha1]=965f73cdeed7052db22429903bb49d32487a4356, not stripped
将usr/local/bin/stm32flash 拷贝到开发板
2.使用方法
使用方法:
$ ./stm32flash
stm32flash 0.5
http://stm32flash.sourceforge.net/
ERROR: Device not specified
Usage: ./stm32flash [-bvngfhc] [-[rw] filename] [tty_device | i2c_device]
-a bus_address Bus address (e.g. for I2C port)
-b rate Baud rate (default 57600)
-m mode Serial port mode (default 8e1)
-r filename Read flash to file (or - stdout)
-w filename Write flash from file (or - stdout)
-C Compute CRC of flash content
-u Disable the flash write-protection
-j Enable the flash read-protection
-k Disable the flash read-protection
-o Erase only
-e n Only erase n pages before writing the flash
-v Verify writes
-n count Retry failed writes up to count times (default 10)
-g address Start execution at specified address (0 = flash start)
-S address[:length] Specify start address and optionally length for
                  read/write/erase operations
-F RX_length[:TX_length] Specify the max length of RX and TX frame
-s start_page Flash at specified page (0 = flash start)
-f Force binary parser
-h Show this help
-c Resume the connection (don't send initial INIT)
*Baud rate must be kept the same as the first init*
This is useful if the reset fails
-i GPIO_string GPIO sequence to enter/exit bootloader mode
GPIO_string=[entry_seq][:[exit_seq]]
sequence=[-]n[,sequence]
-R Reset device at exit.
Examples:
Get device information:
./stm32flash /dev/ttyS0
or:
./stm32flash /dev/i2c-0
Write with verify and then start execution:
./stm32flash -w filename -v -g 0x0 /dev/ttyS0
Read flash to file:
./stm32flash -r filename /dev/ttyS0
Read 100 bytes of flash from 0x1000 to stdout:
./stm32flash -r - -S 0x1000:100 /dev/ttyS0
Start execution:
./stm32flash -g 0x0 /dev/ttyS0
GPIO sequence:
- entry sequence: GPIO_3=low, GPIO_2=low, GPIO_2=high
- exit sequence: GPIO_3=high, GPIO_2=low, GPIO_2=high
./stm32flash -R -i -3,-2,2:3,-2,2 /dev/ttyS0
3.烧录
使stm32进入串口烧录模式(BOOT1=0,BOOT0=1)
  • BOOT1=x,BOOT0=0:从主存储器启动,就是我们常说的64K、128K、256K、512K等等的片内的Flash存储器,正常情况下我们一般这么配置,此时BOOT1引脚可以悬空;
  • BOOT1=0,BOOT0=1:从系统存储器启动,此种启动方式会运行系统存储器内的Bootloader程序,也就是我们常说的ISP程序,这个程序是出厂内置好的,不能更改,系统存储器是一个ROM,我们使用串口下载程序就需要配置为此种启动模式;
  • BOOT1=1,BOOT0=1:从内置SRAM启动,一般用于调试,当用户需要反复下载调试程序的时候,将程序下载到Flash很慢,此时可以选择下载到SRAM种调试,回提高效率,但是单片机一旦断电,所有程序均丢失,此种启动方式还有一个常用的用途,就是用于解除芯片的读保护功能或者擦除Flash等。
sudo stm32flash -w rtthread.hex -v -g 0x00 /dev/ttyUSB0
stm32flash 0.5
Using Parser : Intel HEX
Inte**ce serial_posix: 57600 8E1
Version     : 0x31
Option 1     : 0x00
Option 2     : 0x00
Device ID   : 0x0419 (STM32F42**/43**)
- RAM       : 192KiB (12288b reserved by bootloader)
- Flash     : 2048KiB (size first sector: 1x16384)
- Option RAM : 65552b
- System RAM : 30KiB
Write to memory
Erasing memory
Wrote and verified address 0x08006800 (10.16%)
hex或bin文件都可以烧录
