IMX6Q-CV1.1底板的资料中电容屏和电阻屏的镜像如何配置编译
以下是patch文件的内容,默认配置是电容屏的,从电容屏的配置修改为电阻屏的配置,可以通过config配置进行修改: -号表示去掉的内容,+表示添加的内容 diff --git a/arch/arm/configs/imx6_defconfig b/arch/arm/configs/imx6_defconfig index 962ea1f0..8a2d84b1 100644 --- a/arch/arm/configs/imx6_defconfig +++ b/arch/arm/configs/imx6_defconfig @@ -1099,7 +1099,7 @@ CONFIG_INPUT_TOUCHSCREEN=y # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set -CONFIG_TOUCHSCREEN_FT5X06=y +# CONFIG_TOUCHSCREEN_FT5X06 is not set CONFIG_TOUCHSCREEN_GT9XX=y # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set @@ -1119,7 +1119,7 @@ CONFIG_TOUCHSCREEN_GT9XX=y # CONFIG_TOUCHSCREEN_NOVATEK is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set -# CONFIG_TOUCHSCREEN_TSC2007 is not set +CONFIG_TOUCHSCREEN_TSC2007=y # CONFIG_TOUCHSCREEN_W90X900 is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_P1003 is not set |
