A40i修改SPI频率
2024-8-28 10:49| 发布者: hzjmlb| 查看: 447| 评论: 0
类目: 知识库  >  A40i/T3系列产品     文档编号: 1497
在设备树中修改对应spi时钟输入
linux-3.10\arch\arm\boot\dts\sun8iw11p1-OKA40i_C.dts
&spi2 {
      status = "okay";
      clock-frequency = <60000000>;
      spidev_cs0:spi2_cs0@0{
                 #address-cells=<1>;
                 #size-cells=<1>;
                 compatible = "spidev";
                 spi-max-frequency = <80000000>;  // 这个数值不能大于80MHz,spi驱动会检查
                 reg               = <0>;
                 mode=<0>;
      spidev_cs1:spi2_cs1@1{
                 #address-cells=<1>;
                 #size-cells=<1>;
                 reg               = <1>;
                 mode=<0>;
linux-3.10\arch\arm\boot\dts\sun8iw11p1-pwm1.dtsi
spi2: spi@01c17000 {
        #address-cells = <1>;
        #size-cells = <0>;
        compatible = "allwinner,sun8i-spi";
        device_type = "spi2";
        reg = <0x0 0x01c17000 0x0 0x1000>;
        interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
        clocks = <&clk_pll_periph0>, <&clk_spi2>;
        clock-frequency = <60000000>;  // 修改时钟频率
        pinctrl-names = "default", "sleep";
        pinctrl-0 = <&spi2_pins_a &spi2_pins_b>;
        pinctrl-1 = <&spi2_pins_c>;
        spi2_cs_number = <2>;
        spi2_cs_bitmap = <3>;
        status = "okay";  // 改为okay
修改完毕后在系统中可以查看对应频率
# mount -t debugfs none /sys/kernel/debug
# cat /sys/kernel/debug/clk/clk_summary
   clock                        enable_cnt  prepare_cnt  rate
    pll_periph0                 3           3            600000000  # 600MHz
       spi2                     1           1            60000000   #  60MHz
       spi0                     1           1            100000000  # 100MHz
spi2被成功修改到了60MHz的输入
使用飞凌测试应用测试30MHz是否工作正常
# fltest_spi -s 30000000
spi mode: 0
bits per word: 8
max speed: 30000000 Hz (30000 KHz)
FF FF FF FF FF FF
40 00 00 00 00 95
FF FF FF FF FF FF
FF FF FF FF FF FF
FF FF FF FF FF FF
DE AD BE EF BA AD
F0 0D
