Android 12 系统横屏时,开机动画有一段时间显示不全
| android12由于系统默认方向为竖屏,平板电脑要横屏显示。系统在开机时,有时因为旋转,会出现动画只显示一部分,如下图: 修改如下: diff --git a/device/rockchip/rk3588/BoardConfig.mk b/device/rockchip/rk3588/BoardConfig.mk index b25ebb6a6e..c71120e04d 100644 --- a/device/rockchip/rk3588/BoardConfig.mk +++ b/device/rockchip/rk3588/BoardConfig.mk @@ -29,7 +29,7 @@ PRODUCT_KERNEL_CONFIG ?= OK3588-Android_defconfig PRODUCT_BOOT_DEVICE := fe2e0000.mmc PRODUCT_SDMMC_DEVICE := fe2c0000.mmc
-SF_PRIMARY_DISPLAY_ORIENTATION := 0 +SF_PRIMARY_DISPLAY_ORIENTATION := 90
# Disable emulator for "make dist" until there is a 64-bit qemu kernel BUILD_EMULATOR := false diff --git a/frameworks/native/services/su**ceflinger/DisplayDevice.cpp b/frameworks/native/services/su**ceflinger/DisplayDevice.cpp index 4445eea604..a3cc781ec5 100644 --- a/frameworks/native/services/su**ceflinger/DisplayDevice.cpp +++ b/frameworks/native/services/su**ceflinger/DisplayDevice.cpp @@ -262,13 +262,15 @@ void DisplayDevice::setProjection(ui::Rotation orientation, Rect layerStackSpace if (!orientedDisplaySpaceRect.isValid()) { // The destination frame can be invalid if it has never been set, // in that case we assume the whole display size. - orientedDisplaySpaceRect = getCompositionDisplay()->getState().displaySpace.bounds; + orientedDisplaySpaceRect = getCompositionDisplay()->getState().displaySpace.bounds; + orientedDisplaySpaceRect = Rect(orientedDisplaySpaceRect.bottom, orientedDisplaySpaceRect.right); }
if (layerStackSpaceRect.isEmpty()) { // The layerStackSpaceRect can be invalid if it has never been set, in that case // we assume the whole framebuffer size. layerStackSpaceRect = getCompositionDisplay()->getState().framebufferSpace.bounds; + layerStackSpaceRect = Rect(layerStackSpaceRect.bottom, layerStackSpaceRect.right); if (orientation == ui::ROTATION_90 || orientation == ui::ROTATION_270) { std::swap(layerStackSpaceRect.right, layerStackSpaceRect.bottom); } diff --git a/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp b/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp index 894c47fb91..5ae5a7c1bf 100755 --- a/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp +++ b/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp @@ -437,9 +437,10 @@ Su**ceFlinger::Su**ceFlinger(Factory& factory) : Su**ceFlinger(factory, SkipI internalDisplayOrientation = ui::ROTATION_270; break; } - ALOGV("Internal Display Orientation: %s", toCString(internalDisplayOrientation)); + //ALOGV("Internal Display Orientation: %s", toCString(internalDisplayOrientation));
mInternalDisplayPrimaries = sysprop::getDisplayNativePrimaries(); + ALOGV("Internal Display Orientation: %s", toCString(internalDisplayOrientation));
// debugging stuff... char value[PROPERTY_VALUE_MAX]; @@ -2786,8 +2787,14 @@ sp<DisplayDevice> Su**ceFlinger::setupNewDisplayDeviceInternal( }
display->setLayerStack(state.layerStack); - display->setProjection(state.orientation, state.layerStackSpaceRect, - state.orientedDisplaySpaceRect); + // display->setProjection(state.orientation, state.layerStackSpaceRect, + if(!mBootFinished){ + display->setProjection(ui::ROTATION_0, state.layerStackSpaceRect, + state.orientedDisplaySpaceRect); + }else{ + display->setProjection(state.orientation, state.layerStackSpaceRect, + state.orientedDisplaySpaceRect); + } display->setDisplayName(state.displayName);
return display; @@ -2958,8 +2965,15 @@ void Su**ceFlinger::processDisplayChanged(const wp<IBinder>& displayToken, if ((currentState.orientation != drawingState.orientation) || (currentState.layerStackSpaceRect != drawingState.layerStackSpaceRect) || (currentState.orientedDisplaySpaceRect != drawingState.orientedDisplaySpaceRect)) { - display->setProjection(currentState.orientation, currentState.layerStackSpaceRect, + // display->setProjection(currentState.orientation, currentState.layerStackSpaceRect, + ALOGV("%s currentState.orientation=%d", __FUNCTION__,currentState.orientation); + if(!mBootFinished){ + display->setProjection(ui::ROTATION_0, currentState.layerStackSpaceRect, + currentState.orientedDisplaySpaceRect); + }else{ + display->setProjection(currentState.orientation, currentState.layerStackSpaceRect, currentState.orientedDisplaySpaceRect); + } if (isDisplayActiveLocked(display)) { mActiveDisplayTransformHint = display->getTransformHint(); } |
