335x中python移植方法(仅供参考)
———————————————————————————————————————————— ######################################################################################## 参考网页: http://c.360webcache.com/c?m=e210a10d6f1f7d9c6adbc7a4b43876e4&q=python%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91&u=http%3A%2F%2Fblog.csdn.net%2Fdxm2025%2Farticle%2Fdetails%2F41090469 ———————————————————————————————————————————— Python 移植教程 使用的源文件需要自行从网上下载。 准备文件: Python-2.7.13.tgz sqlite-autoconf-3200100.tar.gz Python-2.7.13-xcompile.patch.tar.gz ———————————————— 步骤1、准备环境 tar xvf Python-2.7.13.tgz tar xvf sqlite-autoconf-3200100.tar.gz mkdir python2_7_13_for_x86_32 mkdir python2_7_13_for_arm mkdir INSTALL mkdir sqlite3 ———————————————— 步骤2、安装sqlite cd sqlite-autoconf-3200100 ./configure --host=arm-arago-linux-gnueabi \ --prefix=$PWD/../sqlite3 make make install ———————————————— 步骤3、安装python2_7_13_for_x86_32 cd ../python2_7_13_for_x86_32/ sed -i 's/self.extensions.remove(ext)/print(ext.name)/g' ../Python-2.7.13/setup.py ../Python-2.7.13/configure --prefix=`pwd` make make install ———————————————— 步骤4、打补丁 cd .. tar xvf Python-2.7.13-xcompile.patch.tar.gz -C Python-2.7.13 cd Python-2.7.13/ patch -p1 < Python-2.7.13-xcompile.patch ———————————————— 步骤5、配置python2_7_13_for_arm cd ../python2_7_13_for_arm/ ../Python-2.7.13/configure --prefix=`pwd` \ --host=arm-arago-linux-gnueabi \ --build=i686-linux-gnu \ --enable-ipv6 \ --enable-static \ ac_cv_file__dev_ptmx="yes" \ ac_cv_file__dev_ptc="no" \ LDFLAGS="-L$PWD/../sqlite3/lib" \ CPPFLAGS="-I$PWD/../sqlite3/include" ———————————————— 步骤6、编译python2_7_13_for_arm make HOSTPYTHON=../python2_7_13_for_x86_64/python \ HOSTPGEN=../python2_7_13_for_x86_64/Parser/pgen \ BLDSHARED="arm-arago-linux-gnueabi-gcc -shared" \ CROSS_COMPILE=arm-arago-linux-gnueabi- \ CROSS_COMPILE_TARGET=yes \ HOSTARCH=arm-arago-linux-gnueabi \ BUILDARCH=i686-linux-gnu ———————————————— 步骤7、安装python2_7_13_for_arm make install HOSTPYTHON=../python2_7_13_for_x86_64/python \ BLDSHARED="arm-arago-linux-gnueabi-gcc -shared" \ CROSS_COMPILE=arm-arago-linux-gnueabi- \ CROSS_COMPILE_TARGET=yes \ prefix=$PWD/../INSTALL ———————————————— 步骤8、移植到开发板之后的配置 export PATH=/INSTALL/bin:$PATH python python2.7-config --prefix /INSTALL python python2.7-config --includes /INSTALL/include/ python python2.7-config --libs /INSTALL/lib/ ———————————————————————————————————————————— ######################################################################################## ———————————————————————————————————————————— 为Python安装easy_install工具 ———————————————— 步骤1、下载setuptools-0.6c11-py2.7.egg wget https://pypi.python.org/packages/25/5d/cc55d39ac39383dd6e04ae80501b9af3cc455be64740ad68a4e12ec81b00/setuptools-0.6c11-py2.7.egg#md5=fe1f997bc722265116870bc7919059ea ———————————————— 步骤2、安装easy_install /bin/sh setuptools-0.6c11-py2.7.egg ———————————————————————————————————————————— ######################################################################################## ———————————————————————————————————————————— 修改openssl.so库的版本 ———————————————— 步骤1、下载openssl-OpenSSL_1_0_1b.zip,并解压缩 tar xvf openssl-OpenSSL_1_0_1b.zip ———————————————— 步骤2、 mkdir arm_install CC=arm-arago-linux-gnueabi-gcc ./Configure linux-elf no-asm --prefix=$PWD/arm_install --openssldir=$PWD --cross-compile-prefix=arm-arago-linux-gnueabi- shared make make install tar cvf arm_install.tar arm_install/ mv arm_install.tar /media/BOOT/ ———————————————— 步骤3、在开发板上进行操作 mv /media/mmcblk1p1/arm_install.tar / tar xvf arm_install.tar cp -r /arm_install/lib/* /usr/lib cp /arm_install/bin/* /usr/bin/ ———————————————— 步骤4、取消SSL全局验证并验证easy_install vi /INSTALL/bin/easy_install 增加 import ssl ssl._create_default_https_context = ssl._create_unverified_context easy_install web.py ———————————————— 步骤5、安装pip工具 easy_install pip //此时使用pip工具会报SSL 认证错误,需要安装ntp网络对时 ———————————————————————————————————————————— ######################################################################################## ———————————————————————————————————————————— 移植ntp网络对时 (335x已有不用移植) wget http://www.eecis.udel.edu/~ntp/ntp_spool/ntp4/ntp-4.2/ntp-4.2.8p10.tar.gz tar xvf ntp-4.2.8p10.tar.gz cd ntp-4.2.8p10/ mkdir arm_install CC=arm-arago-linux-gnueabi-gcc ./configure --prefix=$PWD/arm_install --host=arm-arago-linux-gnueabi --enable-static --with-yielding-select=yes make make install -------------------------------------- ./ntpdate time.buptnet.edu.cn |
