8MM自启界面应用
vi
/etc/init.d/matrix-gui-2.0 修改为如下内容 红色字体为添加内容,即启动指令,此例是启动/home/forlinx/qt/下的keypad 紫色字体需要注释掉如下 即可完成自启 #! /bin/sh matrixgui="/home/forlinx/qt/matrix_browser" GUI_OPTS="http://127.0.0.1:80/
""" PIDFILE="/var/run/matrix-gui-2.0.pid" # Important System Environment Variables for sh in /etc/profile.d/*.sh ; do [
-r "$sh" ] && . "$sh" Done 此处加几秒延时(sleep *) /home/forlinx/qt/keypad #itest -x
"$matrixgui" || exit 0 #case "$1"
in # start) #Clear out the the tmp and lock directory # cd /usr/share/matrix-gui-2.0 # rm -rf tmp/* # rm -rf lock/* # cd - # if [ -e $PIDFILE ]; then # PIDDIR=/proc/$(cat $PIDFILE) # if [ -d ${PIDDIR} -a "$(readlink -f ${PIDDIR}/exe)" =
"${matrixgui}" ]; then # echo "$DESC already started; not
starting." # else # echo "Removing stale PID file
$PIDFILE." # rm -f $PIDFILE # fi # fi # echo -n "Starting Matrix GUI application" # start-stop-daemon --start --quiet
--background -m --pidfile $PIDFILE --exec $matrixgui -- $GUI_OPTS # echo "." # ;; # stop) # echo -n "Stopping Matrix GUI
application" # start-stop-daemon --stop --quiet --pidfile
$PIDFILE # echo
"." # ;; # *) # echo "Usage:
/etc/init.d/matrix-gui-2.0 {start|stop}" # exit 1 esac exit 0 |
