104x11C4复用为GPIO
| 此方式为直接读写寄存器,举例说明,客户可根据自己的需求自行读写寄存器 diff --git a/arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb.dts b/arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb.dts index ab87507c78be..fcfd79276be9 100644 --- a/arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb.dts +++ b/arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb.dts @@ -119,7 +119,7 @@ }; &i2c3 { - status = "okay"; + status = "disabled"; }; &duart0 { diff --git a/drivers/mmc/host/sdhci-of-esdhc.c b/drivers/mmc/host/sdhci-of-esdhc.c index 06797b34b1a4..c62a4adfe255 100644 --- a/drivers/mmc/host/sdhci-of-esdhc.c +++ b/drivers/mmc/host/sdhci-of-esdhc.c @@ -844,6 +844,8 @@ static int sdhci_esdhc_probe(struct platform_device *pdev) struct sdhci_pltfm_host *pltfm_host; struct sdhci_esdhc *esdhc; int ret; + u32 value; + void __iomem *CFG_RCWPMUXCR0; np = pdev->dev.of_node; @@ -862,6 +864,15 @@ static int sdhci_esdhc_probe(struct platform_device *pdev) host->mmc_host_ops.execute_tuning = esdhc_execute_tuning; host->tuning_delay = 1; + CFG_RCWPMUXCR0=ioremap(0x157040C, 0x04); + value = ioread32be(CFG_RCWPMUXCR0); + printk("CFG_RCWPMUXCR0 is %x ----------1111\n",value); + value |= 0x11; + iowrite32be(0x11, CFG_RCWPMUXCR0); + value = ioread32be(CFG_RCWPMUXCR0); + printk("CFG_RCWPMUXCR0 is %x ----------2222\n",value); + iounmap(CFG_RCWPMUXCR0); + esdhc_init(pdev, host); sdhci_get_of_property(pdev); |
上一篇:1028GPIO复用下一篇:10xx的网口对应关系
