6254关于M核的引脚在A核使用
设备树配置 &mcu_pmx0 { mymcugpio1_pins_default: mymcugpio1-pins-default { pinctrl-single,pins = < AM62X_MCU_IOPAD(0x004, PIN_INPUT, 7) >; }; };
&mcu_gpio0 { pinctrl-names = "default"; pinctrl-0 =<&mymcugpio1_pins_default>; status = "okay"; }; 使用gpio-leds驱动的配置,在leds节点中添加如下 --- a/arch/arm64/boot/dts/ti/OK6254-C.dts +++ b/arch/arm64/boot/dts/ti/OK6254-C.dts @@ -166,7 +166,7 @@ compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&usr_led_pins_default>; - + pinctrl-1 = <&mymcugpio1_pins_default>; led-0 { label = "heartbeat"; gpios = <&main_gpio0 42 GPIO_ACTIVE_HIGH>; @@ -206,6 +206,14 @@ led-pattern = <500 500>; default-state = "on"; }; + + led-5 { + label = "led5"; + gpios = <&mcu_gpio0 1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "timer"; + led-pattern = <500 500>; + default-state = "on"; + }; }; |
