6254 GPIOCHIP号不对的问题
现象如下,gpiochip1对应的gpio0有92个引脚,但是488-402=86,只有87个引脚 root@ok6254:~# cat /sys/kernel/debug/gpio gpiochip2: GPIOs 314-401, parent: platform/601000.gpio, 601000.gpio: gpio-330 ( |led1 ) out lo gpio-331 ( |led2 ) out lo gpio-332 ( |led3 ) out lo gpio-333 ( |led4 ) out lo gpio-336 ( |fixed-regulator-rgb ) out lo
gpiochip1: GPIOs 402-488, parent: platform/600000.gpio, 600000.gpio: gpio-433 ( |net-5g-rst ) out lo ACTIVE LOW gpio-437 ( |phy_rstn ) out lo gpio-438 ( |id ) in lo gpio-440 ( |RT9186 ) out lo gpio-441 ( |fixed-regulator-lvds) out lo gpio-442 ( |phy_rstn ) out lo gpio-444 ( |heartbeat ) out lo gpio-473 ( |regulator-6 ) out lo
gpiochip0: GPIOs 489-511, parent: platform/4201000.gpio, 4201000.gpio: root@ok6254:~# 通过搜索打印信息定位代码,发现OK6254-linux-kernel/drivers/gpio/gpiolib.c中相关内容 seq_printf(s, "%s%s: GPIOs %d-%d", (char *)s->private, dev_name(&gdev->dev), gdev->base, gdev->base + gdev->ngpio - 1); 而这个ngpio是通过设备配置的,如下 main_gpio0: gpio@600000 { compatible = "ti,am64-gpio", "ti,keystone-gpio"; reg = <0x0 0x00600000 0x0 0x100>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio_intr>; interrupts = <190>, <191>, <192>, <193>, <194>, <195>; interrupt-controller; #interrupt-cells = <2>; ti,ngpio = <87>; ti,davinci-gpio-unbanked = <0>; power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 77 0>; clock-names = "gpio"; }; 所以修改方法就是把ti,ngpio = <87>;修改为ti,ngpio = <92>; 同理其他两组gpio也是不对的 |
