3399Ubuntu系统在PC虚拟机中使用apt-get修改文件系统(使用qemu在PC模拟开发板环境)
2022-3-2 08:51| 发布者: 兵兵兵兵鸭| 查看: 3655| 评论: 0
类目: RK3399产品系列  >  Ubuntu     文档编号: 605
首先在VM虚拟机中安装qemu相关环境
forlinx@ubuntu:$ sudo apt-get install qemu-user-static
将Forlinx Desktop源码目录下OK3399-desktop-release/rootfs/ubuntu.img文件扩容后挂载()
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ sudo fsck.ext3 -f IMAGE
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ sudo resize2fs IMAGE SIZE
(IMAGE为要修改的镜像名称,SIZE为块的数量、一个块的大小为4K(即当SIZE为783770时,783770*4=3135080,大概为3.2G,1250000时为5G))按需求扩容对应的容量大小,ubuntu.img镜像大小与开发板rootfs分区有关,扩容为5G没有问题,再往上扩容需要查看开发板rootfs分区大小,ubuntu.img ≤ rootfs分区大小,rootfs分区修改方法可参考我司论坛识库描述:http://bbs.witech.com.cn/portal.php?mod=view&aid=410
扩容后将ubuntu.img文件挂载到target目录下
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ sudo mount ubuntu.img target/
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ cd target
修改配置
forlinx@ubuntu:~/OK3399-desktop-release/rootfs/target$ sudo cp /usr/bin/qemu-arm-static usr/bin/
拷贝PC主机端的dns配置,因为待会安装程序时要用网络:
forlinx@ubuntu:~/OK3399-desktop-release/rootfs/target$ sudo cp -b /etc/resolv.conf  etc/resolv.conf
forlinx@ubuntu:~/OK3399-desktop-release/rootfs/target$ sudo vim etc/apt/source.list
添加
deb http://ports.ubuntu.com/ubuntu-ports/ xenial main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial main universe
创建qemu挂载脚本
forlinx@ubuntu:~/OK3399-desktop-release/rootfs/target$ cd ..
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ touch mount.sh
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ vi mount.sh
添加以下内容:
#!/bin/bash
function mnt() {
    echo "MOUNTING"
    sudo mount -t proc /proc ${2}proc
    sudo mount -t sysfs /sys ${2}sys
    sudo mount -o bind /dev ${2}dev
    sudo chroot ${2}
function umnt() {
    echo "UNMOUNTING"
    sudo umount ${2}proc
    sudo umount ${2}sys
    sudo umount ${2}dev
if [ "$1" == "-m" ] && [ -n "$2" ] ;
then
    mnt $1 $2
elif [ "$1" == "-u" ] && [ -n "$2" ];
then
    umnt $1 $2
else
    echo ""
    echo "Either 1'st, 2'nd or both parameters were missing"
    echo ""
    echo "1'st parameter can be one of these: -m(mount) OR -u(umount)"
    echo "2'nd parameter is the full path of rootfs directory(with trailing '/')"
    echo ""
    echo "For example: ch-mount -m /media/sdcard/"
    echo ""
    echo 1st parameter : ${1}
    echo 2nd parameter : ${2}
fi
保存退出
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ chmod +x mount.sh
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ sudo ./mount.sh -m target/
到此,成功将ubuntu.img挂载到qemu上,虚拟机操作用户应该变为root@ubuntu:/# ,此时执行apt等操作会保留在ubuntu.img文件中
做对应的修改即可
退出 exit
取消挂载
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ sudo ./mount.sh -u target/
forlinx@ubuntu:~/OK3399-desktop-release/rootfs$ sudo umount target/
然后运行编译脚本生成update.img即可。
刚表态过的朋友 (1 人)
