查看: 8925|回复: 6
编译通不过,新装好的平台,请求技术支持,谢谢
bluesky28 发表于 2011-11-18 16:05:15 | 显示全部楼层 |阅读模式
MSDXM_COMPONENTS=toolbar statbar bkgndbmp
DATASYNC_MODULES= dmsvc dmsdk dminfos dmscript cefobj repllog rapisrv eventrst rra_stm systemcpl udp2tcp wceload unload
NETCFV2_MODULES= dotnetv2_string_chs dotnetv2_string dotnetv2
\WINCE600\build.err
BLDDEMO: There were errors building S3C6410_DEMO
S3C6410_DEMO - 1 error(s), 0 warning(s)
========== 生成: 0 成功或最新,1 失败,0 被跳过 ==========
楼主| bluesky28 发表于 2011-11-18 16:27:30 | 显示全部楼层
D:\WINCE600\public\common\oak\lib\ARMV4I\retail\commctrl.lib D:\WINCE600\public\common\oak\lib\ARMV4I\retail\commctrl_hpc.lib D:\WINCE600\public\common\oak\lib\ARMV4I\retail\commctrlviewxp.lib
D:\WINCE600\OSDesigns\S3C6410_DEMO\S3C6410_DEMO\Wince600\SMDK6410_ARMV4I\cesysgen\sdk\lib\ARMV4I\retail\coredll.lib D:\WINCE600\OSDesigns\S3C6410_DEMO\S3C6410_DEMO\Wince600\SMDK6410_ARMV4I\cesysgen\oak\target\ARMV4I\retail\0409\commctrl.res D:\WINCE600\public\common\oak\lib\ARMV4I\retail\corelib0.lib D:\WINCE600\OSDesigns\S3C6410_DEMO\S3C6410_DEMO\Wince600\SMDK6410_ARMV4I\cesysgen\oak\lib\ARMV4I\retail\corelib1.lib
D:\WINCE600\OSDesigns\S3C6410_DEMO\S3C6410_DEMO\Wince600\SMDK6410_ARMV4I\cesysgen\sdk\lib\ARMV4I\retail\commctrl.exp
commctrl.lib(prsht.obj) : error LNK2019: unresolved external symbol CloseGestureInfoHandle referenced in function "int __cdecl PropSheetDlgProc(struct HWND__ *,unsigned int,unsigned int,long)" (?PropSheetDlgProc@@YAHPAUHWND__@@IIJ@Z)
commctrl.lib(tab.obj) : error LNK2001: unresolved external symbol CloseGestureInfoHandle
commctrl.lib(tab.obj) : error LNK2019: unresolved external symbol GetGestureInfo referenced in function Tab_WndProc
commctrl_hpc.lib(lvlogic.obj) : error LNK2019: unresolved external symbol SetWindowAutoGesture referenced in function "void __cdecl ListView_UpdateAutoGestures(struct _LV *)" (?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z)
commctrl_hpc.lib(treeview_hpc.obj) : error LNK2001: unresolved external symbol SetWindowAutoGesture
commctrl_hpc.lib(lvlogic.obj) : error LNK2019: unresolved external symbol GetWindowAutoGesture referenced in function "void __cdecl ListView_UpdateAutoGestures(struct _LV *)" (?ListView_UpdateAutoGestures@@YAXPAU_LV@@@Z)
commctrl_hpc.lib(treeview_hpc.obj) : error LNK2019: unresolved external symbol GetAnimateMessageInfo referenced in function "int __cdecl TV_PlatformPreproc(struct HWND__ *,unsigned int,unsigned int,long,struct _TREE *)" (?TV_PlatformPreproc@@YAHPAUHWND__@@IIJPAU_TREE@@@Z)
commctrl.lib(lvgesture.obj) : error LNK2001: unresolved external symbol GetAnimateMessageInfo
commctrl.lib(lvgesture.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl TouchPerf::ReleaseSession(void)" (?ReleaseSession@TouchPerf@@SAXXZ) referenced in function "public: __cdecl GestureTriggeredScrollCtrl::~GestureTriggeredScrollCtrl(void)" (??1GestureTriggeredScrollCtrl@@QAA@XZ)
commctrl.lib(lvgesture.obj) : error LNK2019: unresolved external symbol "public: static void __cdecl TouchPerf::AcquireSession(void)" (?AcquireSession@TouchPerf@@SAXXZ) referenced in function "public: __cdecl GestureTriggeredScrollCtrl::GestureTriggeredScrollCtrl(void)" (??0GestureTriggeredScrollCtrl@@QAA@XZ)
D:\WINCE600\OSDesigns\S3C6410_DEMO\S3C6410_DEMO\Wince600\SMDK6410_ARMV4I\cesysgen\oak\target\ARMV4I\retail\commctrl.dll : fatal error LNK1120: 7 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
NMAKE : fatal error U1077: 'D:\WINCE600\sdk\bin\i386\nmake.exe' : return code '0x2'
Stop.
楼主| bluesky28 发表于 2011-11-19 08:47:25 | 显示全部楼层
重装R3和R3补丁好了。
版主,原来之前也有人提问过这个问题,可是没有答案。在其它网站上看到方法了。
25
飞凌-fatfish 发表于 2011-11-22 09:55:35 | 显示全部楼层
恩,这些补丁确实要打。没有统计过这些报错究竟原因在哪。ce报错各种问题。
还是尽量按照手册来做才是最好的选择。
yiguo66 该用户已被删除
yiguo66 发表于 2012-1-15 15:50:21 | 显示全部楼层
liansuobb 该用户已被删除
liansuobb 发表于 2012-11-21 09:07:02 | 显示全部楼层
飞凌-fatfish 发表于 2012-11-21 09:48:20 | 显示全部楼层
楼上有问题可以试试在论坛里搜索以前的解决方法
或者直接发帖提问
