- 3
贡献25
飞刀2 FD
注册时间2016-5-11
在线时间0 小时
拨到NAND FLASH启动信息: 停在最后不动了
U-Boot 1.1.6 (May 13 2011 - 16:11:02) for SMDK6410
** u-boot 1.1.6 **
** Updated for TE6410 Board **
** Version 1.0 (10-01-15) **
** OEM: Forlinx Embedded **
** Web: http://www.witech.com.cn **
CPU: S3C6410 @532MHz
Board: SMDK6410
DRAM: 256 MB
Flash: 0 kB
NAND: select s3c_nand_oob_mlc_128
2048 MB
In: serial
Out: serial
Err: serial
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1-svn140 (root@monkey-MS-7678) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #237 Wed Nov 2 10:51:04 CST 2011
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
Memory: 256MB = 256MB total
Memory: 206888k/206888k available, 55256k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xf4000000 ( 568 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0033000 ( 172 kB)
.text : 0xc0033000 - 0xc06f46bc (6918 kB)
.data : 0xc06f6000 - 0xc07367c8 ( 258 kB)
.bss : 0xc07367ec - 0xc07b4088 ( 503 kB)
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
Advanced Linux Sound Architecture Driver Version 1.0.24.
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP reno registered
audit: initializing netlink socket (disabled)
type=2000 audit(0.270:1): initialized
msgmni has been set to 404
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
fb1: s3cfb frame buffer device
fb2: s3cfb frame buffer device
fb3: s3cfb frame buffer device
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System" |
