请教高手:wince6.0 build and Sysgen 后报错,是哪里的原因?
14
楼主| twc63 发表于 2012-1-4 14:00:32 | 显示全部楼层
重做 clean sysgen,还是报同样的错。
飞凌-alexlee 发表于 2012-1-4 16:57:53 | 显示全部楼层
把板子上电后,串口信息,从头到尾,全部复制上来
楼主| twc63 发表于 2012-1-4 20:00:35 | 显示全部楼层
WinCE 6.0 Steploader for SMDK6410
Launch Eboot...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Dec 30 2011 16:00:08
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Dec 31 2011
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8007F5E4
INFO: (unsigned)ASM_IsrHandler : 0x800819F8
INFO: (unsigned)pISR : 0xEA020676
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd5
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : PAGES_PER_BLOCK = 128
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 4096(0x1000)
TOC_Read
-TOC_Read
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch in 0 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
RAM image
RAM image
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x1 for part 0x21.
BP_SetDataPointer at 0x0
**[Eboot] BP_ReadData***
ReadData: Start = 0x0, Length = 0x241b000.
Log2Phys: Logical 0x200 -> Physical 0x380
Loading Kernel......
System ready!
Preparing for download...
INFO: *** Device Name 'SMDK64100' ***
INFO: Using static IP address 0000.
INFO: Using subnet mask 2525250.
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
INFO: OEMLaunch: Jumping to Physical Address 0x50157734h (Virtual Address 0x80157734h)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK   : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK   : 133000000
[OAL] PCLK   : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
+OALArgsInit()
Arguments area has some values
-OALArgsInit()
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
[FMD] --FMD_Init()
[FMD] FMD_OEMIoControl() : IOCTL_FMD_GET_INTERFACE
[FMD:ERR] FMD_OEMIoControl() : Unknown IOCTL (0x00071c24)
[OAL] Not Clear System Hive
[OAL] Not Clear User Hive
[PWRCON]  PWC_Init***
-OALIntrRequestSysIntr(irq = 11, sysIntr = 18)
-OALIntrRequestSysIntr(irq = 9, sysIntr = 19)
-OALIntrRequestSysIntr(irq = 40, sysIntr = 20)
-OALIntrRequestSysIntr(irq = 19, sysIntr = 21)
-OALIntrRequestSysIntr(irq = 23, sysIntr = 22)
-OALIntrRequestSysIntr(irq = 20, sysIntr = 23)
-OALIntrRequestSysIntr(irq = 88, sysIntr = 24)
-OALIntrRequestSysIntr(irq = 73, sysIntr = 25)
-OALIntrRequestSysIntr(irq = 74, sysIntr = 26)
[HSMMC0] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 94, sysIntr = 27)
[HSMMC0] Turn OFF the F/B delay control.
[HSMMC1] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 7, sysIntr = 28)
-OALIntrRequestSysIntr(irq = 95, sysIntr = 29)
[HSMMC0] Card is Removed!
[HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Card is Inserted!
WARN: OALIoCtlHalGetHWEntropy: Buffer too small
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:8 : ERR CMD:1 : ERR CMD:55 : [HSMMC1] CMD Timeout Error...
<Davicom DM9000A driver for WinCE 6.0>
楼主| twc63 发表于 2012-1-4 20:02:15 | 显示全部楼层
<DM9:++MiniportIntialize>
[dm9: Tries to map io space with 18000000]
[dm9: The mapped address is D2F40000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[UFNPDD] USB Serial Function Class Enabled
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
Current Client "Serial_Class"
[UFNPDD] OTG Cable Attached
[UFNPDD] RESET Again
DEBUG: CreateSerialObject 3
-OALIntrRequestSysIntr(irq = 64, sysIntr = 31)
DEBUG: CreateSerialObject 2
-OALIntrRequestSysIntr(irq = 63, sysIntr = 32)
DEBUG: CreateSerialObject 1
-OALIntrRequestSysIntr(irq = 62, sysIntr = 33)
[USBH] HcdPdd_Init()
[USBH] ++InitializeOHCI()
[USBH] --InitializeOHCI() : Success
+OEMSetAlarmTime(1/4/2012 19:59:13.000)
-OALIntrRequestSysIntr(irq = 13, sysIntr = 34)
-OALIntrRequestSysIntr(irq = 14, sysIntr = 36)
[MFC POWER] Power is up.
[MFC POWER] Power is down-OALIntrRequestSysIntr(irq = 26, sysIntr = 37)
MFC Interrupt has been initialized.
[MFC IOCTL_POWER_CAPABILITIES]
[MFC IOCTL_POWER_CAPABILITIES] leaving...
LED - DLL_PROCESS_ATTACH
ADC - DLL_PROCESS_ATTACH
[GPO_MSG] ++GPO_AllocResources()
-OALIntrRequestSysIntr(irq = 91, sysIntr = 38)
[GPO] port_initialize()
[GPO] set_interrupt_method(3)
[GPO] --set_interrupt_method() = 1
[GPO] set_filter_method(1, 0)
[GPO] --set_filter_method() = 1
[GPO_MSG] --GPO_Init() OK
BEE - DLL_PROCESS_ATTACH
[GPO:INF] ++GPOThread()
TEM - DLL_PROCESS_ATTACH
-OALIntrRequestSysIntr(irq = 18, sysIntr = 39)
[DISPDRV] S3C6410Disp:Close FLprogressbar thread
[DISPDRV] S3C6410Disp::S3C6410Disp()
-OALIntrRequestSysIntr(irq = 21, sysIntr = 40)
2D Sysintr : 40
[DISPDRV:] S3C6410Disp() : m_pDispConReg->VIDTCON2 = 879df
[OAL] LcdWidth(480)  LcdHeight(272)
ChangeDisplaySettingsEx changed rotation angle to 0
++[KEYBD]KeybdDriverInitializeAddresses
++[KEYBD]KeyMatrix::KeybdPowerOn
+Select all column
--[KEYBD]KeyMatrix::KeybdPowerOn
楼主| twc63 发表于 2012-1-4 20:07:04 | 显示全部楼层
+[KEYBD]IsrThreadStart:
-[KEYBD]IsrThreadStart:
ERROR: D:\WINCE600\PUBLIC\COMMON\OAK\DRIVERS\KEYBD\LAYMGR\.\laymgr.cpp line 3829: Keyboard: Error selecting device layout for PDD Matrix
LayMgr.cpp: Layout Manager successfully initialized to  2
-OALIntrRequestSysIntr(irq = 100, sysIntr = 41)
-OALIntrRequestSysIntr(irq = 37, sysIntr = 42)
Maximum Allowed Error 7:
+[KEYBD]IsrThreadProc
-OALIntrRequestSysIntr(irq = 32, sysIntr = 43)
+[KEYBD]Enter Infinite Loop
ERROR: D:\WINCE600\PUBLIC\COMMON\OAK\DRIVERS\KEYBD\LAYMGR\.\laymgr.cpp line 2265: Keyboard: Keypress ignored since Device Layout is not set
楼主| twc63 发表于 2012-1-4 20:07:49 | 显示全部楼层
MSIM: IM_ReadRegistry read KB 5
Explorer(V2.0) taskbar thread started.
NDISPWR:: Found adapter [DM9CE1]
AUTORAS:: Dialer notifies: [1] [Dialer Start]
Posting WM_NETCONNECT(TRUE) message
AUTORAS:: Dialer notifies: [4] [Dialer Connected]
飞凌-alexlee 发表于 2012-1-5 08:38:26 | 显示全部楼层
你插入的什么键盘设备啊~
你是不是bsp加了什么别的东西了啊?
还改了ce的系统文件了啊~
楼主| twc63 发表于 2012-1-5 09:18:58 | 显示全部楼层
没有插,我也没改系统文件啊。
飞凌-alexlee 发表于 2012-1-5 13:04:49 | 显示全部楼层
你的bsp是哪里来的?
你kitl了吗?
楼主| twc63 发表于 2012-1-5 14:50:02 | 显示全部楼层
是你们网上下的,什么是Kitl ?
