查看: 13745|回复: 6
SDK无法安装则麽回事
cangming 发表于 2009-12-23 22:32:27 | 显示全部楼层 |阅读模式
Software development tools required use this SDK for developing applications with native
  code are not installed on this development workstation.If you continue this installation,you
  cannot use this SDK to develop applications that use native code,but you can view Help
  documentation related to native code development.To fully install this SDK for native code
  development ,install the appropriate software development tools and then run the setup
  Wizard again.To detemine which development  tools are required, see this
  Microsoft Web site,at http://go.microsoft.com/fwlink/?likid-18639&clcid=0x409,which you
  can open in an external browser window by clicking the Open Browser button.
这是对话框信息,怎么回子事呀?
phantom 该用户已被删除
phantom 发表于 2009-12-24 17:38:14 | 显示全部楼层
楼主| cangming 发表于 2009-12-24 19:31:44 | 显示全部楼层
回复 2# phantom
就是安装的OK2440III附带的光盘上的eVC,但是无法运行,运行时的错误信息:
Microsoft eMbeded Visual C++ has discovered no CE platform SDK installed on the desktop.
Please install at least one CE platform SDK before launching Microsoft eMbedded Visual C++
怎么回事?.
gooogleman 发表于 2009-12-26 17:02:43 | 显示全部楼层
解决了吗,以前从未遇到过这种问题哦
胖丁 该用户已被删除
胖丁 发表于 2012-1-5 20:55:10 | 显示全部楼层
飞凌-alexlee 发表于 2012-1-6 13:53:58 | 显示全部楼层
胖丁。你的是sdk没装好把
hkp580@sohu.com 该用户已被删除
hkp580@sohu.com 发表于 2012-3-3 10:06:51 | 显示全部楼层
