查看: 885|回复: 0
[硬件咨询] OK3506X-S v1.1开机跳这些log是正常的吗,原机固件
RK3506通行证
express 发表于 2026-3-24 17:26:00 | 显示全部楼层 |阅读模式
  1. I/TC: OP-TEE memory: TEEOS 0x5e000 TA 0x1000 SHM 0x1000
  2. I/TC: Primary CPU initializing
  3. E/TC:0 0 rk_otp_sbpi_read:353 otp_check_ecc fail! parity=0x20
  4. E/TC:0 0 rk_otp_read:789 ---OTP---sbpi read otp failed! addr: 0x1ff
  5. E/TC:0 0 call_initcalls:24 Initcall __text_start + 0x0001a280 failed
  6. I/TC: Primary CPU switching to normal world boot
  7. U-Boot 2017.09-gd76af45 #zmx (Apr 03 2025 - 11:08:12 +0800)
  8. Model: Forlinx OK3506-S Board
  9. MPIDR: 0xf00
  10. PreSerial: 0, raw, 0xff0a0000
  11. DRAM:  256 MiB
  12. Sysmem: init
  13. Relocation Offset: 0d4ef000
  14. Relocation fdt: 0c4fa890 - 0c4fede0
  15. CR: M/C/I
  16. DM: v2
  17. SPI Nand ID c8 52 c8
  18. Bootdev(atags): mtd 1
  19. PartType: EFI
  20. map table blk begin[18048] overflow
  21. map table blk begin[19072] overflow
  22. boot mode: None
  23. RESC: 'boot', blk@0x0000ace5
  24. resource: sha256+
  25. FIT: no signed, no conf required
  26. DTB: rk-kernel.dtb
  27. HASH(c): OK
  28. vdd_cpu init 1011000 uV
  29. I2c0 speed: 400000Hz
  30. I2c2 speed: 400000Hz
  31. params load
  32. Could not find baseparameter partition
  33. Model: Forlinx OK3506-S Board
  34. read eth0 mac form vendor_storage error! try to read from eeprom
  35. read eth0 mac from eeprom is ff:ff:ff:ff:ff:ff
  36. read eth0 mac from eeprom error, use default mac address.
  37. cpuid: 4D 34 53 33 37 34 00 00 00 00 00 00 00 05 01 26
  38. read eth1 mac form vendor_storage error! try to read from eeprom
  39. read eth1 mac from eeprom is ff:ff:ff:ff:ff:ff
  40. read eth1 mac from eeprom error, use default mac address.
  41. cpuid: 4D 34 53 33 37 34 00 00 00 00 00 00 00 05 01 26
  42. Rockchip UBOOT DRM driver version: v1.0.1
  43. Using display timing dts
  44. dsi@ff640000:  detailed mode clock 46000 kHz, flags[a]
  45.     H: 1024 1084 1264 1324
  46.     V: 0600 0605 0607 0617
  47. bus_format: 100e
  48. VOP:0xff600000 update mode to: 1024x600p56, type: MIPI0
  49. VOP:0xff600000 set crtc_clock to 46000KHz, get 45454545Hz
  50. Unsupported bt709f at 10bit csc depth, use bt601f instead
  51. VOP:0xff600000 set plane [400x300->400x300@312x150] fmt[0] addr[0xd900000]
  52. final DSI-Link bandwidth: 460 Mbps x 2
  53. CLK: (arm clk use pvtpll, rate = 1200M)
  54.   gpll 1500000 KHz
  55.   v0pll 1179648 KHz
  56.   v1pll 903168 KHz
  57.   clk_gpll_div 187500 KHz
  58.   clk_gpll_div_100m 93750 KHz
  59.   clk_v0pll_div 147456 KHz
  60.   clk_v1pll_div 129024 KHz
  61.   aclk_bus_root 187500 KHz
  62.   hclk_bus_root 147456 KHz
  63.   pclk_bus_root 93750 KHz
  64.   aclk_hsperi_root 147456 KHz
  65.   hclk_ksperi_root 93750 KHz
  66. Net:   eth0: ethernet@ff4c8000, eth1: ethernet@ff4d0000
  67. Hit key to stop autoboot('Spacebar'):  0
  68. ## Booting FIT Image at 0xbd5ae80 with size 0x0059ca00
  69. Fdt Ramdisk skip relocation
  70. ## Loading kernel from FIT Image at 0bd5ae80 ...
  71.    Using 'conf' configuration
  72. ## Verified-boot: 0
  73.    Trying 'kernel' kernel subimage
  74.      Description:  unavailable
  75.      Type:         Kernel Image
  76.      Compression:  uncompressed
  77.      Data Start:   0x0bd68e80
  78.      Data Size:    5826600 Bytes = 5.6 MiB
  79.      Architecture: ARM
  80.      OS:           Linux
  81.      Load Address: 0x01100000
  82.      Entry Point:  0x01100000
  83.      Hash algo:    sha256
  84.      Hash value:   ad1d34466dd9da395f778cc9e20283038a6d798bf7875df313ea79c04f47c9d2
  85.    Verifying Hash Integrity ... sha256+ OK
  86. ## Loading fdt from FIT Image at 0bd5ae80 ...
  87.    Using 'conf' configuration
  88.    Trying 'fdt' fdt subimage
  89.      Description:  unavailable
  90.      Type:         Flat Device Tree
  91.      Compression:  uncompressed
  92.      Data Start:   0x0bd5b680
  93.      Data Size:    54890 Bytes = 53.6 KiB
  94.      Architecture: ARM
  95.      Load Address: 0x00063000
  96.      Hash algo:    sha256
  97.      Hash value:   3c8a4965aef81c9ea515ffea0a5b7320a61355e0bee053ea70addb22fe738c20
  98.    Verifying Hash Integrity ... sha256+ OK
  99.    Loading fdt from 0x00063000 to 0x00063000
  100.    Booting using the fdt blob at 0x00063000
  101.    Loading Kernel Image from 0x0bd68e80 to 0x01100000 ... OK
  102.    kernel loaded at 0x01100000, end = 0x0168e828
  103.    Using Device Tree in place at 00063000, end 00073669
  104. Unable to update property dsi@ff640000:status, err=FDT_ERR_BADPATH
  105. ## reserved-memory:
  106.   trust@0: addr=0 size=62000
  107.   drm-logo@0: addr=d900000 size=ec000
  108.   ramoops@83000: addr=83000 size=2d000
  109. Adding bank: 0x00000000 - 0x10000000 (size: 0x10000000)
  110. Total: 2033.7/2272.324 ms
  111. Starting kernel ...
  112. [    2.403602] Booting Linux on physical CPU 0xf00
  113. [    2.403623] Linux version 6.1.99 (zmx@910e6e9b1bd8) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #1 SMP PREEMPT Thu Apr  3 11:23:18 CST 2025
  114. [    2.403634] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  115. [    2.403644] CPU: div instructions available: patching division code
  116. [    2.403649] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  117. [    2.404020] OF: fdt: Machine model: Forlinx OK3506-S Board
  118. [    2.406766] earlycon: uart8250 at MMIO32 0xff0a0000 (options '')
  119. [    2.473542] printk: bootconsole [uart8250] enabled
  120. [    2.478566] Memory policy: Data cache writealloc
  121. [    2.483583] Reserved memory: created CMA memory pool at 0x0ea00000, size 22 MiB
  122. [    2.491005] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  123. [    2.499709] Zone ranges:
  124. [    2.502382]   Normal   [mem 0x0000000000000000-0x000000000fffffff]
  125. [    2.508776] Movable zone start for each node
  126. [    2.513177] Early memory node ranges
  127. [    2.516919]   node   0: [mem 0x0000000000000000-0x000000000fffffff]
  128. [    2.523429] Initmem setup node 0 [mem 0x0000000000000000-0x000000000fffffff]
  129. [    2.543236] psci: probing for conduit method from DT.
  130. [    2.548450] psci: PSCIv1.0 detected in firmware.
  131. [    2.553210] psci: Using standard PSCI v0.2 function IDs
  132. [    2.558609] psci: MIGRATE_INFO_TYPE not supported.
  133. [    2.563540] psci: SMC Calling Convention v1.1
  134. [    2.568211] percpu: Embedded 11 pages/cpu s16340 r8192 d20524 u45056
  135. [    2.574875] Built 1 zonelists, mobility grouping on.  Total pages: 65024
  136. [    2.581835] Kernel command line: storagemedia=mtd androidboot.storagemedia=mtd androidboot.mode=normal  rw rootwait earlycon=uart8250,mmio32,0xff0a0000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 snd_aloop.index=7 snd_aloop.use_raw_jiffies=1 mtdparts=spi-nand0:0x400000@0x800000(uboot),0x400000@0xc00000(misc),0x4000000@0x1000000(boot),0x8000000@0x5000000(recovery),0x80000000@0xd000000(rootfs),0x8000000@0x8d000000(oem),0x7af60000@0x95000000(userdata) #z-04/03/2025 androidboot.fwver=ddr-v1.04-0ac6b06a19,tee-v1.25,uboot-d76af45 user_debug=31
  137. [    2.631425] Unknown kernel command line parameters "#z-04/03/2025 storagemedia=mtd", will be passed to user space.
  138. [    2.642234] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
  139. [    2.650253] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
  140. [    2.658027] mem auto-init: stack:off, heap alloc:off, heap free:off
  141. [    2.670666] Memory: 226100K/262144K available (4926K kernel code, 1119K rwdata, 2452K rodata, 188K init, 360K bss, 13516K reserved, 22528K cma-reserved)
  142. [    2.684900] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=3, Nodes=1
  143. [    2.691858] rcu: Preemptible hierarchical RCU implementation.
  144. [    2.697830] rcu:     RCU event tracing is enabled.
  145. [    2.702499] rcu:     RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=3.
  146. [    2.709227] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
  147. [    2.717131] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=3
  148. [    2.724099] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  149. [    2.730935] rcu: srcu_init: Setting srcu_struct sizes based on contention.
  150. [    2.749048] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
  151. [    2.755356] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  152. [    2.766462] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  153. [    2.774684] Switching to timer-based delay loop, resolution 41ns
  154. [    2.781463] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  155. [    2.792205] CPU: Testing write buffer coherency: ok
  156. [    2.797302] pid_max: default: 4096 minimum: 301
  157. [    2.802112] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
  158. [    2.809654] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
  159. [    2.818404] /cpus/cpu@f00 missing clock-frequency property
  160. [    2.824187] /cpus/cpu@f01 missing clock-frequency property
  161. [    2.829922] /cpus/cpu@f02 missing clock-frequency property
  162. [    2.835617] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
  163. [    2.842460] Setting up static identity map for 0x108240 - 0x108294
  164. [    2.849029] rcu: Hierarchical SRCU implementation.
  165. [    2.854043] rcu:     Max phase no-delay instances is 1000.
  166. [    2.860183] smp: Bringing up secondary CPUs ...
  167. I/TC: Secondary CPU 1 initializing
  168. I/TC: Secondary CPU 1 switching to normal world boot
  169. I/TC: Secondary CPU 2 initializing
  170. I/TC: Secondary CPU 2 switching to normal world boot
  171. [    2.873390] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
  172. [    2.882006] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
  173. [    2.882130] smp: Brought up 1 node, 3 CPUs
  174. [    2.898269] SMP: Total of 3 processors activated (144.00 BogoMIPS).
  175. [    2.904814] CPU: All CPU(s) started in SVC mode.
  176. [    2.910332] devtmpfs: initialized
  177. [    2.924146] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  178. [    2.932380] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  179. [    2.942487] futex hash table entries: 16 (order: -2, 1024 bytes, linear)
  180. [    2.949505] pinctrl core: initialized pinctrl subsystem
  181. [    2.956201] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  182. [    2.962883] DMA: preallocated 256 KiB pool for atomic coherent allocations
  183. [    2.970790] Registered FIQ tty driver
  184. [    2.974888] thermal_sys: Registered thermal governor 'step_wise'
  185. [    2.974900] thermal_sys: Registered thermal governor 'user_space'
  186. [    2.981185] cpuidle: using governor menu
  187. [    2.993154] ramoops: boot-log-0      0xd000@0x00083000
  188. [    2.998249] ramoops: console 0x20000@0x00090000
  189. [    3.003312] printk: console [ramoops-1] enabled
  190. [    3.008083] pstore: Registered ramoops as persistent store backend
  191. [    3.014426] ramoops: using 0x2d000@0x83000, ecc: 0
  192. [    3.030899] rockchip-gpio ff940000.gpio: probed /pinctrl/gpio@ff940000
  193. [    3.038458] rockchip-gpio ff870000.gpio: probed /pinctrl/gpio@ff870000
  194. [    3.045882] rockchip-gpio ff1c0000.gpio: probed /pinctrl/gpio@ff1c0000
  195. [    3.053364] rockchip-gpio ff1d0000.gpio: probed /pinctrl/gpio@ff1d0000
  196. [    3.060925] rockchip-gpio ff1e0000.gpio: probed /pinctrl/gpio@ff1e0000
  197. [    3.067843] rockchip-pinctrl pinctrl: probed pinctrl
  198. [    3.076007] platform ff600000.vop: Fixed dependency cycle(s) with /dsi@ff640000
  199. [    3.083771] platform ff640000.dsi: Fixed dependency cycle(s) with /dsi@ff640000/panel@0
  200. [    3.092046] platform ff640000.dsi: Fixed dependency cycle(s) with /vop@ff600000
  201. [    3.113032] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
  202. [    3.120130] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
  203. [    3.127386] fiq_debugger_probe: could not install nmi irq handler
  204. [[    3.133835] printk: console [ttyFIQ0] enabled
  205.     3.133835] printk: console [ttyFIQ0] enabled
  206. [    3.142762] printk: bootconsole [uart8250] disabled
  207. [    3.142762] printk: bootconsole [uart8250] disabled
  208. [    3.148179] Registered fiq debugger ttyFIQ0
  209. [    3.159683] SCSI subsystem initialized
  210. [    3.159904] usbcore: registered new inte**ce driver usbfs
  211. [    3.159976] usbcore: registered new inte**ce driver hub
  212. [    3.160032] usbcore: registered new device driver usb
  213. [    3.160333] mc: Linux media inte**ce: v0.10
  214. [    3.160446] videodev: Linux video capture inte**ce: v2.00
  215. [    3.160502] pps_core: LinuxPPS API ver. 1 registered
  216. [    3.160518] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  217. [    3.160546] PTP clock support registered
  218. [    3.161799] Advanced Linux Sound Architecture Driver Initialized.
  219. [    3.162343] Bluetooth: Core ver 2.22
  220. [    3.162418] NET: Registered PF_BLUETOOTH protocol family
  221. [    3.162435] Bluetooth: HCI device and connection manager initialized
  222. [    3.162455] Bluetooth: HCI socket layer initialized
  223. [    3.162471] Bluetooth: L2CAP socket layer initialized
  224. [    3.162499] Bluetooth: SCO socket layer initialized
  225. [    3.163099] rockchip-cpuinfo cpuinfo: SoC            : 35060000
  226. [    3.163134] rockchip-cpuinfo cpuinfo: Serial         : 93961a9ba89dd64b
  227. [    3.164055] clocksource: Switched to clocksource arch_sys_counter
  228. [    3.166025] NET: Registered PF_INET protocol family
  229. [    3.166256] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
  230. [    3.167448] tcp_listen_portadE/TC:2   plat_shm_get_page_num:373 plat_shm_get_page_num: type 6 alloc is not supported
  231. dr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
  232. [    3.167504] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  233. [    3.167533] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
  234. [    3.167568] TCP bind hash table entries: 2048 (order: 3, 32768 bytes, linear)
  235. [    3.167650] TCP: Hash tables configured (established 2048 bind 2048)
  236. [    3.167767] UDP hash table entries: 128 (order: 0, 4096 bytes, linear)
  237. [    3.167812] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes, linear)
  238. [    3.168046] NET: Registered PF_UNIX/PF_LOCAL protocol family
  239. [    3.170681] rockchip-thermal ff650000.tsadc: tsadc is probed successfully!
  240. [    3.171940] Initialise system trusted keyrings
  241. [    3.172278] workingset: timestamp_bits=30 max_order=16 bucket_order=0
  242. [    3.176193] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  243. [    3.176426] ntfs: driver 2.1.32 [Flags: R/W DEBUG].
  244. [    3.176599] ntfs3: Enabled Linux POSIX ACLs support
  245. [    3.176620] ntfs3: Read-only LZX/Xpress compression included
  246. [    3.176707] fuse: init (API version 7.37)
  247. [    3.248422] Key type asymmetric registered
  248. [    3.248458] Asymmetric key parser 'x509' registered
  249. [    3.248579] io scheduler mq-deadline registered
  250. [    3.248601] io scheduler kyber registered
  251. [    3.248764] io scheduler bfq registered
  252. [    3.250457] rockchip-usb2phy ff2b0000.usb2-phy: error -ENXIO: IRQ index 0 not found
  253. [    3.255272] pwm-backlight backlight: supply power not found, using dummy regulator
  254. [    3.259828] dma-pl330 ff000000.dma-controller: Loaded driver for PL330 DMAC-241330
  255. [    3.259864] dma-pl330 ff000000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
  256. [    3.261486] dma-pl330 ff008000.dma-controller: Loaded driver for PL330 DMAC-241330
  257. [    3.261523] dma-pl330 ff008000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  258. [    3.261896] rockchip-system-monitor rockchip-system-monitor: system monitor probe
  259. [    3.263201] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
  260. [    3.263885] ff0c0000.serial: ttyS2 at MMIO 0xff0c0000 (irq = 47, base_baud = 1500000) is a 16550AI/TC: ddr_plat_smc_handler: default
  261. [    3.265112] random: crng init done
  262. [    3.266930] dw-mipi-dsi-rockchip ff640000.dsiI/TC: ddr_plat_smc_handler: unhandled DDR SMC id(0x13)
  263. : Fixed dependency cycle(s) with /dsi@ff640000/panel@0
  264. [    3.267058] mipi-dsi ff640000.dsi.0: Fixed dependency cycle(s) with /dsi@ff640000
  265. [    3.270152] rockchip-drm display-subsystem: bound ff600000.vop (ops 0xb07299f8)
  266. [    3.270215] dw-mipi-dsi-rockchip ff640000.dsi: failed to find panel or bridge: -517
  267. [    3.286847] no ATF memory for init
  268. [    3.292978] CAN device driver inte**ce
  269. [    3.293653] rk3576_canfd ff320000.can: Failed to request rxchan
  270. [    3.294231] rk3576_canfd ff320000.can: CAN info: use_dma = 0, rx_max_data = 18, fifo_depth = 14
  271. [    3.294770] rk3576_canfd ff330000.can: Failed to request rxchan
  272. [    3.295283] rk3576_canfd ff330000.can: CAN info: use_dma = 0, rx_max_data = 18, fifo_depth = 14
  273. [    3.296045] rk_gmac-dwmac ff4c8000.ethernet: IRQ eth_lpi not found
  274. [    3.296240] rk_gmac-dwmac ff4c8000.ethernet: supply phy not found, using dummy regulator
  275. [    3.296418] rk_gmac-dwmac ff4c8000.ethernet: clock input or output? (output).
  276. [    3.296444] rk_gmac-dwmac ff4c8000.ethernet: Can not read property: tx_delay.
  277. [    3.296459] rk_gmac-dwmac ff4c8000.ethernet: set tx_delay to 0xffffffff
  278. [    3.296475] rk_gmac-dwmac ff4c8000.ethernet: Can not read property: rx_delay.
  279. [    3.296488] rk_gmac-dwmac ff4c8000.ethernet: set rx_delay to 0xffffffff
  280. [    3.296511] rk_gmac-dwmac ff4c8000.ethernet: integrated PHY? (no).
  281. [    3.296533] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock mac_clk_rx
  282. [    3.296550] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock mac_clk_tx
  283. [    3.296584] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock clk_mac_ref
  284. [    3.296603] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock clk_mac_refout
  285. [    3.296621] rk_gmac-dwmac ff4c8000.ethernet: cannot get clock clk_mac_speed
  286. [    3.296876] rk_gmac-dwmac ff4c8000.ethernet: init for RMII
  287. [    3.297132] rk_gmac-dwmac ff4c8000.ethernet: User ID: 0x40, Synopsys ID: 0x51
  288. [    3.297167] rk_gmac-dwmac ff4c8000.ethernet:         DWMAC4/5
  289. [    3.297184] rk_gmac-dwmac ff4c8000.ethernet: DMA HW capability register supported
  290. [    3.297199] rk_gmac-dwmac ff4c8000.ethernet: RX Checksum Offload Engine supported
  291. [    3.297212] rk_gmac-dwmac ff4c8000.ethernet: TX Checksum insertion supported
  292. [    3.297226] rk_gmac-dwmac ff4c8000.ethernet: Wake-Up On Lan supported
  293. [    3.297316] rk_gmac-dwmac ff4c8000.ethernet: TSO supported
  294. [    3.297334] rk_gmac-dwmac ff4c8000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  295. [    3.297351] rk_gmac-dwmac ff4c8000.ethernet: Enabled RFS Flow TC (entries=10)
  296. [    3.297367] rk_gmac-dwmac ff4c8000.ethernet: TSO feature enabled
  297. [    3.297422] rk_gmac-dwmac ff4c8000.ethernet: Using 40/40 bits DMA host/device width
  298. [    4.329715] rk_gmac-dwmac ff4d0000.ethernet: IRQ eth_lpi not found
  299. [    4.329938] rk_gmac-dwmac ff4d0000.ethernet: supply phy not found, using dummy regulator
  300. [    4.330138] rk_gmac-dwmac ff4d0000.ethernet: clock input or output? (output).
  301. [    4.330164] rk_gmac-dwmac ff4d0000.ethernet: Can not read property: tx_delay.
  302. [    4.330179] rk_gmac-dwmac ff4d0000.ethernet: set tx_delay to 0xffffffff
  303. [    4.330196] rk_gmac-dwmac ff4d0000.ethernet: Can not read property: rx_delay.
  304. [    4.330209] rk_gmac-dwmac ff4d0000.ethernet: set rx_delay to 0xffffffff
  305. [    4.330233] rk_gmac-dwmac ff4d0000.ethernet: integrated PHY? (no).
  306. [    4.330256] rk_gmac-dwmac ff4d0000.ethernet: cannot get clock mac_clk_rx
  307. [    4.330276] rk_gmac-dwmac ff4d0000.ethernet: cannot get clock mac_clk_tx
  308. [    4.330311] rk_gmac-dwmac ff4d0000.ethernet: cannot get clock clk_mac_ref
  309. [    4.330330] rk_gmac-dwmac ff4d0000.ethernet: cannot get clock clk_mac_refout
  310. [    4.330347] rk_gmac-dwmac ff4d0000.ethernet: cannot get clock clk_mac_speed
  311. [    4.330605] rk_gmac-dwmac ff4d0000.ethernet: init for RMII
  312. [    4.330875] rk_gmac-dwmac ff4d0000.ethernet: User ID: 0x40, Synopsys ID: 0x51
  313. [    4.330913] rk_gmac-dwmac ff4d0000.ethernet:         DWMAC4/5
  314. [    4.330930] rk_gmac-dwmac ff4d0000.ethernet: DMA HW capability register supported
  315. [    4.330944] rk_gmac-dwmac ff4d0000.ethernet: RX Checksum Offload Engine supported
  316. [    4.330959] rk_gmac-dwmac ff4d0000.ethernet: TX Checksum insertion supported
  317. [    4.330972] rk_gmac-dwmac ff4d0000.ethernet: Wake-Up On Lan supported
  318. [    4.331059] rk_gmac-dwmac ff4d0000.ethernet: TSO supported
  319. [    4.331078] rk_gmac-dwmac ff4d0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  320. [    4.331096] rk_gmac-dwmac ff4d0000.ethernet: Enabled RFS Flow TC (entries=10)
  321. [    4.331112] rk_gmac-dwmac ff4d0000.ethernet: TSO feature enabled
  322. [    4.331127] rk_gmac-dwmac ff4d0000.ethernet: Using 40/40 bits DMA host/device width
  323. [    4.466033] PPP generic driver version 2.4.2
  324. [    4.466339] usbcore: registered new inte**ce driver asix
  325. [    4.466407] usbcore: registered new inte**ce driver ax88179_178a
  326. [    4.466457] usbcore: registered new inte**ce driver cdc_ether
  327. [    4.466513] usbcore: registered new inte**ce driver net1080
  328. [    4.466557] usbcore: registered new inte**ce driver cdc_subset
  329. [    4.466599] usbcore: registered new inte**ce driver zaurus
  330. [    4.466681] usbcore: registered new inte**ce driver cdc_ncm
  331. [    4.466725] usbcore: registered new inte**ce driver qmi_wwan
  332. [    4.466775] usbcore: registered new inte**ce driver r8153_ecm
  333. [    4.467441] dwc2 ff740000.usb: supply vusb_d not found, using dummy regulator
  334. [    4.467630] dwc2 ff740000.usb: supply vusb_a not found, using dummy regulator
  335. [    4.597465] dwc2 ff740000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
  336. [    4.597691] dwc2 ff740000.usb: DWC OTG Controller
  337. [    4.597739] dwc2 ff740000.usb: new USB bus registered, assigned bus number 1
  338. [    4.597793] dwc2 ff740000.usb: irq 55, io mem 0xff740000
  339. [    4.598564] hub 1-0:1.0: USB hub found
  340. [    4.598629] hub 1-0:1.0: 1 port detected
  341. [    4.599582] dwc2 ff780000.usb: supply vusb_d not found, using dummy regulator
  342. [    4.599766] dwc2 ff780000.usb: supply vusb_a not found, using dummy regulator
  343. [    4.727464] dwc2 ff780000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
  344. [    4.727638] dwc2 ff780000.usb: DWC OTG Controller
  345. [    4.727682] dwc2 ff780000.usb: new USB bus registered, assigned bus number 2
  346. [    4.727729] dwc2 ff780000.usb: irq 56, io mem 0xff780000
  347. [    4.728505] hub 2-0:1.0: USB hub found
  348. [    4.728572] hub 2-0:1.0: 1 port detected
  349. [    4.729791] usbcore: registered new inte**ce driver cdc_wdm
  350. [    4.729898] usbcore: registered new inte**ce driver usb-storage
  351. [    4.730001] usbcore: registered new inte**ce driver option
  352. [    4.730040] usbserial: USB Serial support registered for GSM modem (1-port)
  353. [    4.730211] usbcore: registered new inte**ce driver cdc_xr_usb_serial
  354. [    4.730233] xr_usb_serial_common: Exar USB UART (serial port) driver
  355. [    4.730972] i2c_dev: i2c /dev entries driver
  356. [    4.732383] edt_ft5x06 0-0038: supply vcc not found, using dummy regulator
  357. [    4.732573] edt_ft5x06 0-0038: supply iovcc not found, using dummy regulator
  358. [    4.735716] rtc-rx8010 2-0032: registered as rtc0
  359. [    4.736189] rtc-rx8010 2-0032: setting system clock to 2026-03-24T17:27:44 UTC (1774373264)
  360. [    4.736564] rtc-pcf8563 2-0051: pcf8563_write_block_data: err=-6 addr=0e, data=03
  361. [    4.736594] rtc-pcf8563 2-0051: pcf8563_probe: write error
  362. [    4.736658] rtc-pcf8563: probe of 2-0051 failed with error -5
  363. [    4.738684] usbcore: registered new inte**ce driver btusb
  364. [    4.738866] cpu cpu0: bin=0
  365. [    4.739017] cpu cpu0: leakage=3
  366. [    4.740046] cpu cpu0: pvtm=1480
  367. [    4.740696] cpu cpu0: pvtm-volt-sel=0
  368. [    4.741940] cpu cpu0: avs=0
  369. [    4.742171] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=1
  370. [    4.742858] Synopsys Designware ** Card Inte**ce Driver
  371. [    4.744005] dwmmc_rockchip ff480000.mmc: No normal pinctrl state
  372. [    4.744105] dwmmc_rockchip ff480000.mmc: No idle pinctrl state
  373. [    4.744364] dwmmc_rockchip ff480000.mmc: IDMAC supports 32-bit address mode.
  374. [    4.744416] dwmmc_rockchip ff480000.mmc: Using internal DMA controller.
  375. [    4.744439] dwmmc_rockchip ff480000.mmc: Version ID is 270a
  376. [    4.744523] dwmmc_rockchip ff480000.mmc: DW MMC controller at irq 61,32 bit host data width,256 deep fifo
  377. [    4.744580] usbcore: registered new inte**ce driver usbhid
  378. [    4.744601] usbhid: USB HID core driver
  379. [    4.744979] mmc_host mmc0: card is non-removable.
  380. [    4.751831] rk-multicodecs es8388-sound: Has no ADC channel
  381. [    4.757710] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  382. [    4.789729] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
  383. [    4.797613] rk-multicodecs es8388-sound: Don't need to map headset detect gpio to irq
  384. [    4.802811] Initializing XFRM netlink socket
  385. [    4.802899] NET: Registered PF_PACKET protocol family
  386. [    4.802944] NET: Registered PF_KEY protocol family
  387. [    4.802969] can: controller area network core
  388. [    4.803096] NET: Registered PF_CAN protocol family
  389. [    4.803130] can: raw protocol
  390. [    4.803159] can: broadcast manager protocol
  391. [    4.803193] can: netlink gateway - max_hops=1
  392. [    4.803480] Bluetooth: RFCOMM socket layer initialized
  393. [    4.803549] Bluetooth: RFCOMM ver 1.11
  394. [    4.803589] [BT_RFKILL]: Enter rfkill_rk_init
  395. [    4.803612] [WLAN_RFKILL]: Enter rfkill_wlan_init
  396. [    4.804313] [BT_RFKILL]: bluetooth_platdata_parse_dt: uart_rts_gpios is no-in-use.
  397. [    4.804400] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
  398. [    4.804623] [BT_RFKILL]: bt_default device registered.
  399. [    4.804867] input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input0
  400. [    4.806575] Registering SWP/SWPB emulation handler
  401. [    4.807053] Loading compiled-in X.509 certificates
  402. [    4.814346] rga2 ff610000.rga: probe successfully, irq = 65, hw_version:3.a.07135
  403. [    4.814581] rga: IOMMU binding successfully, default mapping core[0x4]
  404. [    4.814861] rga: Module initialized. v1.3.6
  405. [    4.820848] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
  406. [    4.835464] rockchip-drm display-subsystem: bound ff600000.vop (ops 0xb07299f8)
  407. [    4.835643] rockchip-drm display-subsystem: bound ff640000.dsi (ops 0xb072af6c)
  408. [    4.836640] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0
  409. [    4.849214] rockchip-drm display-subsystem: [drm] run display error_event monitor
  410. [    4.849891] input: adc-keys as /devices/platform/adc-keys/input/input1
  411. [    4.852017] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 187500Hz, actual 187500HZ div = 0)
  412. [    4.854754] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  413. [    4.857952] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  414. [    4.859896] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
  415. [    4.860074] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  416. [    4.860111] cfg80211: failed to load regulatory.db
  417. [    4.860241] clk: Disabling unused clocks
  418. [    4.860868] rockchip-pm rockchip-suspend: not set pwm-regulator-config
  419. [    4.861166] rockchip-suspend not set sleep-mode-config for mem-lite
  420. [    4.861194] rockchip-suspend not set wakeup-config for mem-lite
  421. [    4.861217] rockchip-suspend not set sleep-mode-config for mem-ultra
  422. [    4.861235] rockchip-suspend not set wakeup-config for mem-ultra
  423. [    4.862096] ALSA device list:
  424. [    4.862128]   #0: rockchip-es8388
  425. [    4.862146]   #1: rockchip,acodec
  426. [    5.017457] usb 2-1: new high-speed USB device number 2 using dwc2
  427. [    5.047535] edt_ft5x06 0-0038: touchscreen probe failed
  428. [    5.048259] Waiting for root device PARTUUID=614e0000-0000...
  429. [    5.215688] hub 2-1:1.0: USB hub found
  430. [    5.215875] hub 2-1:1.0: 4 ports detected
  431. [    5.594160] usb 2-1.4: new high-speed USB device number 3 using dwc2
  432. [    5.789633] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000d lmp_ver=08 lmp_subver=8723
  433. [    5.790633] Bluetooth: hci0: RTL: rom_version status=0 version=2
  434. [    5.790696] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723d_fw.bin
  435. [    5.790955] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723d_fw.bin failed with error -2
  436. [    5.791012] Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8723d_fw.bin not found
  437. [    7.897444] vendor storage:20190527 ret = -1
  438. [   14.941164] platform mtd_vendor_storage: deferred probe pending
复制代码
如上,最后一条log即【[ 14.941164] platform mtd_vendor_storage: deferred probe pending】
