查看: 6|回复: 0
pack问题
T153通行证
HDKV 发表于 昨天 15:44 | 显示全部楼层 |阅读模式
orlinx@forlinx:~/work/OK153-linux-sdk$ ./build.sh pack
11-06 15:38:47.943   14905 D mkcommon  : ========ACTION List: mk_pack ;========
11-06 15:38:47.947   14905 D mkcommon  : options :
11-06 15:38:47.950   14905 I mkcommon  : packing firmware ...
11-06 15:38:48.631   14959 I pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/common/keys
11-06 15:38:49.600   14959 E pack      : something is incorrect:please <./build.sh config>.
11-06 15:38:49.615   14959 D pack      : copying tools file
11-06 15:38:49.705   14959 D pack      : copying configs file
11-06 15:38:49.987   14959 D pack      : copying product configs file
11-06 15:38:49.999   14959 D pack      : linux copying boardt&linux_kernel_version configs file
11-06 15:38:50.011   14959 D pack      : Use u-boot env file: /home/forlinx/work/OK153-linux-sdk/device/config/chips/t153/configs/okt153_emmc/buildroot/env.cfg
11-06 15:38:50.051   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/aultls32.fex
11-06 15:38:50.055   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/aultools.fex
11-06 15:38:50.059   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/boot_package.cfg
11-06 15:38:50.063   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/boot_package.fex
11-06 15:38:50.073   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/boot_package_nor.cfg
11-06 15:38:50.084   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/cardscript.fex
11-06 15:38:50.093   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/cardscript_secure.fex
11-06 15:38:50.100   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/cardtool.fex
11-06 15:38:50.109   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/diskfs.fex
11-06 15:38:50.123   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/dragon_toc.cfg
11-06 15:38:50.131   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/dtboimg.cfg
11-06 15:38:50.139   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/env.cfg
11-06 15:38:50.150   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/env_burn.cfg
11-06 15:38:50.157   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/esm.fex
11-06 15:38:50.165   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/image.cfg
11-06 15:38:50.177   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/image_crashdump.cfg
11-06 15:38:50.185   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/image_linux.cfg
11-06 15:38:50.199   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/image_nor.cfg
11-06 15:38:50.207   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/parameter.fex
11-06 15:38:50.215   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/programmer_img.cfg
11-06 15:38:50.225   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/split_**x.fex
11-06 15:38:50.232   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sunxi.fex
11-06 15:38:50.248   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sys_config.fex
11-06 15:38:50.256   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sys_partition.fex
11-06 15:38:50.267   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sys_partition_dump.fex
11-06 15:38:50.270   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sys_partition_nor.fex
11-06 15:38:50.278   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sys_partition_private.fex
11-06 15:38:50.287   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sysrecovery.fex
11-06 15:38:50.297   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc0.fex
11-06 15:38:50.301   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc0_ft.fex
11-06 15:38:50.307   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc0_nand.fex
11-06 15:38:50.316   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc0_nor.fex
11-06 15:38:50.325   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc0_sdcard.fex
11-06 15:38:50.331   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc0_ufs.fex
11-06 15:38:50.334   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/toc1.fex
11-06 15:38:50.345   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/usbtool.fex
11-06 15:38:50.352   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/usbtool_crash.fex
11-06 15:38:50.365   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/usbtool_test.fex
11-06 15:38:50.376   14959 D pack      : /home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/verity_block.fex
11-06 15:38:50.389   14959 D pack      : copying boot resource
11-06 15:38:50.770   14959 D pack      : copying boot file
11-06 15:38:51.263   14959 D pack      : copying boot file 2.0
11-06 15:38:51.580   14959 D pack      : copying arm secure boot file
11-06 15:38:51.687   14959 D pack      : No dts for spl
11-06 15:38:51.690   14959 D pack      : spl.dtb not exit!
11-06 15:38:51.694   14959 D pack      : copying additional files
11-06 15:38:51.710   14959 D pack      : handle partition_size
11-06 15:38:52.852   14959 I pack      : skip split fdt
11-06 15:38:53.398   14959 D pack      : update optee
11-06 15:38:54.812   14959 D pack      : do not set LINUX_DTBO_FILE
11-06 15:38:54.819   14959 D pack      : pack boot package
11-06 15:38:54.873   14959 D pack      : content_count=2
11-06 15:38:54.877   14959 D pack      : 2ICHEE_REDUNDANT_ENV_SIZE:0x20000
11-06 15:38:54.880   14959 D pack      : --mkenvimage create redundant env data!--
11-06 15:38:54.896   14959 D pack      : --redundant env.cfg data size 0x20000---
11-06 15:38:55.083   16355 D mkkernel  : verity not supported yet
11-06 15:38:55.095   14959 D pack      : packing for linux
11-06 15:38:55.112   14959 D pack      : do_fit_image
11-06 15:38:55.115   14959 D pack      : create_kernel_fit_image
11-06 15:38:55.120   14959 E pack      : Can not find kernel.its
11-06 15:38:55.153   14959 D pack      : normal
cat: /home/forlinx/work/OK153-linux-sdk/brandy/brandy-2.0/u-boot-2023/bsp/configs/OKT153-S-Linux_defconfig: No such file or directory
11-06 15:38:55.259   14959 D pack      : flashmap is disable
11-06 15:38:55.286   14959 D pack      : commit : 4ccbd73c47-dirty
11-06 15:38:55.289   14959 D pack      : mbr count = 4
11-06 15:38:55.311   14959 D pack      :
11-06 15:38:55.327   14959 D pack      : partitation file Path=/home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sys_partition.bin
11-06 15:38:55.331   14959 D pack      : mbr_name file Path=/home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/sunxi_mbr.fex
11-06 15:38:55.345   14959 D pack      : download_name file Path=/home/forlinx/work/OK153-linux-sdk/out/t153/okt153_emmc/pack_out/dlinfo.fex
11-06 15:38:55.349   14959 D pack      :
11-06 15:38:55.352   14959 D pack      : mbr size = 16384
11-06 15:38:55.359   14959 D pack      : mbr magic softw411
11-06 15:38:55.375   14959 D pack      : disk name=boot-resource
11-06 15:38:55.391   14959 D pack      : disk name=env
11-06 15:38:55.394   14959 D pack      : disk name=env-redund
11-06 15:38:55.402   14959 D pack      : disk name=amp-freertos
11-06 15:38:55.418   14959 D pack      : disk name=riscv0
11-06 15:38:55.431   14959 D pack      : disk name=private
11-06 15:38:55.434   14959 D pack      : disk name=boot
11-06 15:38:55.453   14959 D pack      : ERROR:  unable to open file boot.fex
11-06 15:38:55.456   14959 D pack      : update_for_part_info -1
11-06 15:38:55.460   14959 D pack      : ERROR: update mbr file fail
11-06 15:38:55.487   14959 F pack      : update_mbr failed
