- 8
贡献50
飞刀6 FD
注册时间2026-10-21
在线时间1 小时
连接5G wifi的时候出现以下问题:
- <span style="font-family: quote-cjk-patch, Inter, system-ui, -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Oxygen, Ubuntu, Cantarell, "Open Sans", "Helvetica Neue", sans-serif; font-variant-ligatures: no-contextual; white-space: pre-wrap; background-color: white;"><font color="#000000" style="">[ 1613.074454] wlan: mlan0 START SCAN
- wpa connecting ...
- [ 1618.494556] wlan: SCAN COMPLETED: scanned AP count=22
- [ 1618.498402] wlan: HostMlme mlan0 send auth to bssid 30:XX:XX:XX:7b:80
- [ 1621.000987] wlan: mlan0 START SCAN
- [ 1626.481843] wlan: SCAN COMPLETED: scanned AP count=22
- [ 1626.486233] wlan: HostMlme mlan0 send auth to bssid 30:XX:XX:XX:98:e0
- [ 1629.390098] wlan: mlan0 START SCAN
- root@ok3572-buildroot:/# [ 1634.775890] wlan: SCAN COMPLETED: scanned AP count=19
- [ 1634.778736] wlan: HostMlme mlan0 send auth to bssid 30:XX:XX:XX:7b:80
- ifconfig[ 1635.809828] mlan0:
- [ 1635.809845] wlan: HostMlme Auth received from 30:XX:XX:XX:7b:80
- [ 1636.816507] wlan:MLAN_EVENT_ASSOC_FAILURE
- [ 1636.816559] ASSOC_RESP: Association Failed, status code = 1, error = 0xfffc, a_id = 0xffff
- [ 1636.816576] IOCTL failed: 0000000034f598a1 id=0x20000, sub_id=0x20001 action=1, status_code=0xfffc0001 [???]
- [ 1636.816617] HostMlme mlan0: bss_start Fails
- [ 1636.816651] wlan: HostMlme mlan0 Failed to connect to bssid 30:XX:XX:XX:7b:80
- [ 1637.921645] wlan: mlan0 START SCAN
- [ 1643.377785] wlan: SCAN COMPLETED: scanned AP count=22
- [ 1643.382417] wlan: HostMlme mlan0 send auth to bssid 30:XX:XX:XX:98:e0
- [ 1650.790973] wlan: mlan0 START SCAN
- [ 1656.177763] wlan: SCAN COMPLETED: scanned AP count=16
- [ 1656.180592] wlan: HostMlme mlan0 send auth to bssid 30:XX:XX:XX:7b:80
- [ 1657.822790] mlan0:
- [ 1657.822804] wlan: HostMlme Auth received from 30:XX:XX:XX:7b:80
- [ 1658.829513] wlan:MLAN_EVENT_ASSOC_FAILURE
- [ 1658.829570] ASSOC_RESP: Association Failed, status code = 1, error = 0xfffc, a_id = 0xffff
- [ 1658.829587] IOCTL failed: 00000000f1f319d2 id=0x20000, sub_id=0x20001 action=1, status_code=0xfffc0001 [???]
- [ 1658.829627] HostMlme mlan0: bss_start Fails
- [ 1658.829662] wlan: HostMlme mlan0 Failed to connect to bssid 30:XX:XX:XX:7b:80
- [ 1668.938674] wlan: mlan0 START SCAN
- [ 1674.405056] wlan: SCAN COMPLETED: scanned AP count=13
- ifconfig mlan0
- sh: ifconfigifconfig: command not found
- root@ok3572-buildroot:/# ifco[ 1690.406717] wlan: mlan0 START SCAN ^C
- root@ok3572-buildroot:/# [ 1695.704235] wlan: SCAN COMPLETED: scanned AP count=17
- [ 1695.707232] wlan: HostMlme mlan0 send auth to bssid 30:XX:XX:XX:7b:80
- [ 1696.755221] mlan0:
- [ 1696.755235] wlan: HostMlme Auth received from 30:XX:XX:XX:7b:80
- ^C[ 1697.761818] wlan:MLAN_EVENT_ASSOC_FAILURE
- [ 1697.761866] ASSOC_RESP: Association Failed, status code = 1, error = 0xfffc, a_id = 0xffff
- [ 1697.761881] IOCTL failed: 00000000f1f319d2 id=0x20000, sub_id=0x20001 action=1, status_code=0xfffc0001 [???]
- [ 1697.761915] HostMlme mlan0: bss_start Fails
- [ 1697.761945] wlan: HostMlme mlan0 Failed to connect to bssid 30:XX:XX:XX:7b:80</font></span>
复制代码
貌似是AP响应超时的问题,请问是否是板子驱动在处理5GHz频段的时候存在问题?
