查看: 53|回复: 2
[Linux] A40i烧录报错WARNING:Please contact Forlinx
A40i\T3\T507\T527通行证
15633162026 发表于 昨天 14:40 | 显示全部楼层 |阅读模式
[13:22:01.575]收←◆\0
[13:22:12.197]收←◆[     0.0]set pll start
[     0.3]set pll end
[     0.5]beign to init dram
[     0.7]DRAMC IS FOUR
[     0.10]DRAM BOOT DRIVE INFO: V1.1
[     0.13]Found A40
[     0.15]Found A40
[     0.17]Found A40
[     0.19]Found A40
[     0.21]Found A40
[     0.27]PMU: [     0.28]AXP221
[     0.30]ddr voltage = 1250 mv
[     0.37]PMU: [     0.38]AXP221
[     0.40]ddr voltage = 1250 mv
[     0.51]PMU: [     0.52]AXP221
[     0.54]ddr voltage = 1500 mv
[     0.64]DRAM CLK =576 MHZ
[     0.67]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[     0.72]DRAM zq value: 0x003b3bfb
[     0.78]DRAM SIZE =1024 M
[     0.81]DRAM ** test OK.
[     0.84]init dram ok
[13:22:16.317]收←◆
U-Boot 2014.07 (Dec 01 2025 - 13:45:14) Allwinner Technology
uboot commit : f2975d643127519ba9bb893438d12684ed860612
i2c_init: by cpux
i2c_init ok
[      4.133]pmbus:   ready
[      4.153]PMU: AXP221
[      4.153]PMU: AXP22x found
[      4.157]PMU: dcdc2 1160
[      4.157]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz  MBus=400Mhz
set power on vol to default
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1160, onoff=1
dcdc3_vol = 1200, onoff=1
dcdc4_vol = 1100, onoff=0
aldo1_vol = 3300, onoff=1
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dc1sw_vol = 3000, onoff=0
dc5ldo_vol = 1100, onoff=0
dldo1_vol = 3300, onoff=1
dldo2_vol = 3300, onoff=0
dldo3_vol = 3300, onoff=0
dldo4_vol = 2500, onoff=1
eldo1_vol = 2800, onoff=0
eldo2_vol = 1200, onoff=1
eldo3_vol = 2800, onoff=1
gpio0_vol = 3300, onoff=1
gpio1_vol = 3300, onoff=1
find power_sply to end
vbus exist
DRAM:  512 MiB
fdt addr: 0x56e80878
Relocation Offset is: 15ed8000
[13:22:16.480]收←◆In:    serial
Out:   serial
Err:   serial
gic: normal mode
workmode = 16,storage type = 0
[      4.289]NAND_UbootProbe start
[      4.292]NB1 : enter phy init
[      4.295]nand_physic_init
[13:22:16.609]收←◆[      4.413]Reset NDFC start 0  0
[      4.413]Reset NDFC end 0  0
[      4.414]nand not support! channel 0 chip 0: ff ff ff ff ff ff ff ff
[      4.420]nand not support! channel 0 chip 1: ff ff ff ff ff ff ff ff
[      4.426]nand not support! channel 0 chip 2: ff ff ff ff ff ff ff ff
[      4.433]nand not support! channel 0 chip 3: ff ff ff ff ff ff ff ff
[      4.439] no nand found !
[      4.442]nand_physic_init nand_build_nsi error
[      4.446]nand_physic_init error -1
[      4.450]NB1 : nand phy init fail
[      4.453]NB1 : enter phy Exit
[      4.456]nand_physic_exit
[      4.459]NAND_UbootProbe end: 0xffffffff
try nand fail
try nand fail
try card 2
楼主| 15633162026 发表于 昨天 14:43 | 显示全部楼层
您好!我看论坛帖子 https://bbs.forlinx.com/forum.php?mod=viewthread&tid=128217&highlight=%E7%83%A7%E5%BD%95 中提到了加密方式。我想确认下烧录过程中,uboot有加密认证机制吗?我现在无法烧录,是因为使用自研硬件,加密认证失败吗?
Forlinx-Chenk 发表于 昨天 15:02 | 显示全部楼层
是的,uboot中有加密,飞凌的sdk只能在飞凌的核心板上使用
