查看: 3935|回复: 1
怎样裸机调试串口,能通过那个仅有USB转接调试吗
10
iiio051031448 发表于 2012-3-12 12:04:26 | 显示全部楼层 |阅读模式
我想用J-link裸机调试下串口,请问怎么配置。
那个仅有口能调试,
楼主| iiio051031448 发表于 2012-3-12 12:39:41 | 显示全部楼层
;代码============================
;init.S============================
        IMPORT main
        AREA Init, CODE, READONLY
        ENTRY
start
        bl main
       end
//*main.c===========================
/* xmain.c */
/* GPIO registers */
#define        GPACON                                (*(volatile unsigned long *)0x7F008000)
#define        GPADAT                                (*(volatile unsigned long *)0x7F008004)
#define        GPAUP                                (*(volatile unsigned long *)0x7F008008)
/*UART registers*/
#define        ULCON0                                (*(volatile unsigned long *)0x7F005000)
#define        UCON0                                (*(volatile unsigned long *)0x7F005004)
#define        UFCON0                                 (*(volatile unsigned long *)0x7F005008)
#define        UMCON0                                (*(volatile unsigned long *)0x7F00500c)
#define        UTRSTAT0                        (*(volatile unsigned long *)0x7F005010)
#define        UTXH0                                 (*(volatile unsigned char *)0x7F005020)
#define        URXH0                                 (*(volatile unsigned char *)0x7F005024)
#define        UBRDIV0                                (*(volatile unsigned long *)0x7F005028)
#define        TXD0READY        (1<<2)  //发送数据状态OK
#define        RXD0READY        (1)                //接收数据状态OK
/* UART串口初始化 */
void uart_init( )
        GPACON |= 0x1111;                //GPH2,GPH3 used as TXD0,RXD0
        GPAUP        = 0xaa;                        //GPH2,GPH3内部上拉
        ULCON0        = 0x03;        //8位数据位,无校验,普通模式,一位停止位
        UCON0        = 0x05;        //查询方式为轮询或中断;时钟选择为PCLK
        UFCON0         = 0x00;                //不使用FIFO
        UMCON0         = 0x00;                //不使用流控
        UBRDIV0 = 36;                //波特率为57600,PCLK=12Mhz
/* UART串口单个字符打印函数 */
extern void putc(unsigned char c)
        //while( ! (UTRSTAT0 & TXD0READY) );
        UTXH0 = c;
/* UART串口接受单个字符函数 */
extern unsigned char getc(void)
        //while( ! (UTRSTAT0 & RXD0READY) );
        return URXH0;
/* UART串口字符串打印函数 */
extern int printk(const char* str)
        int i = 0;
        while( str[i] ){
                putc( (unsigned char) str[i++] );
        return i;
__inline void delay(int msec)
        int i, j;
        for(i = 1000; i > 0; i--)
                for(j = msec*10; j > 0; j--)
                        /* do nothing */;
/* xmain 通过UART串口打印字符串 */
void main(void)
        uart_init();
        while(1)
            //delay(10);
            printk("Uart串口打印试验\r\n");
