查看: 9138|回复: 17
3G无线网卡拨号上网问题
14
zbj20082003 发表于 2012-4-6 11:34:58 | 显示全部楼层 |阅读模式
我使用的3g无线网卡为ZTE:AC2726  CDMA2000,使用3GDialup拨号
拨号的提示信息:
Start connect CDMA2000, please wait......
* usb_modeswitch: handle USB devices with multiple modes
* Version 1.1.6 (C) Josua Dietze 2010
* Based on libusb0 (0.1.12 and above)
! PLEASE REPORT NEW CONFIGURATIONS !
DefaultVendor=  0x19d2
DefaultProduct= 0xfff5
TargetVendor=   0x19d2
TargetProduct=  not set
TargetClass=    not set
TargetProductList="fff1,ffff"
DetachStorageOnly=0
HuaweiMode=0
SierraMode=0
SonyMode=0
GCTMode=0
KobilMode=0
MessageEndpoint=  not set
MessageContent="5553424312345678c00000008000069f030000000000000000000000000000"
NeedResponse=0
ResponseEndpoint= not set
Interface=0x00
InquireDevice enabled (default)
Success check enabled, max. wait time 20 seconds
System integration mode disabled
Looking for target devices ...
  searching devices, found USB ID 1d6b:0002
  searching devices, found USB ID 19d2:fff5
   found matching vendor ID
  searching devices, found USB ID 1d6b:0001
No devices in target mode or class found
Looking for default devices ...
   found matching product ID
   adding device
Found devices in default mode, class or configuration (1)
Accessing device 002 on bus 001 ...
Getting the current device configuration ...
OK, got current device configuration (1)
Using endpoints 0x0a (out) and 0x89 (in)
Inquiring device details; driver will be detached ...
Looking for active driver ...
OK, driver found ("usb-storage")
OK, driver "usb-storage" detached
SCSI inquiry data (for identification)
  Vendor String: ZTE
   Model String: USB Storage FFF1
Revision String: 2.31
USB description data (for identification)
Manufacturer: ZTE, Incorporated
     Product: USB Storage
  Serial No.: 000000000002
Setting up communication with interface 0 ...
Using endpoint 0x0a for message sending ...
Trying to send message 1 to endpoint 0x0a ...
OK, message successfully sent
Resetting response endpoint 0x89
Error resetting endpoint: -62
Resetting message endpoint 0x0a
Error resetting endpoint: -19
Device is gone, skipping any further commands
Checking for mode switch (max. 20 times, once per second) ...
Searching for target devices ...
  searching devices, found USB ID 19d2:fff1
   found matching product ID from list
Found target device, now opening
Found target device 003 on bus 001
Target device description data
     Product: ZTE CDMA Tech
  Serial No.: not provided
Found correct target device
Mode switch succeeded. Bye.
abort on (NO CARRIER)
abort on (ERROR)
abort on (NO DIALTONE)
abort on (BUSY)
abort on (NO ANSWER)
send (AT^M)
expect (OK)
AT^M^M
OK
楼主| zbj20082003 发表于 2012-4-6 11:38:06 | 显示全部楼层
拨号的提示信息:
DetachStorageOnly=0
HuaweiMode=0
SierraMode=0
SonyMode=0
GCTMode=0
KobilMode=0
NeedResponse=0
Interface=0x00
   adding device
  Vendor String: ZTE
14
楼主| zbj20082003 发表于 2012-4-6 11:41:56 | 显示全部楼层
怎么发送不完呢?分批发吧
14
楼主| zbj20082003 发表于 2012-4-6 11:43:28 | 显示全部楼层
拨号的提示信息:
DetachStorageOnly=0
HuaweiMode=0
SierraMode=0
SonyMode=0
GCTMode=0
KobilMode=0
NeedResponse=0
Interface=0x00
14
楼主| zbj20082003 发表于 2012-4-6 11:44:06 | 显示全部楼层
   adding device
14
楼主| zbj20082003 发表于 2012-4-6 11:44:37 | 显示全部楼层
  Vendor String: ZTE
14
楼主| zbj20082003 发表于 2012-4-6 11:45:40 | 显示全部楼层
abort on (ERROR)
abort on (BUSY)
send (AT^M)
expect (OK)
AT^M^M
OK
-- got it
send (ATZ^M)
expect (OK)
^M
ATZ^M^M
OK
-- got it
14
楼主| zbj20082003 发表于 2012-4-6 11:47:25 | 显示全部楼层
send (AT+CFUN=1^M)
expect (OK)
^M
AT+CFUN=1^M^M
OK
-- got it
send (ATDT#777^M)
expect (CONNECT)
^M
ATDT#777^M^M
CONNECT
-- got it
send (^M)
Serial connection established.
Using interface ppp0
Connect: ppp0 <--> /dev/ttyUSB0
PAP authentication succeeded
local  IP address 1.198.224.117
remote IP address 115.168.79.5
primary   DNS address 222.85.85.85
secondary DNS address 222.88.88.88
Modem hangup
Connect time 0.2 minutes.
Sent 0 bytes, received 0 bytes.
Connection terminated.
但是使用ifconfig 提示信息
[root@FORLINX6410]# ifconfig
eth0      Link encap:Ethernet  HWaddr 08:90:90:90:90:90
          inet addr:192.168.1.232  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:9537 errors:0 dropped:113 overruns:0 frame:0
          TX packets:554 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:660144 (644.6 KiB)  TX bytes:55561 (54.2 KiB)
          Interrupt:108 Base address:0xa000
[root@FORLINX6410]#
xp下ping 百度后提示
C:\Documents and Settings\UserName>ping www.baidu.com
Pinging www.a.shifen.com [61.135.169.105] with 32 bytes of data:
Reply from 61.135.169.105: bytes=32 time=793ms TTL=53
Reply from 61.135.169.105: bytes=32 time=634ms TTL=53
Reply from 61.135.169.105: bytes=32 time=607ms TTL=53
Reply from 61.135.169.105: bytes=32 time=803ms TTL=53
Ping statistics for 61.135.169.105:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 607ms, Maximum = 803ms, Average = 709ms
ok6410 下ping 百度ping 不通
[root@FORLINX6410]# ping 61.135.169.105
PING 61.135.169.105 (61.135.169.105): 56 data bytes
^C
--- 61.135.169.105 ping statistics ---
7 packets transmitted, 0 packets received, 100% packet loss
[root@FORLINX6410]#
ok6410 下ping 百度dns  不通
[root@FORLINX6410]# ping 222.88.88.88
PING 222.88.88.88 (222.88.88.88): 56 data bytes
^C
--- 222.88.88.88 ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss
[root@FORLINX6410]# ping 222.85.85.85
PING 222.85.85.85 (222.85.85.85): 56 data bytes
^C
--- 222.85.85.85 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
[root@FORLINX6410]#
不知道为什么,飞凌工程师帮忙给看看。
飞凌-chongzi 发表于 2012-4-6 13:07:40 | 显示全部楼层
ping www.sina.com试试
楼主| zbj20082003 发表于 2012-4-6 15:01:02 | 显示全部楼层
开发板上电后,我就去拨号连接,发现连接通了。ping新浪,百度和DNS服务器都通了。但是没有1分钟,就断线了。不知道为什么。
提示如下
ppp0      Link encap:Point-to-Point Protocol
          inet addr:1.198.138.96  P-t-P:115.168.79.5  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:112 errors:0 dropped:0 overruns:0 frame:0
          TX packets:112 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:9142 (8.9 KiB)  TX bytes:9136 (8.9 KiB)
ping: sendto: Network is unreachable
[root@FORLINX6410]#
