查看: 12463|回复: 13
3G 拨号问题
14
zbj20082003 发表于 2012-4-17 11:58:47 | 显示全部楼层 |阅读模式
环境Linux3.0.1
3G模块ZTE AC2726   电信CDMA2000
1..插上3G模块后,/dev下增加一个usbdev1.1,并没有出现ttyUSB0~ttyUSB4.使用./pppd call cdma2000,提示
[root@FORLINX6410]# pwd
/opt/3G/bin
[root@FORLINX6410]# ./pppd call cdma2000
./pppd: In file /etc/ppp/peers/cdma2000: unrecognized option '/dev/ttyUSB0'
2.应该是驱动没有正常安装。但是运行官方提供的3GDialup后,系统就会提示
[root@FORLINX6410]# usb 1-1: usbfs: process 135 (usb_modeswitch) did not claim i
nterface 0 before use
usb 1-1: USB disconnect, device number 2
usb 1-1: new full speed USB device number 7 using s3c2410-ohci
usb 1-1: New USB device found, idVendor=19d2, idProduct=fff1
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1: Product: ZTE CDMA Tech
usb 1-1: Manufacturer: ZTE, Incorporated
pl2303 1-1:1.0: pl2303 converter detected
usb 1-1: pl2303 converter now attached to ttyUSB0
pl2303 1-1:1.1: pl2303 converter detected
usb 1-1: pl2303 converter now attached to ttyUSB1
pl2303 1-1:1.2: pl2303 converter detected
usb 1-1: pl2303 converter now attached to ttyUSB2
pl2303 1-1:1.3: pl2303 converter detected
usb 1-1: pl2303 converter now attached to ttyUSB3
pl2303 1-1:1.4: pl2303 converter detected
usb 1-1: pl2303 converter now attached to ttyUSB4
scsi1 : usb-storage 1-1:1.5
scsi 1:0:0:0: Direct-Access     ZTE      USB Storage FFF1 2.31 PQ: 0 ANSI: 2
sd 1:0:0:0: Attached scsi generic sg0 type 0
sd 1:0:0:0: [sda] Attached SCSI removable disk
能将usb1.1转换为ttyUSB0~4,而且拨号成功
3.然后在/dev下就有了ttyUSB0~4
4.然后再使用./pppd call cdma2000拨号就能成功。
  第一个问题:不知到3GDialup怎么将usb转换为ttyUSB0~4的?我用手动安装如何实现
  第二个问题:不管是手动连接还是3GDialup,当连接上之后如果ping www.baidu.com都能成功,只要一直ping不停止,连接一直保持,一旦停止ping等等1,2秒,就会断开连接,提示如下
64 bytes from 119.75.218.77: seq=153 ttl=53 time=59.448 ms
64 bytes from 119.75.218.77: seq=154 ttl=53 time=122.508 ms
64 bytes from 119.75.218.77: seq=155 ttl=53 time=77.247 ms
^C
--- www.baidu.com ping statistics ---
156 packets transmitted, 156 packets received, 0% packet loss
round-trip min/avg/max = 59.448/88.407/441.169 ms
[root@FORLINX6410]# Modem hangup
Connect time 3.0 minutes.
Sent 13222 bytes, received 13308 bytes.
Connection terminated.
连接中止了,好像超时了?然后再ifconfig
^C
[1] + Done(16)                   ./pppd call cdma2000
[root@FORLINX6410]# ifconfig
[root@FORLINX6410]#
楼主| zbj20082003 发表于 2012-4-17 15:05:31 | 显示全部楼层
帮忙给看看!打你们电话真难!
14
楼主| zbj20082003 发表于 2012-4-17 15:06:18 | 显示全部楼层
另外我想用代码实现拨号,并且返回获得的IP地址,应该怎么做?
14
楼主| zbj20082003 发表于 2012-4-17 15:50:18 | 显示全部楼层
第一个问题解决了,通过分析官方的3GDiaup代码发现,其执行了一个命令./usb_modeswitch -c usb_modeswitch.d/19d2^%fff5 -W 实现了USB到串口的处理。
14
楼主| zbj20082003 发表于 2012-4-17 16:07:14 | 显示全部楼层
明白了
14
楼主| zbj20082003 发表于 2012-4-17 16:13:25 | 显示全部楼层
通过分析官方3GDialog代码发现,其实就是执行了两条命令
1.首先通过读取/sys/bus/usb/devices/1-1/idVendor和/sys/bus/usb/devices/1-1/idProduct获得设备Vid和Pid
2.然后执行./usb_modeswitch -c usb_modeswitch.d/19d2^%fff5 -W命令(其中19d2为Vid和fff5为Pid)实现usb串口的映射
3.然后执行/opt/3G/bin/pppd call cdma2000实现拨号
4.其中状态框中的内容就是从终端上读出的内容放到了文本框中(不知道这句话对不对)
14
楼主| zbj20082003 发表于 2012-4-17 16:18:47 | 显示全部楼层
就剩下最后一个问题了,网络拨通之后不和某个Server保持连接,自动就会断开。如果一直ping 某个server也不会断,一旦停止ping ,停几秒就断。提示如次:
PAP authentication succeeded
local  IP address 1.198.20.80
remote IP address 115.168.79.5
primary   DNS address 222.85.85.85
secondary DNS address 222.88.88.88
[root@FORLINX6410]# ping www.baidu.com
PING www.baidu.com (220.181.111.147): 56 data bytes
64 bytes from 220.181.111.147: seq=0 ttl=53 time=73.823 ms
64 bytes from 220.181.111.147: seq=1 ttl=53 time=79.310 ms
^C
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 73.823/76.566/79.310 ms
Connect time 0.5 minutes.
Sent 286 bytes, received 356 bytes.
mary 该用户已被删除
mary 发表于 2012-4-17 17:23:33 | 显示全部楼层
蓟州侯 该用户已被删除
蓟州侯 发表于 2012-4-18 08:59:45 | 显示全部楼层
pmcf1988 该用户已被删除
pmcf1988 发表于 2012-8-13 13:39:14 | 显示全部楼层
