查看: 6196|回复: 4
linux3.0.1 烧写出现 cannot get bus
i.MX6UL通行证i.MX6Q通行证XX18通行证
swet123 发表于 2012-4-18 09:50:29 | 显示全部楼层 |阅读模式
大家好, 今天我在尝试烧写linux3.0.1内核到OK6410的时候发生了一些错误:
1.  用飞凌原版的内核出现如下错误:
      内      核:   OK6410官方基础资料-2G\Linux-3.0.1\demo\zImage
      文件系统:   FORLINX_6410_touch_nand2g.yaffs2
      OK6410:    256M sdram 2G NandFlash
      烧写方式:   SD卡一键烧写
烧写成功后,转到nand启动:出现如下错误(红色部分)usbcore: registered new interface driver zc3xx
zc3xx: registered
usbcore: registered new interface driver ALi m5602
ALi m5602: registered
usb 1-1: new low speed USB device number 2 using s3c2410-ohci
usbcore: registered new interface driver STV06xx
STV06xx: registered
gspca_gl860: driver startup - version 0.9d10
usbcore: registered new interface driver gspca_gl860
gspca_gl860: driver registered
s3c-fimc: controller 0 registered successfully
s3c-fimc: controller 1 registered successfully
s3c-fimc: info ov965x_init
usb 1-1: New USB device found, idVendor=2188, idProduct=0ae1
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product:  USB OPTICAL MOUSE
s3c-i2c s3c2440-i2c.0: cannot get bus (error -110)
上述红色字体会一直出现,大概有30分钟左右的时候,才进入系统。
我看了看,大概是ov965x_init 这个驱动的原因, 所以我自己又编译了一遍linux3.0.1,
交叉编译链为:4.3.2
在内核中将  [ ]   Video capture adapters  --->     项去掉。
烧写该内核到板子,文件系统使用FORLINX_6410_touch_nand2g.yaffs2
烧写完毕后,运行出现另一个错误:
s3c2410_rtc: tick irq 34, alarm irq 92
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 377 KHz
[OV965X]ov965x_attach_adapter.
usb 1-1: new low speed USB device using s3c2410-ohci and address 2
usb 1-1: configuration #1 chosen from 1 choice
s3c2440-i2c s3c2440-i2c: cannot get bus (error -110)
[CAM]s3c_fimc_register_camera,cam->id=0
parent clock for camera: 266.000 MHz, divisor: 11
[CAM]RESET CAM.[CAM]Reset and init reg!1cam->client=0
[CAM]Reset and init reg!3
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (44333333 Hz)
sdhci: card inserted.
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (44333333 Hz)
input:  USB OPTICAL MOUSE as /class/input/input2
generic-usb 0003:2188:0AE1.0001: input: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-s3c24xx-1/input0
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18rc3.
ASoC version 0.13.2
WM9713/WM9714 SoC Audio Codec 0.15
playback: 1, capture : 1
asoc: AC97 HiFi <-> s3c64xx-ac97 mapping ok
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.63 GiB
mmcblk0: p1
[WM9713]Open speaker volume.
ALSA device list:
  #0: SMDK6400 (WM9713)
TCP cubic registered
can: controller area network core (rev 20081130 abi 8)
can: raw protocol (rev 20081130)
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
s3c2410-rtc s3c2410-rtc: setting system clock to 2000-01-01 02:55:02 UTC (946695302)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
block 61 is bad
block 62 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs2 filesystem).
Freeing init memory: 144K
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
楼主| swet123 发表于 2012-4-23 14:25:31 | 显示全部楼层
;Pasd asd asd
25
飞凌-fatfish 发表于 2012-4-23 16:27:15 | 显示全部楼层
建议把开发板的型号、nandflash型号、烧写文件的来源(比如来源于光盘)、操作的步骤、以及所有打印的串口信息(这个很重要)写出来。如果有特殊情况,也可以在附件中添加截图。
mrliming 该用户已被删除
mrliming 发表于 2012-11-5 18:37:58 | 显示全部楼层
千叶梦幻 该用户已被删除
千叶梦幻 发表于 2013-4-14 15:39:30 | 显示全部楼层
