查看: 13101|回复: 8
版主进来看看 我编译qtopia-free-2.2.0出的错误 collect2: ld returned 1 exit sta...
ljc710871968 发表于 2012-10-30 21:33:11 | 显示全部楼层 |阅读模式
  1. make[5]: 正在进入目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/applications/todo'
  2. make[6]: 正在进入目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/applications/todo'
  3. make[6]: 没有什么可以做的为 `all'。
  4. make[6]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/applications/todo'
  5. make[5]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/applications/todo'
  6. cd games/fifteen && make -f Makefile
  7. make[5]: 正在进入目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/games/fifteen'
  8. make[6]: 正在进入目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/games/fifteen'
  9. arm-linux-g++ -o fifteen .obj/release-shared/fifteen.o .obj/release-shared/main.o .obj/release-shared/moc_fifteen.o -luuid -lqtopia2 -lqtopia -lqpe -L/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/lib -L/usr/local/arm/yizhi/qtopia-free-2.2.0/qt2/lib -lqte
  10. /usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/lib/libqpe.so: undefined reference to `qpe_setBrightness(int)'
  11. /usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/lib/libqpe.so: undefined reference to `PowerStatusManager::getStatus()'
  12. collect2: ld returned 1 exit status
  13. make[6]: *** [fifteen] 错误 1
  14. make[6]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/games/fifteen'
  15. make[5]: *** [all] 错误 2
  16. make[5]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src/games/fifteen'
  17. make[4]: *** [sub-games-fifteen] 错误 2
  18. make[4]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src'
  19. make[3]: *** [sub-src-components_pro] 错误 2
  20. make[3]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src'
  21. make[2]: *** [all] 错误 2
  22. make[2]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/src'
  23. make[1]: *** [all] 错误 2
  24. make[1]:正在离开目录 `/usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia'
  25. ***********************************************************************
  26. *
  27. * ERROR: Building Qtopia has failed.
  28. *
  29. * Please search the make output for any error messages.
  30. *
  31. * Hint: If the configuration has changed since the last successfull
  32. * build consider using make clean to ensure that all binaries
  33. * are rebuilt using the new configuration.
  34. *
  35. * For more information about the build process please use a browser
  36. * and go to the getting started section in:
  37. * /usr/local/arm/yizhi/qtopia-free-2.2.0/qtopia/doc/html/index.html
  38. *
  39. ***********************************************************************
复制代码
楼主| ljc710871968 发表于 2012-10-30 21:34:28 | 显示全部楼层
求大神们看看怎么回事。该做的我都做了。库和文件都移植过去了。
楼主| ljc710871968 发表于 2012-10-31 07:57:34 | 显示全部楼层
:'( 有遇到相同问题的吗
楼主可以帮帮我嘛???  详情 回复 发表于 2019-5-25 23:14
有,请问楼主解决了吗??  详情 回复 发表于 2019-5-25 23:12
飞凌-unix 发表于 2012-10-31 08:45:33 | 显示全部楼层
建议你去检查下你的qt安装有没有问题,权限
楼主| ljc710871968 发表于 2012-10-31 14:52:58 | 显示全部楼层
是qt软件吗??
飞凌-unix 发表于 2012-10-31 16:55:46 | 显示全部楼层
对
飞凌-unix 发表于 2012-10-31 16:56:00 | 显示全部楼层
看看qt的环境设置有没有问题
ppwjs 发表于 2019-5-25 23:12:45 | 显示全部楼层
**** 作者被禁止或删除 内容自动屏蔽 ****
有,请问楼主解决了吗??
ppwjs 发表于 2019-5-25 23:14:56 | 显示全部楼层
楼主可以帮帮我嘛???
