查看: 6486|回复: 0
求助移植Linux3.3.5挂载NFS卡住
zwmasdf 发表于 2012-11-26 15:09:28 | 显示全部楼层 |阅读模式
Booting Linux on physical CPU 0
Linux version 3.3.5 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #5 Wed Nov 21 15:56:24 CST 2012
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OK6410
CPU S3C6410 (id 0x36410101)
CPU: found DTCM0 8k @ 00000000, not enabled
CPU: moved DTCM0 8k to fffe8000, enabled
CPU: found DTCM1 8k @ 00000000, not enabled
CPU: moved DTCM1 8k to fffea000, enabled
CPU: found ITCM0 8k @ 00000000, not enabled
CPU: moved ITCM0 8k to fffe0000, enabled
CPU: found ITCM1 8k @ 00000000, not enabled
CPU: moved ITCM1 8k to fffe2000, enabled
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: root=/dev/nfs nfsroot=192.168.1.105:/home/zwm/rootfs ip=192.168.1.110:::::eth0 console=ttySAC0,115200
Memory: 256MB = 256MB total
Memory: 255320k/255320k available, 6824k reserved, 0K highmem
Virtual kernel memory layout:
    DTCM    : 0xfffe8000 - 0xfffec000   (  16 kB)
    ITCM    : 0xfffe0000 - 0xfffe4000   (  16 kB)
    vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc03dee30   (3932 kB)
      .init : 0xc03df000 - 0xc03fd000   ( 120 kB)
      .data : 0xc03fe000 - 0xc042ce20   ( 188 kB)
       .bss : 0xc042d024 - 0xc0467a78   ( 235 kB)
NR_IRQS:246
VIC @f6000000: id 0x00041192, vendor 0x41
VIC @f6010000: id 0x00041192, vendor 0x41
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
Setting up static identity map for 0x502ee298 - 0x502ee2f4
gpiochip_add: registered GPIOs 38 to 53 on device: GPF
gpiochip_add: registered GPIOs 74 to 89 on device: GPI
gpiochip_add: registered GPIOs 91 to 102 on device: GPJ
gpiochip_add: registered GPIOs 161 to 176 on device: GPO
gpiochip_add: registered GPIOs 178 to 192 on device: GPP
gpiochip_add: registered GPIOs 194 to 202 on device: GPQ
gpiochip_add: registered GPIOs 144 to 159 on device: GPN
gpiochip_add: registered GPIOs 0 to 7 on device: GPA
gpiochip_add: registered GPIOs 9 to 15 on device: GPB
gpiochip_add: registered GPIOs 17 to 24 on device: GPC
gpiochip_add: registered GPIOs 26 to 30 on device: GPD
gpiochip_add: registered GPIOs 32 to 36 on device: GPE
gpiochip_add: registered GPIOs 55 to 61 on device: GPG
gpiochip_add: registered GPIOs 137 to 142 on device: GPM
gpiochip_add: registered GPIOs 63 to 72 on device: GPH
gpiochip_add: registered GPIOs 104 to 119 on device: GPK
gpiochip_add: registered GPIOs 121 to 135 on device: GPL
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
s3c-i2c s3c2440-i2c.1: slave address 0x10
s3c-i2c s3c2440-i2c.1: bus frequency set to 64 KHz
s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP reno registered
UDP hash table entries: 128 (order: 0, 6144 bytes)
UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
ROMFS MTD (C) 2007 Red Hat, Inc.
io scheduler noop registered
start plist test
end plist test
s3c-fb s3c-fb: window 0: fb
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 69) is a S3C6400/10
console [ttySAC0] enabled
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 70) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 71) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 72) is a S3C6400/10
brd: module loaded
loop: module loaded
at24 0-0050: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
at24 1-0057: 16384 byte 24c128 EEPROM, writable, 1 bytes/write
s3c2410-ohci s3c2410-ohci: init err (00000000 0000)
ohci_hcd: can't start s3c24xx
s3c2410-ohci s3c2410-ohci: startup error -75
s3c2410-ohci s3c2410-ohci: USB bus 1 deregistered
s3c2410-ohci: probe of s3c2410-ohci failed with error -75
i2c /dev entries driver
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 15
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 00:04:35 UTC (946685075)
然后就卡住了  这是怎么回事
