- 3
贡献31
飞刀0 FD
注册时间2018-10-23
在线时间0 小时
Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
Memory: 256MB = 256MB total
Memory: 206816k/206816k available, 55328k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xf4000000 ( 568 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0033000 ( 172 kB)
.text : 0xc0033000 - 0xc0707580 (6994 kB)
.data : 0xc0708000 - 0xc0748bc8 ( 259 kB)
.bss : 0xc0748bec - 0xc07c6508 ( 503 kB)
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
Advanced Linux Sound Architecture Driver Version 1.0.24.
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP reno registered
audit: initializing netlink socket (disabled)
type=2000 audit(0.270:1): initialized
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
msgmni has been set to 403
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
fb1: s3cfb frame buffer device
fb2: s3cfb frame buffer device
fb3: s3cfb frame buffer device
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
vcan: Virtual CAN inte**ce driver
slcan: serial line CAN inte**ce driver
slcan: 10 dynamic inte**ce channels.
CAN device driver inte**ce
mcp251x: setup gpio pins CS and External Int
mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset
mcp2515 spi1.0: Probe failed
mcp2515 spi1.0: probe failed
PPP MPPE Compression module registered
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at d081a000,d0c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new inte**ce driver rt73usb
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 3.0.1 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new inte**ce driver usb-storage
usbcore: registered new inte**ce driver usbserial
usbcore: registered new inte**ce driver pl2303
dummy_hcd dummy_hcd: USB Host+Gadget Emulator, driver 02 May 2005
dummy_hcd dummy_hcd: Dummy host controller
dummy_hcd dummy_hcd: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Dummy host controller
usb usb2: Manufacturer: Linux 3.0.1 dummy_hcd
usb usb2: SerialNumber: dummy_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: s3c-keypad as /devices/virtual/input/input1
S3C Keypad Driver
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /devices/virtual/input/input2
i2c /dev entries driver
Linux video capture inte**ce: v2.00
(不好意思,打印信息还没完) |
