修改LCD数据位
楼主| weiyanan11 发表于 2012-12-24 11:25:43 | 显示全部楼层
S3cfb.h中添加
#define S3CFB_PIXEL_BPP_18      18      /*  RGB 6-6-6 format for SMDK EVAL BOARD */
const static s3cfb_rgb_t s3cfb_rgb_18 = {
        .red    = {.offset = 12, .length = 6,},
        .green  = {.offset = 6,  .length = 6,},
        .blue   = {.offset = 0,  .length = 6,},
        .transp = {.offset = 0,  .length = 0,},
s3cfb_fimd4x.c中修改
s3cfb_fimd_info_t s3cfb_fimd = {
        .vidcon0 = S3C_VIDCON0_INTERLACE_F_PROGRESSIVE | S3C_VIDCON0_VIDOUT_RGB_IF | S3C_VIDCON0_L1_DATA16_SUB_18_MODE | \
                        S3C_VIDCON0_L0_DATA16_MAIN_18_MODE | S3C_VIDCON0_PNRMODE_RGB_P | \
                        S3C_VIDCON0_CLKVALUP_ALWAYS | S3C_VIDCON0_CLKDIR_DIVIDED | S3C_VIDCON0_CLKSEL_F_HCLK | \
                        S3C_VIDCON0_ENVID_DISABLE | S3C_VIDCON0_ENVID_F_DISABLE,
        .dithmode = (S3C_DITHMODE_RDITHPOS_6BIT | S3C_DITHMODE_GDITHPOS_6BIT | S3C_DITHMODE_BDITHPOS_6BIT ) & S3C_DITHMODE_DITHERING_DISABLE,
#if defined (CONFIG_FB_S3C_EXT_BPP_8)
        .wincon0 =  S3C_WINCONx_BYTSWP_ENABLE | S3C_WINCONx_BURSTLEN_4WORD | S3C_WINCONx_BPPMODE_F_8BPP_PAL,
        .wincon1 =  S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_4WORD | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1,
        .bpp = S3CFB_PIXEL_BPP_8,
        .bytes_per_pixel = 1,
        .wpalcon = S3C_WPALCON_W0PAL_16BIT,
#elif defined (CONFIG_FB_S3C_EXT_BPP_16)
        .wincon0 =  S3C_WINCONx_ENLOCAL_DMA | S3C_WINCONx_BUFSEL_1 | S3C_WINCONx_BUFAUTOEN_DISABLE | \
                        S3C_WINCONx_BITSWP_DISABLE | S3C_WINCONx_BYTSWP_DISABLE | S3C_WINCONx_HAWSWP_ENABLE | \
                        S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_ENWIN_F_DISABLE,
        .wincon1 =  S3C_WINCONx_ENLOCAL_DMA | S3C_WINCONx_BUFSEL_0 | S3C_WINCONx_BUFAUTOEN_DISABLE | \
                        S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_BPPMODE_F_16BPP_565 | \
                        S3C_WINCONx_ALPHA_SEL_1 | S3C_WINCONx_ENWIN_F_DISABLE,
        .wincon2 = S3C_WINCONx_ENLOCAL_DMA | S3C_WINCONx_BITSWP_DISABLE | S3C_WINCONx_BYTSWP_DISABLE | \
                        S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_4WORD | S3C_WINCONx_BURSTLEN_16WORD | \
                        S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_ALPHA_SEL_1 | S3C_WINCONx_ENWIN_F_DISABLE,
        .wincon3 = S3C_WINCONx_BITSWP_DISABLE | S3C_WINCONx_BYTSWP_DISABLE | S3C_WINCONx_HAWSWP_ENABLE | \
                        S3C_WINCONx_BURSTLEN_4WORD | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BLD_PIX_PLANE | \
        .wincon4 = S3C_WINCONx_BITSWP_DISABLE | S3C_WINCONx_BYTSWP_DISABLE | S3C_WINCONx_HAWSWP_ENABLE | \
        .bpp = S3CFB_PIXEL_BPP_16,
        .bytes_per_pixel = 2,
#elif defined (CONFIG_FB_S3C_EXT_BPP_18)
                        S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_18BPP_666 | S3C_WINCONx_ENWIN_F_DISABLE,
                        S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_BPPMODE_F_18BPP_666 | \
                        S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_BPPMODE_F_18BPP_666 | S3C_WINCONx_ALPHA_SEL_1 | S3C_WINCONx_ENWIN_F_DISABLE,
        .bpp = S3CFB_PIXEL_BPP_18,
        .bytes_per_pixel = 4,
        .wpalcon = S3C_WPALCON_W0PAL_18BIT,
void s3cfb_activate_var(s3cfb_info_t *fbi, struct fb_var_screeninfo *var)
        DPRINTK("%s: var->bpp = %d\n", __FUNCTION__, var->bits_per_pixel);
        switch (var->bits_per_pixel) {
        case 8:
                s3cfb_fimd.wincon0 = S3C_WINCONx_BYTSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_8BPP_PAL;
                s3cfb_fimd.wincon1 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.wincon2 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.wincon3 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.wincon4 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_16BPP_565 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.bpp = S3CFB_PIXEL_BPP_8;
                s3cfb_fimd.bytes_per_pixel = 1;
                s3cfb_fimd.wpalcon = S3C_WPALCON_W0PAL_16BIT;
                break;
        case 16:
                s3cfb_fimd.wincon0 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_16BPP_565;
                s3cfb_fimd.bpp = S3CFB_PIXEL_BPP_16;
                s3cfb_fimd.bytes_per_pixel = 2;
                break;
        case 18:
                s3cfb_fimd.wincon0 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_18BPP_666;
                s3cfb_fimd.wincon1 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_18BPP_666 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.wincon2 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_18BPP_666 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.wincon3 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_18BPP_666 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.wincon4 = S3C_WINCONx_HAWSWP_ENABLE | S3C_WINCONx_BURSTLEN_16WORD | S3C_WINCONx_BPPMODE_F_18BPP_666 | S3C_WINCONx_BLD_PIX_PLANE | S3C_WINCONx_ALPHA_SEL_1;
                s3cfb_fimd.bpp = S3CFB_PIXEL_BPP_18;
                s3cfb_fimd.bytes_per_pixel = 4;
                break;
楼主| weiyanan11 发表于 2012-12-24 11:26:02 | 显示全部楼层
s3cfb_fimd5x.c中修改
        case 8:
                break;
        case 16:
                break;
        case 18:
                break;
楼主| weiyanan11 发表于 2012-12-24 14:52:33 | 显示全部楼层
更改数据位需要修改uboot吗
kevinataz 该用户已被删除
kevinataz 发表于 2013-1-5 11:28:47 | 显示全部楼层
