查看: 10999|回复: 3
菜鸟下载运行第一个裸板程序跑马灯led出错,求指点
albert4278 发表于 2010-10-26 15:44:25 | 显示全部楼层 |阅读模式
向2440里面烧写裸板程序,led灯轮流点亮的那个,使用AXD做为编译环境。没有用它作为load image和debug工具,我暂时还没有JTAG.
源码参见“开发板配套教程”里面的2.8.2 使用ADS创建工程中的例子,init.s,main.c
几个参数都详细对照过了,比如ROBASE=0X32000000 IMAGE ENTRY=0X32000000等。
dnw的usb下载地址为0x30800000
编译跑马灯程序后生成image文件 2440led.bin。
启动板子,选择menu下的[1]download to flash,进入子菜单:
选择 3  offset .......[my app]
再按照要求的usb port->transmit 选择要烧写的bin文件2440led.bin
界面提示下载成功。进入selectmenu
然后我选择3 boot my app
打印如下,最后启动不起来,进入了linux kernel
| [0] Download & Run                                         |
| [1] Download to flash                                      |
| [2] Download From UART                                     |
| [3] Boot My Application                                    |
| [4] Boot Linux                                             |
| [5] Boot Wince                                             |
| [6] Erase Flash Partition                                  |
| [7] Config parameters                                      |
NAND ID is 0xecda
Please select which region to write : Esc to abort
0 : offset 0x00000000, size 0x00020000 [boot]
1 : offset 0x00020000, size 0x00060000 [bootParam]
2 : offset 0x00080000, size 0x00100000 [pic]
3 : offset 0x00180000, size 0x00380000 [MyApp]
4 : offset 0x00500000, size 0x00300000 [kernel]
5 : offset 0x00800000, size 0x03c00000 [fs_yaffs]
6 : offset 0x04400000, size 0x00080000 [eboot]
7 : offset 0x04480000, size 0x03b80000 [wince]
Now download and write nand flash part [ MyApp ]
press [USB Port-->transmit] to choose the file
Now, Downloading [ADDRESS:30800000h,TOTAL:478]
RECEIVED FILE SIZE:     478
( 72.3KB/S,0.0S)
Now, Checksum calculation
Download O.K.
Now write nand flash page 0x300 from ram address 0x30800000, filesize = 478
.Program nand flash partition success
|                     Select Menu                            |
| [4] Boot Linux                                             |
| [5] Boot Wince                                             |
NAND ID is 0xecda
Memory Test(30200000h-33ff0000h):O.K.
Load Application...
run 0x32000000...
NAND ID is 0xecda
Set boot params = root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320
Load Kernel...
Uncompressing Linux................................................................................................................. done, booting the kernel.
Linux version 2.6.12-h1940 (root@localhost.localdomain) (gcc version 3.4.1) #428 Fri Jan 29 16:49:06 CST 2010
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Machine: SMDK2410
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
S3C2440: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
Built 1 zonelists
Kernel command line: root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320
irq: clearing pending ext status 000d0000
irq: clearing subpending status 00000093
irq: clearing subpending status 00000092
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00500d00, tcnt a2c1, tcfg 0000020f,00000030, usec 00001eb8
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 60800KB available (2936K code, 920K data, 112K init)
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 96.000 MHz
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Bluetooth: Core ver 2.7
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
NTFS driver 2.1.22 [Flags: R/W].
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Nov  4 2008 17:54:45 Installing.
Initializing Cryptographic API
--- s3c2410fb init ---!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pxafb_probe start!!!!!!!!!!!!!!!!!!!!!!!!!!
VA=0xc4880000, PA=0x305c0000, size=0x00027000
Console: switching to colour frame buffer device 40x15
success to register framebuffer device: 0!!!
enable_irq(32) unbalanced from c001729c
done probe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
fb1: Virtual frame buffer device, using 1024K of video memory
in s3c2410ts init()
success get major number!!!!!!
s3c2410-ts device driver MAJOR:253
success to get adc clock source!
base_addr = 0xc4860000
line 543 passed!
register s3c2410-ts driver success, return code is 0
S3C2410 RTC, (c) 2004 Simtec Electronics
我是新手,目前以我有限的知识感到难以定位,求高手解答
附件是2440_led的AXD工程源码等。
我的邮箱albert4278@gmail.com
2440led.zip
28.23 KB, 下载次数: 7, 下载积分: 贡献 1
xxx331388 该用户已被删除
xxx331388 发表于 2010-11-30 23:29:38 | 显示全部楼层
飞凌-alexlee 发表于 2010-12-1 08:24:29 | 显示全部楼层
嘿嘿,先看test的源码~
就是开机跑的那个app测试
kaka2290 该用户已被删除
kaka2290 发表于 2010-12-18 00:37:38 | 显示全部楼层
