- 1
贡献0
飞刀0 FD
注册时间2010-9-15
在线时间1 小时
好几天了,搞了好几遍,NFS还是挂不上,都快骂娘了,谁给看看,十分感谢
宿主机IP:192.168.0.2
虚拟机内IP:192.168.0.231
宿主机ping192.168.0.231ping的通,重启板子,还是连不上,以下是显示信息:
IP-Config: Complete:
device=eth0, addr=192.168.0.232, mask=255.255.255.0, gw=192.168.0.201,
host=witech, domain=, nis-domain=com.cn,
bootserver=192.168.0.231, rootserver=192.168.0.231, rootpath=
Looking up port of RPC 100003/2 on 192.168.0.231
hub 1-0:1.0: connect-debounce failed, port 2 disabled
usb 1-2: new full speed USB device using s3c2410-ohci and address 2
usb 1-2: device descriptor read/64, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 3
usb 1-2: new full speed USB device using s3c2410-ohci and address 4
usb 1-2: device not accepting address 4, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 5
usb 1-2: device not accepting address 5, error -62
hub 1-0:1.0: unable to enumerate USB device on port 2
rpcbind: server 192.168.0.231 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.0.231
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /dahai/root
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00 256 mtdblock0 (driver?)
1f01 3840 mtdblock1 (driver?)
1f02 81920 mtdblock2 (driver?)
1f03 962560 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) |
