NFS挂载出现问题,深夜求解
楼主| luy3728000 发表于 2011-2-7 00:05:24 | 显示全部楼层
我把虚拟机换成 从 NAT 换到 host0-only方式时,可以从XP ping通虚拟机的ubuntu ,但是挂载时还是出现
eth0: link down
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Gateway not on directly connected network.
Looking up port of RPC 100003/2 on 192.168.22.128
eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
rpcbind: server 192.168.22.128 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.22.128
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /forlinx/root
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             256 mtdblock0 (driver?)
1f01            3840 mtdblock1 (driver?)
1f02           81920 mtdblock2 (driver?)
1f03         2011136 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
eth0: link down
楼主| luy3728000 发表于 2011-2-7 00:06:01 | 显示全部楼层
纠结啊!!搞了两三天这个了
飞凌-alexlee 发表于 2011-2-7 22:48:05 | 显示全部楼层
你选择桥接模式~~
楼主| luy3728000 发表于 2011-2-10 12:57:02 | 显示全部楼层
桥接模式也试过,几种方式都试过了,问题还是一样啊。
xxiiaaon 该用户已被删除
xxiiaaon 发表于 2011-2-14 00:06:51 | 显示全部楼层
飞凌-alexlee 发表于 2011-2-14 08:11:47 | 显示全部楼层
你重新下载最新的内核跟uboot
glorin 该用户已被删除
glorin 发表于 2011-3-27 21:51:03 | 显示全部楼层
25
飞凌-fatfish 发表于 2011-3-28 09:03:21 | 显示全部楼层
如果楼上有什么问题,最好是开贴详述
