- 0
贡献0
飞刀10 FD
注册时间2016-3-31
在线时间0 小时
** u-boot 1.1.6 **
** Updated for OK6410 TE6410 Board **
** Version (2012-09-23) **
** OEM: Forlinx Embedded **
** Web: http://www.witech.com.cn **
CPU: S3C6410 @532MHz
Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode
Board: SMDK6410
DRAM: 256 MB
Flash: 0 kB
NandFlash Information:
Nandflash:ChipType= MLC ChipName=samsung-K9LBG08U0D
No No Calc pagesize, blocksize, erasesize, use ids table .............
NandFlash:name=NAND 4GiB 1,8V 8-bit,id=d7, pagesize=4096 ,chipsize=2048 MB,erase
size=524288 oobsize=128
NandFlash Size is 2048 MB
SD/MMC: SD 2.0 SDHC / Manufacturer: 0x02,OEM: "TM/SA04G",REV: 1.1,S/N: 11168784
05,DATE: 2012/12
SDHC size: 3724 MiB
Freq = 50MHz
In: serial
Out: lcd
Err: lcd
NAND erase: device 0 whole chip
Skipping bad block at 0x00000000
Skipping bad block at 0x00080000
Skipping bad block at 0x00100000
Skipping bad block at 0x30a80000
Erasing at 0x7ff80000 -- 100% complete.
OK
reading u-boot.bin
212992 bytes read
NAND write: device 0 offset 0x0, size 0x200000
1032192 bytes written: OK
reading zImage
3638592 bytes read
NAND write: device 0 offset 0x200000, size 0x500000
Writing data at 0x6ff000 -- 100% complete.
5242880 bytes written: OK
reading rootfs.yaffs2
129761280 bytes read
NAND write: device 0 offset 0x700000, size 0x7bc0000
Writing data at 0x7eff000 -- 100% complete.
129761280 bytes written: OK
这是串口信息
