查看: 3789|回复: 3
烧写android2.2时出现的问题求解!!!
wqearth 发表于 2011-3-22 23:24:41 | 显示全部楼层 |阅读模式
我在烧写android时出现如何的情况,我不知道该如何解决,主要现在自己还是十分的菜鸟的原因无法自己解决,求解决办法
Reading kernel from sector 3829198 (12288 sectors).. completed
Boot with zImage
Starting kernel ...
Uncompressing Linux................................................................................................................................................................................................................... done, booting the kernel.
Linux version 2.6.29.1 (root@jkeqiang-desktop) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #65 Wed Dec 15 08:59:56 CST 2010
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, (c) 2004 Simtec Electronics
mout_epll: source is fout_epll (1), rate is 24000000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: rootdelay=0 console=ttySAC0,115200
PID hash table entries: 512 (order: 9, 2048 bytes)
console [ttySAC0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 122836KB available (3436K code, 405K data, 3048K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
net_namespace: 324 bytes
S3C DMA-pl080 Controller Driver, (c) 2006-2007 Samsung Electronics
Total 32 DMA channels will be initialized.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (extended precision)
------------[ cut here ]------------
WARNING: at fs/sysfs/dir.c:462 sysfs_add_one+0x34/0x48()
sysfs: duplicate filename 'sanity_checks' can not be created
Modules linked in:
[<c05761d4>] (dump_stack+0x0/0x14) from [<c03255dc>] (warn_slowpath+0x70/0x8c)
[<c032556c>] (warn_slowpath+0x0/0x8c) from [<c03b8d68>] (sysfs_add_one+0x34/0x48)
r3:c061b1c9 r2:c061d00b
r7:c6c35180 r6:c6c35420 r5:c6c35420 r4:ffffffef
[<c03b8d34>] (sysfs_add_one+0x0/0x48) from [<c03b853c>] (sysfs_add_file_mode+0x54/0x98)
r5:c066cab4 r4:c781bea0
[<c03b84e8>] (sysfs_add_file_mode+0x0/0x98) from [<c03ba61c>] (internal_create_group+0x130/0x1d0)
r7:c066c948 r6:0000000d r5:00000034 r4:00000000
[<c03ba4ec>] (internal_create_group+0x0/0x1d0) from [<c03ba6f0>] (sysfs_create_group+0x18/0x1c)
[<c03ba6d8>] (sysfs_create_group+0x0/0x1c) from [<c03735e8>] (sysfs_slab_add+0x128/0x180)
[<c03734c0>] (sysfs_slab_add+0x0/0x180) from [<c001593c>] (slab_sysfs_init+0x5c/0xfc)
r9:00000000 r8:00000000 r7:c00158e0 r6:00000000 r5:c7801b40
r4:c066c8f0
[<c00158e0>] (slab_sysfs_init+0x0/0xfc) from [<c03022fc>] (do_one_initcall+0x5c/0x19c)
r5:00000000 r4:c0020628
[<c03022a0>] (do_one_initcall+0x0/0x19c) from [<c00085a0>] (kernel_init+0x80/0xf4)
r8:00000000 r7:00000000 r6:00000000 r5:00000000 r4:c0020628
[<c0008520>] (kernel_init+0x0/0xf4) from [<c0328628>] (do_exit+0x0/0x6b0)
r4:00000000
---[ end trace da227214a82491b8 ]---
Kernel panic - not syncing: Attempted to kill init!
接下去就烧写不下去了,求解!!!!!!!!!
飞凌-fatfish 发表于 2011-3-23 08:23:16 | 显示全部楼层
可以用uboot的nand scrub命令擦一次flash
楼主| wqearth 发表于 2011-3-23 09:03:34 | 显示全部楼层
擦除了坏块也没用哦,还是无法正常烧写,还是上面的问题,到那步就无法进行下去了
25
飞凌-fatfish 发表于 2011-3-23 13:14:48 | 显示全部楼层
请贴出 擦除坏块和和烧写的过程。
