- 23
贡献133
飞刀40 FD
注册时间2018-11-8
在线时间7 小时
两种方法都试过了,串口打印信息为
Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
s3c-rtc s3c64xx-rtc: setting system clock to 2000-10-08 22:14:24 UTC (971043264)
yaffs: passed flags ""
devtmpfs: error mounting -2
Freeing init memory: 172K
Failed to execute /linuxrc. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
s3c2410-ohci s3c2410-ohci: auto-stop root hub
[<c0039d38>] (unwind_backtrace+0x0/0xf8) from [<c053e558>] (panic+0x60/0x1a8)
[<c053e558>] (panic+0x60/0x1a8) from [<c00335ac>] (init_post+0xbc/0x130)
[<c00335ac>] (init_post+0xbc/0x130) from [<c0008488>] (kernel_init+0x118/0x160)
[<c0008488>] (kernel_init+0x118/0x160) from [<c0034aa8>] (kernel_thread_exit+0x0/0x8)
