查看: 12429|回复: 4
[Win CE] OK6410启动停在ERR CMD:5: ERR CMD :5:
32
A40i\T3\T507\T527通行证i.MX6Q通行证RK3568通行证FCU2401通行证AM335x通行证
lishengwu 发表于 2013-8-1 17:02:16 | 显示全部楼层 |阅读模式
我的OK6410的开发板,在系统启动过程中,卡住了。
查看串口的调试信息,看到调试信息停留在
                                      CSDHCSlotBase :: SDClockOn: Timeout waiting for CLOCK_STABLE
                                       ERR CMD :5 :: ERR CMD:5::ERR CMD:5::
不知道为什么,请高手帮忙分析分析。。。
飞凌-路飞 发表于 2013-8-2 08:49:22 | 显示全部楼层
楼主清除下坏块,然后从新烧写下试试!!实在不行就打技术支持电话吧!!!
楼主| lishengwu 发表于 2013-8-2 14:08:03 | 显示全部楼层
你好!我这里贴出来串口打印出来的信息:
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK   : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK   : 133000000
[OAL] PCLK   : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
Arguments area has some values
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
OEMSetRealTime(2006/1/1 12:0:0.000)
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x00002c38
[FMD] FMD_Init() : NUM_OF_BLOCKS = 2048
[FMD] FMD_Init() : PAGES_PER_BLOCK = 128
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_OEMIoControl() : IOCTL_FMD_GET_INTE**CE
[FMD] FMD_GetInfo() : NUMBLOCKS = 2048(0x800), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
[FMD:ERR] FMD_OEMIoControl() : Unknown IOCTL (0x00071c24)
[OAL] Not Clear System Hive
[OAL] Not Clear User Hive
[PWRCON]  PWC_Init***
-OALIntrRequestSysIntr(irq = 40, sysIntr = 18)
-OALIntrRequestSysIntr(irq = 19, sysIntr = 19)
-OALIntrRequestSysIntr(irq = 23, sysIntr = 20)
-OALIntrRequestSysIntr(irq = 20, sysIntr = 21)
-OALIntrRequestSysIntr(irq = 73, sysIntr = 22)
-OALIntrRequestSysIntr(irq = 74, sysIntr = 23)
[HSMMC0] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 94, sysIntr = 24)
[HSMMC0] Turn OFF the F/B delay control.
[HSMMC0] Card is Inserted!
WARN: OALIoCtlHalGetHWEntropy: Buffer too small
[HSMMC0] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
<Davicom DM9000A driver for WinCE 6.0>
<DM9:++MiniportIntialize>
[dm9: Tries to map io space with 18000000]
[dm9: The mapped address is D2D10000]
[dm9: Chip signature is 29282B2A]
Unknown device
<DM9:--MiniportIntialize>
[UFNPDD] USB Serial Function Class Enabled
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 25)
ERR CMD:5 : ERR CMD:5 : ERR CMD:5 : ERR CMD:5 :
网上说是跟CLOCK_STABLE有关系,是这样吗?
飞凌-路飞 发表于 2013-8-5 08:34:53 | 显示全部楼层
楼主建议您还是返修把!!
楼主| lishengwu 发表于 2013-8-12 11:13:51 | 显示全部楼层
楼主建议您还是返修把!!
你好!在SD驱动中,_MMC_SPEC_42_ 这个宏没有定义,但却有很多关于这个宏的源码配置,请问,这个_MMC_SPEC_42_ 有什么作用?
