- 1
贡献0
飞刀0 FD
注册时间2010-1-27
在线时间1 小时
谢谢技术支持,但是,问题依旧:
选了7之后没有任何反映。只是打印出以下信息:
Ethernet Boot Loader Configuration :
0) Mac address .......... (00:12:72:72:20:20)
1) Ip address ........... (192.168.1.115)
2) Subnet Mask address .. (255.255.255.0)
3) DHCP ................. (Disabled)
4) Boot delay (seconds).. (5)
5) Frequency settings ... (core at 240, bus divider 2)
6) Download image to Flash
7) Launch existing flash resident image at startup
l) Launch flash resident image now
d) Download from ethernet now
s) Save configuration now
r) Restore default configuration and save now
n) Image flash menu
若进入eboot菜单按L键,循环出现如下信息:
+OEMLaunch (dwImageStart=0,dwImageLength=0,dwLaunchAddr=0
Initialize image flash .......Master Clock is 50003200 Hz
->ConfigChip
<-ConfigChip
->LoadBlocksInfo
LoadBlocksInfo::g_pBlocksInfo : 0x80050000
<-LoadBlocksInfo
OK
FMD_DirectRead to 0x8006c000 from @0 30408704 bytes
Launching windows CE image by jumping at address 0x2006d000RomBOOT
INFO : Low Level Init : OK
Init Data flash
Starting eboot ...
Master Clock is 47996928 Hz
Target processor Frequency is 200 MHz
Target Bus Frequency is 50 MHz
Master Clock is 49996800 Hz
vga init 0x4::0x20
VGA INIT DONE
Debug serial initialized ........OK
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Dec 12
2007 11:04:22
Microsoft Windows CE 5.0 Ethernet Bootloader for the AT91SAM926xEK board
Adaptation performed by ADENEO (c) 2007
Press [ENTER] to launch image stored in flash or [SPACE] to cancel.
Initiating image launch in 0 seconds
System ready!
Preparing for download...
Initialize image flash .......Master Clock is 49996800 Hz
->ConfigChip
<-ConfigChip
->LoadBlocksInfo
<-LoadBlocksInfo
OK
Init Data flash
Starting eboot ...
Master Clock is 48003072 Hz
vga init 0x4::0x20
VGA INIT DONE
Master Clock is 50003200 Hz |
