- 24
贡献57
飞刀0 FD
注册时间2013-8-19
在线时间5 小时
我也是同样的问题。在烧写玩linux之后重启板子dnw上返回的信息是:
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2021-08-20 10:34:34 UTC (1629455674)
yaffs: passed flags ""
devtmpfs: error mounting -2
Freeing init memory: 176K
Failed to execute /linuxrc. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[<c003aca8>] (unwind_backtrace+0x0/0xfc) from [<c04a7f2c>] (dump_stack+0x18/0x1c)
[<c04a7f2c>] (dump_stack+0x18/0x1c) from [<c04a7f90>] (panic+0x60/0x1ac)
[<c04a7f90>] (panic+0x60/0x1ac) from [<c00345dc>] (init_post+0xc8/0x140)
[<c00345dc>] (init_post+0xc8/0x140) from [<c00084c8>] (kernel_init+0xf4/0x130)
[<c00084c8>] (kernel_init+0xf4/0x130) from [<c0035a34>] (kernel_thread_exit+0x0/0x8)
求解决! |
