查看: 3689|回复: 1
ok6410 led 驱动 +自编测试程序 通过喽
jackbella 发表于 2013-8-28 14:23:08 | 显示全部楼层 |阅读模式
#include <linux/miscdevice.h>
#include <linux/delay.h>
#include <asm/irq.h>
#include <mach/hardware.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/mm.h>
#include <linux/fs.h>
#include <linux/types.h>
#include <linux/moduleparam.h>
#include <linux/slab.h>
#include <linux/errno.h>
#include <linux/ioctl.h>
#include <linux/cdev.h>
#include <linux/string.h>
#include <linux/list.h>
#include <linux/pci.h>
#include <asm/uaccess.h>
#include <asm/atomic.h>
#include <asm/unistd.h>
#include <mach/map.h>
#include <mach/regs-clock.h>
#include <mach/regs-gpio.h>
#include <plat/gpio-cfg.h>
#include <mach/gpio-bank-e.h>
#include <mach/gpio-bank-m.h>
#define DEVICE_NAME "leds"
cmd : 0 :open 1: close
arg : 0-3   led1 -led4
static long s3c6410_leds_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
        switch(cmd) {
                unsigned tmp;
        case 0:
        case 1:
                 if (arg > 3)
                         return -EINVAL;
                tmp = readl(S3C64XX_GPMDAT);
                if(cmd==0) //open led
                        tmp &= (~(1<<arg));
                else  //close led
                        tmp |= (1<<arg);
                writel(tmp,S3C64XX_GPMDAT);
                return 0;
        default:
                return -EINVAL;
static struct file_operations dev_fops = {
        .owner                        = THIS_MODULE,
        .unlocked_ioctl        = s3c6410_leds_ioctl,
static struct miscdevice misc = {
        .minor = MISC_DYNAMIC_MINOR,
        .name = DEVICE_NAME,
        .fops = &dev_fops,
static int __init dev_init(void)
        int ret;
       unsigned tmp;
       //gpm0-3 pull up
        tmp = readl(S3C64XX_GPMPUD);
        tmp &= (~0xFF);
        tmp |= 0xaa;
        writel(tmp,S3C64XX_GPMPUD);
        //gpm0-3 output mode
        tmp =readl(S3C64XX_GPMCON);
        tmp &= (~0xFFFF);
        tmp |= 0x1111;
        writel(tmp,S3C64XX_GPMCON);
        //gpm0-3 output 0  why not open the led??
        tmp = __raw_readl(S3C64XX_GPMDAT);
        tmp |= 0x10;     //low 4bit =0000;
        ret = misc_register(&misc);
        return ret;
static void __exit dev_exit(void)
        misc_deregister(&misc);
module_init(dev_init);
module_exit(dev_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("jack sun");
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <time.h>
#include <sys/time.h>
#define LED_OPEN 0
#define LED_CLOSE 1
int main()
int fd;
   fd = open("/dev/leds", 0);
if (fd < 0)
                perror("open device leds error");
                exit(1);
while(1)
        ioctl(fd,LED_OPEN,0);//led1 open
        ioctl(fd,LED_CLOSE,1);//led2 close
        ioctl(fd,LED_OPEN,2);//led3 open
        ioctl(fd,LED_CLOSE,3);//led4 close
        usleep(1000000);
        ioctl(fd,LED_CLOSE,0);//led1 open
        ioctl(fd,LED_OPEN,1);//led2 close
        ioctl(fd,LED_CLOSE,2);//led3 open
        ioctl(fd,LED_OPEN,3);//led4 close
        usleep(1000000);
        close(fd);
        return 0;
后台运行:
./led_text2 qws&
tonytsui 发表于 2015-7-25 12:28:30 | 显示全部楼层
楼主,没有makefile,也可以运行?初学提问
