- 14
贡献50
飞刀0 FD
注册时间2013-8-27
在线时间4 小时
大侠你好,本人纯菜鸟,请教下:我按照软件手册烧写linux系统,之后重新上电,板子好像一直重启,请问下时什么原因,是不是哪个步骤出错了?如下是串口打印信息:
[ 2.543102] ThumbEE CPU extension supported.
[ 2.547734] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
[ 2.555603] regulator_init_complete: disabling pd_mfc_supply
[ 2.560508] regulator_init_complete: disabling pd_tv_supply
[ 2.566020] regulator_init_complete: disabling pd_cam_supply
[ 2.571693] smdkc110-rtc smdkc110-rtc: rtc disabled, re-enabling
[ 2.577644] smdkc110-rtc smdkc110-rtc: setting system clock to 2010-01-01 12:00:02 UTC (1262347202)
[ 2.588139] FIMC0 registered successfully
[ 2.592013] FIMC1 registered successfully
[ 2.595986] FIMC2 registered successfully
[ 2.598911] DBUG_PORT must not use AFC!
[ 2.621838] yaffs: dev is 32505858 name is "mtdblock2" rw
[ 2.625769] yaffs: passed flags ""
[ 2.629153] <8>yaffs: Attempting MTD mount of 31.2,"mtdblock2"
[ 2.634953] <8>yaffs: auto selecting yaffs2
[ 3.082778] <8>yaffs tragedy: Bad object type, -1612381696 != 0, for object 3531 at chunk 32640 during scan
[ 3.143436] <8>yaffs tragedy: Bad object type, -589822 != 0, for object 3864 at chunk 33792 during scan
[ 3.183188] <8>yaffs tragedy: Bad object type, -177179551 != 0, for object 3885 at chunk 34048 during scan
[ 3.191481] <8>yaffs_read_super: isCheckpointed 0
[ 3.196080] VFS: Mounted root (yaffs filesystem) on device 31:2.
[ 3.202065] Freeing init memory: 176K
[ 3.205700] Failed to execute /linuxrc. Attempting defaults...
[ 3.235183] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 3.246140] Backtrace:
[ 3.248563] [<c0038fcc>] (dump_backtrace+0x0/0x110) from [<c0534cf0>] (dump_stack+0x18/0x1c)
[ 3.256968] r6:c005be90 r5:c00083d4 r4:c077359c r3:00000002
[ 3.262590] [<c0534cd8>] (dump_stack+0x0/0x1c) from [<c0534d6c>] (panic+0x78/0xf8)
[ 3.270153] [<c0534cf4>] (panic+0x0/0xf8) from [<c00345e4>] (init_post+0xb4/0xdc)
[ 3.277594] r3:efc34000 r2:efef1600 r1:efef1700 r0:c06ba672
[ 3.283216] [<c0034530>] (init_post+0x0/0xdc) from [<c0008500>] (kernel_init+0x12c/0x170)
[ 3.291372] r4:c07c1900 r3:ef801090
[ 3.294917] [<c00083d4>] (kernel_init+0x0/0x170) from [<c005be90>] (do_exit+0x0/0x5f0)
[ 3.302810] r4:00000000 r3:00000000
[ 3.306350] Rebooting in 5 seconds..
[ 8.336903] Restarting Linux version 2.6.35.7 (root@forlinx) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #1 PREEMPT Fri Jun 21 16:33:18 CST 2013
[ 8.336914]
[ 8.352602] arch_reset: attempting watchdog reOK
U-Boot 1.3.4 (Jun 18 2013 - 15:27:38) for SMDKV210
CPU: S5PV210@1000MHz(OK)
APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
MPLL = 667MHz, EPLL = 80MHz
HclkDsys = 166MHz, PclkDsys = 83MHz
HclkPsys = 133MHz, PclkPsys = 66MHz
SCLKA2M = 200MHz
Serial = CLKUART
Board: SMDKV210
RAM Configuration:
Bank #0: 20000000 256 MB
Bank #1: 40000000 256 MB
Flash: 0 kB
SD/MMC: S3C_HSMMC0_dev0, S3C_HSMMC2_dev1
Card channel 1 init fail!
0 MB
NAND: Nandflash:ChipType= SLC ChipName=MT29F8G08ABABAWP
No No Calc pagesize, blocksize, erasesize, use ids table .............
NandFlash:name=NAND 1GiB 1,8V 8-bit,id=38, pagesize=4096 ,chipsize=1024 MB,erasesize=524288 oobsize=128
NandFlash Size is 1024 MB
*** Warning - using default environment
In: serial
Out: serial
Err: serial
checking mode for fastboot ...
Main area read (10 blocks):
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 2.6.35.7 (root@forlinx) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #1 PREEMPT Fri Jun 21 16:33:18 CST 2013
[ 0.000000] CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: SMDKV210
[ 0.000000] Ignoring unrecognised tag 0x41001099
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] <8>On node 0 totalpages: 131072
[ 0.000000] <8> Normal zone: 1536 pages used for memmap
[ 0.000000] <8> Normal zone: 0 pages reserved
[ 0.000000] <8> Normal zone: 129536 pages, LIFO batch:31
[ 0.000000] CPU S5PV210/S5PC110 (id 0x43110220)
[ 0.000000] <8>s5pv210_init_clocks: initializing clocks
[ 0.000000] S3C24XX Clocks, Copyright 2004 Simtec Electronics
[ 0.000000] <8>s5pv210_setup_clocks: registering clocks
[ 0.000000] <8>s5pv210_setup_clocks: clkdiv0 = 14131440, clkdiv1 = 00000400
[ 0.000000] <8>s5pv210_setup_clocks: xtal is 24000000
[ 0.000000] S5PV210: PLL settings, A=1000000000, M=667000000, E=80000000 V=54000000
[ 0.000000] S5PV210: ARMCLK=1000000000, HCLKM=200000000, HCLKD=166750000
[ 0.000000] HCLKP=133400000, PCLKM=100000000, PCLKD=83375000, PCLKP=66700000
[ 0.000000] sclk_dmc: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_onenand: source is hclk_dsys (1), rate is 166750000
[ 0.000000] sclk: source is mout_mpll (6), rate is 66700000
[ 0.000000] sclk_mixer: source is sclk_dac (0), rate is 54000000
[ 0.000000] sclk_spdif: source is sclk_audio (0), rate is 24000000
[ 0.000000] sclk_fimc: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_cam0: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_cam1: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_fimd: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_mmc: source is mout_mpll (6), rate is 47642857
[ 0.000000] sclk_mmc: source is mout_epll (7), rate is 80000000
[ 0.000000] sclk_mfc: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_g2d: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_csis: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_spi: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_pwi: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_pwm: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_mdnie: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_mdnie_pwm: source is ext_xtal (0), rate is 24000000
[ 0.000000] s5pv210: 37748736 bytes system memory reserved for mfc at 0x20c29000
[ 0.000000] s5pv210: 37748736 bytes system memory reserved for mfc at 0x40000000
[ 0.000000] s5pv210: 25165824 bytes system memory reserved for fimc0 at 0x42400000
[ 0.000000] s5pv210: 10137600 bytes system memory reserved for fimc1 at 0x43c00000
[ 0.000000] s5pv210: 25165824 bytes system memory reserved for fimc2 at 0x445ab000
[ 0.000000] s5pv210: 8388608 bytes system memory reserved for jpeg at 0x45dab000
[ 0.000000] s5pv210: 11520000 bytes system memory reserved for fimd at 0x465ab000
[ 0.000000] s5pv210: 3072000 bytes system memory reserved for texstream at 0x470a8000
[ 0.000000] s5pv210: 3379200 bytes system memory reserved for pmem_gpu1 at 0x47396000
[ 0.000000] s5pv210: 8388608 bytes system memory reserved for g2d at 0x476cf000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129536
[ 0.000000] Kernel command line: console=ttySAC2,115200 root=/dev/mtdblock2 init=/linuxrc
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 256MB 256MB = 512MB total
[ 0.000000] Memory: 344752k/344752k available, 179536k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xf0800000 - 0xfc000000 ( 184 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0034000 ( 176 kB)
[ 0.000000] .text : 0xc0034000 - 0xc0761000 (7348 kB)
[ 0.000000] .data : 0xc0762000 - 0xc07c1840 ( 383 kB)
[ 0.000000] SLUB: Genslabs=9, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:393
[ 0.000000] VIC @fd000000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd010000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd020000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd030000: id 0x00041192, vendor 0x41
[ 0.000000] mult[140737]
[ 0.000000] max_delta_ns[2937815369]
[ 0.000000] min_delta_ns[30517]
[ 0.000000] rate[32768]
[ 0.000000] HZ[256]
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttySAC2] enabled
[ 0.524920] Calibrating delay loop... 998.15 BogoMIPS (lpj=1949696)
[ 0.610504] pid_max: default: 32768 minimum: 301
[ 0.615157] Mount-cache hash table entries: 512
[ 0.619880] Initializing cgroup subsys debug
[ 0.623863] Initializing cgroup subsys cpuacct
[ 0.628276] Initializing cgroup subsys freezer
[ 0.632719] CPU: Testing write buffer coherency: ok
[ 0.639975] regulator: core version 0.5
[ 0.642527] NET: Registered protocol family 16
[ 0.660731] S3C Power Management, Copyright 2004 Simtec Electronics
[ 0.665610] pmstats at 00000000
[ 0.669930] smdkc110_setup_clocks: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.676229] smdkc110_setup_clocks: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.683740] smdkc110_setup_clocks: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.691277] smdkc110_setup_clocks: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.699559] S5PV210: Initializing architecture
[ 0.703936] s3c24xx-pwm s3c24xx-pwm.0: tin at 66700000, tdiv at 66700000, tin=divclk, base 0
[ 0.711690] s3c24xx-pwm s3c24xx-pwm.1: tin at 66700000, tdiv at 66700000, tin=divclk, base 8
[ 0.720066] s3c24xx-pwm s3c24xx-pwm.2: tin at 66700000, tdiv at 66700000, tin=divclk, base 12
[ 0.728557] s3c24xx-pwm s3c24xx-pwm.3: tin at 66700000, tdiv at 66700000, tin=divclk, base 16
[ 0.737406] regulator: pd_audio_supply: 5000 mV normal
[ 0.742420] regulator: pd_cam_supply: 5000 mV normal
[ 0.747440] regulator: pd_tv_supply: 5000 mV normal
[ 0.752353] regulator: pd_lcd_supply: 5000 mV normal
[ 0.757393] regulator: pd_g3d_supply: 5000 mV normal
[ 0.762425] regulator: pd_mfc_supply: 5000 mV normal
[ 0.795364] bio: create slab <bio-0> at 0
[ 0.799103] SCSI subsystem initialized
[ 0.802272] usbcore: registered new inte**ce driver usbfs
[ 0.807275] usbcore: registered new inte**ce driver hub
[ 0.812561] usbcore: registered new device driver usb
[ 0.818457] s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter
[ 0.823003] s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
[ 0.828512] s3c-i2c s3c2440-i2c.2: i2c-2: S3C I2C adapter
[ 0.834354] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.840784] cfg80211: Calling CRDA to update world regulatory domain
[ 0.846759] Switching to clocksource clock_source_systimer
[ 0.864026] NET: Registered protocol family 2
[ 0.867074] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.874554] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.881335] TCP bind hash table entries: 16384 (order: 6, 327680 bytes)
[ 0.888071] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.894128] TCP reno registered
[ 0.897251] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.903160] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.909617] NET: Registered protocol family 1
[ 0.914030] RPC: Registered udp transport module.
[ 0.918506] RPC: Registered tcp transport module.
[ 0.923159] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.930023] PMU: registered new PMU device of type 0
[ 0.934632] SMDKC110/V210 RTC, (c) 2010 Samsung Electronics
[ 0.940100] smdkc110-rtc smdkc110-rtc: rtc disabled, re-enabling
[ 0.946290] smdkc110-rtc smdkc110-rtc: rtc core: registered s3c as rtc0
[ 0.952737] S5PV210 ADC driver, (c) 2010 Samsung Electronics
[ 0.958710] cpuidle: phy_regs_save:0x4fdff000
[ 0.962697] Loaded driver for PL330 DMAC-0 s3c-pl330
[ 0.967535] DBUFF-64x8bytes Num_Chans-8 Num_Peri-2 Num_Events-32
[ 0.973662] Loaded driver for PL330 DMAC-1 s3c-pl330
[ 0.978536] DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.984672] Loaded driver for PL330 DMAC-2 s3c-pl330
[ 0.989540] DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 1.002861] ashmem: initialized
[ 1.005054] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.011333] ROMFS MTD (C) 2007 Red Hat, Inc.
[ 1.015124] <8>yaffs built Jun 21 2013 16:25:53 Installing.
[ 1.020775] msgmni has been set to 673
[ 1.026958] alg: No test for stdrng (krng)
[ 1.029647] io scheduler noop registered
[ 1.033514] io scheduler deadline registered
[ 1.037738] io scheduler cfq registered (default)
[ 1.043683] s3cfb s3cfb: [fb4] dma: 0x465ab000, cpu: 0xf1000000, size: 0x00465000
[ 1.059361] Console: switching to colour frame buffer device 100x30
[ 1.069933] FIMD src sclk = 166750000
[ 1.193378] s3cfb s3cfb: registered successfully
[ 1.197395] leds initialized
[ 1.199424] Initializing hello device.
[ 1.203443] Succedded to initialize hello device.
[ 1.208065]
[ 1.208069] @@@@@@@@@@@@@@@@@@@@@@@@@@
[ 1.213005] irda initialized
[ 1.215850]
[ 1.215853] @@@@@@@@@@@@@@@@@@@@@@@@@@
[ 1.221212] pwm pwm initialized ok
[ 1.225551] PA FB = 0x465AB000, bits per pixel = 32
[ 1.229481] screen width=800 height=480 va=0xe65ab000 pa=0x465ab000
[ 1.235703] xres_virtual = 800, yres_virtual = 1440, xoffset = 0, yoffset = 0
[ 1.242805] fb_size=4608000
[ 1.245564] Back frameBuffer[0].VAddr=e6722000 PAddr=46722000 size=1536000
[ 1.252432] Back frameBuffer[1].VAddr=e6899000 PAddr=46899000 size=1536000
[ 1.259679] s5pv210-uart.0: s3c2410_serial0 at MMIO 0xe2900000 (irq = 16) is a S3C6400/10
[ 1.267674] s5pv210-uart.1: s3c2410_serial1 at MMIO 0xe2900400 (irq = 20) is a S3C6400/10
[ 1.275771] s5pv210-uart.2: s3c2410_serial2 at MMIO 0xe2900800 (irq = 24) is a S3C6400/10
[ 1.283931] s5pv210-uart.3: s3c2410_serial3 at MMIO 0xe2900c00 (irq = 28) is a S3C6400/10
[ 1.299018] brd: module loaded
[ 1.304187] loop: module loaded
[ 1.306969] S3C NAND Driver, (c) 2008 Samsung Electronics
[ 1.311445] Nandflash:ChipType= SLC ChipName=MT29F8G08ABACAWP s3c_nand_probe 1686
[ 1.318802] S3C NAND Driver is using hardware ECC.
[ 1.323564] No No Calc pagesize, blocksize, erasesize, use ids table .............
[ 1.331257] NAND device: Manufacturer ID: 0x2c, Chip ID: 0x38 (Micron NAND 1GiB 1,8V 8-bit)
[ 1.339583] Creating 3 MTD partitions on "s5pv210-nand":
[ 1.344865] 0x000000000000-0x000000100000 : "misc"
[ 1.350711] 0x000000100000-0x000000600000 : "kernel"
[ 1.355846] 0x000000600000-0x000040000000 : "system"
[ 1.421511] PPP generic driver version 2.4.2
[ 1.424631] PPP Deflate Compression module registered
[ 1.429378] PPP BSD Compression module registered
[ 1.434609] PPP MPPE Compression module registered
[ 1.438805] NET: Registered protocol family 24
[ 1.443241] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
[ 1.450231] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.459172] dm9000 Ethernet Driver, V1.31
[ 1.462891] eth0: dm9000a at f0892300,f0896304 IRQ 41 MAC: 00:09:c0:ff:ec:48 (platform data)
[ 1.470278] HDLC support module revision 1.22
[ 1.474479] hso: drivers/net/usb/hso.c: 1.2 Option Wireless
[ 1.480146] usbcore: registered new inte**ce driver hso
[ 1.485454] usbcore: registered new inte**ce driver cdc_ether
[ 1.491204] usbcore: registered new inte**ce driver rndis_host
[ 1.497165] usbcore: registered new inte**ce driver rndis_wlan
[ 1.502896] libertas_sdio: Libertas SDIO driver
[ 1.507381] libertas_sdio: Copyright Pierre Ossman
[ 1.512381] usbcore: registered new inte**ce driver rt73usb
[ 1.518041] usbcore: registered new inte**ce driver hwa-rc
[ 1.523698] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.529972] s5p-ehci s5p-ehci: s5pv210 EHCI
[ 1.534245] s5p-ehci s5p-ehci: new USB bus registered, assigned bus number 1
[ 1.541097] s5p-ehci s5p-ehci: irq 87, io mem 0xec200000
[ 1.554883] s5p-ehci s5p-ehci: USB 0.0 started, EHCI 1.00
[ 1.559318] hub 1-0:1.0: USB hub found
[ 1.562533] hub 1-0:1.0: 1 port detected
[ 1.566899] usbcore: registered new inte**ce driver hwa-hc
[ 1.572180] usbcore: registered new inte**ce driver cdc_wdm
[ 1.577622] Initializing USB Mass Storage driver...
[ 1.582646] usbcore: registered new inte**ce driver usb-storage
[ 1.588450] USB Mass Storage support registered.
[ 1.593151] usbcore: registered new inte**ce driver ums-sddr09
[ 1.599082] usbcore: registered new inte**ce driver ums-sddr55
[ 1.605089] usbcore: registered new inte**ce driver usbserial
[ 1.610769] USB Serial support registered for generic
[ 1.615784] usbcore: registered new inte**ce driver usbserial_generic
[ 1.622169] usbserial: USB Serial Driver core
[ 1.626610] USB Serial support registered for debug
[ 1.631458] usbcore: registered new inte**ce driver debug
[ 1.636961] USB Serial support registered for pl2303
[ 1.641867] usbcore: registered new inte**ce driver pl2303
[ 1.647292] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 1.653481] s3c-udc : S3C HS USB Device Controller Driver, (c) 2008-2009 Samsung Electronics
[ 1.653489] s3c-udc : version 15 March 2009 (DMA Mode)
[ 1.667136] mice: PS/2 mouse device common for all mice
[ 1.672239] forlinx is call
[ 1.675016] input: s3c-keypad as /devices/virtual/input/input0
[ 1.687971] s3c-keypad Initialized
[ 1.690008] S3C Keypad Driver
[ 1.692869] gpio-keys init
[ 1.695899] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.702479] S5P Touchscreen driver, (c) 2008 Samsung Electronics
[ 1.708236] *********res->start=e1700000, res->end=e1700fff size=4096, pdev-name=s3c-ts
[ 1.716233] S5P TouchScreen got loaded successfully : 12 bits
[ 1.722316] input: S5P TouchScreen as /devices/virtual/input/input2
[ 1.728433] TSSEL : 0
[ 1.730857] input: ft5x0x_ts as /devices/virtual/input/input3
[ 1.875190] usb 1-1: new high speed USB device using s5p-ehci and address 2
[ 1.893159] using rtc device, s3c, for alarms
[ 1.896048] i2c /dev entries driver
[ 1.900687] IR NEC protocol handler initialized
[ 1.904033] IR RC5(x) protocol handler initialized
[ 1.908786] IR RC6 protocol handler initialized
[ 1.913294] IR JVC protocol handler initialized
[ 1.917797] IR Sony protocol handler initialized
[ 1.922394] Linux video capture inte**ce: v2.00
[ 1.927903] usbcore: registered new inte**ce driver em28xx
[ 1.932578] em28xx driver loaded
[ 1.935743] Em28xx: Initialized (Em28xx Audio Extension) extension
[ 1.942281] usbcore: registered new inte**ce driver usbvision
[ 1.947730] USBVision USB Video Device Driver for Linux : 0.9.10
[ 1.953819] usbcore: registered new inte**ce driver zr364xx
[ 1.959328] zr364xx: Zoran 364xx
[ 1.962678] usbcore: registered new inte**ce driver stkwebcam
[ 1.968332] sn9c102: V4L2 driver for SN9C1xx PC Camera Controllers v1:1.47pre49
[ 1.975738] usbcore: registered new inte**ce driver sn9c102
[ 1.981252] et61x251: V4L2 driver for ET61X[12]51 PC Camera Controllers v1:1.09
[ 1.988685] usbcore: registered new inte**ce driver et61x251
[ 1.994240] zc0301: V4L2 driver for ZC0301[P] Image Processor and Control Chip v1:1.10
[ 2.002276] usbcore: registered new inte**ce driver zc0301
[ 2.007694] gspca: main v2.9.0 registered
[ 2.011841] usbcore: registered new inte**ce driver zc3xx
[ 2.017117] zc3xx: registered
[ 2.020185] usbcore: registered new inte**ce driver hdpvr
[ 2.025681] usbcore: registered new inte**ce driver s2255
[ 2.031917] s3c-csis: Samsung MIPI-CSI2 driver probed successfully
[ 2.037485] mfc_init: <6>S5PC110 MFC Driver, (c) 2009 Samsung Electronics
[ 2.037492]
[ 2.048767] S3C JPEG Driver, (c) 2007 Samsung Electronics
[ 2.052741] JPEG driver for S5PV210
[ 2.056537] hub 1-1:1.0: USB hub found
[ 2.060098] hub 1-1:1.0: 4 ports detected
[ 2.064942] usbcore: registered new inte**ce driver uvcvideo
[ 2.069616] USB Video Class driver (v0.1.0)
[ 2.073914] s3c_bat_init
[ 2.076343] sec-fake-battery sec-fake-battery: s3c_bat_probe
[ 2.082951] S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
[ 2.088230] s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
[ 2.095671] device-mapper: uevent: version 1.0.3
[ 2.100248] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05) initialised: dm-devel@redhat.com
[ 2.108588] cpuidle: using governor ladder
[ 2.112698] cpuidle: using governor menu
[ 2.116627] sdhci: Secure Digital Host Controller Inte**ce driver
[ 2.122558] sdhci: Copyright(c) Pierre Ossman
[ 2.127110] s3c-sdhci s3c-sdhci.0: clock source 2: sclk_mmc (47642857 Hz)
[ 2.134863] mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.0] using ADMA
[ 2.140732] s3c-sdhci s3c-sdhci.1: clock source 2: sclk_mmc (47642857 Hz)
[ 2.149665] mmc1: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
[ 2.155301] s3c-sdhci s3c-sdhci.2: clock source 2: sclk_mmc (47642857 Hz)
[ 2.163173] mmc2: SDHCI controller on samsung-hsmmc [s3c-sdhci.2] using ADMA
[ 2.169083] s3c-sdhci s3c-sdhci.3: clock source 2: sclk_mmc (47642857 Hz)
[ 2.179053] mmc3: SDHCI controller on samsung-hsmmc [s3c-sdhci.3] using ADMA
[ 2.185613] usbcore: registered new inte**ce driver hiddev
[ 2.190337] usbcore: registered new inte**ce driver usbhid
[ 2.195766] usbhid: USB HID core driver
[ 2.201967] enter wm8960_i2c_probe ,sound/soc/codecs/wm8960.c
[ 2.206353] Entered wm8960_register,sound/soc/codecs/wm8960.c
[ 2.212049] wm8960 0-001a: No platform data supplied
[ 2.339466] successful to register WM8960 I2C driver .bs s5pv210_cfg_i2s,arch/arm/mach-s5pv210/dev-audio.c:44
[ 2.348545] s3c_idma_preallocate_buffer: VA-f08c0000 PA-C0000000 163840bytes
[ 2.355194] asoc: WM8960 PAIFRX <-> s3c64xx-i2s mapping ok
[ 2.360933] asoc: WM8960 PAIFTX <-> s3c64xx-i2s mapping ok
[ 2.396752] wm8960_set_dai_fmt
[ 2.398803] wm8960_set_dai_fmt
[ 2.404340] ALSA device list:
[ 2.405829] #0: smdk (WM8960)
[ 2.409018] GACT probability NOT on
[ 2.412442] Mirror/redirect action on
[ 2.416069] u32 classifier
[ 2.418752] Actions configured
[ 2.422138] Netfilter messages via NETLINK v0.30.
[ 2.426868] nf_conntrack version 0.5.0 (5386 buckets, 21544 max)
[ 2.432950] CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
[ 2.440165] nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
[ 2.448162] sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
[ 2.454830] ctnetlink v0.93: registering with nfnetlink.
[ 2.459598] xt_time: kernel timezone is -0000
[ 2.466083] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.470031] arp_tables: (C) 2002 David S. Miller
[ 2.474584] TCP cubic registered
[ 2.477756] NET: Registered protocol family 10
[ 2.483968] lo: Disabled Privacy Extensions
[ 2.491468] Mobile IPv6
[ 2.492454] IPv6 over IPv4 tunneling driver
[ 2.498311] sit0: Disabled Privacy Extensions
[ 2.505166] ip6tnl0: Disabled Privacy Extensions
[ 2.509621] NET: Registered protocol family 17
[ 2.512761] NET: Registered protocol family 15
[ 2.517343] lib80211: common routines for IEEE802.11 drivers
[ 2.522806] <8>lib80211_crypt: registered algorithm 'NULL'
[ 2.528249] <8>lib80211_crypt: registered algorithm 'WEP'
[ 2.533622] <8>lib80211_crypt: registered algorithm 'CCMP'
[ 2.539082] <8>lib80211_crypt: registered algorithm 'TKIP'
[ 2.544664] NET: Registered protocol family 36
[ 2.548959] ThumbEE CPU extension supported.
[ 2.553750] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
[ 2.561590] regulator_init_complete: disabling pd_mfc_supply
[ 2.566506] regulator_init_complete: disabling pd_tv_supply
[ 2.572018] regulator_init_complete: disabling pd_cam_supply
[ 2.577684] smdkc110-rtc smdkc110-rtc: rtc disabled, re-enabling
[ 2.583642] smdkc110-rtc smdkc110-rtc: setting system clock to 2010-01-01 12:00:02 UTC (1262347202)
[ 2.594169] FIMC0 registered successfully
[ 2.598059] FIMC1 registered successfully
[ 2.602043] FIMC2 registered successfully
[ 2.604909] DBUG_PORT must not use AFC!
[ 2.627857] yaffs: dev is 32505858 name is "mtdblock2" rw
[ 2.631792] yaffs: passed flags ""
[ 2.635171] <8>yaffs: Attempting MTD mount of 31.2,"mtdblock2"
[ 2.641100] <8>yaffs: auto selecting yaffs2
[ 3.088883] <8>yaffs tragedy: Bad object type, -1612381696 != 0, for object 3531 at chunk 32640 during scan
[ 3.149543] <8>yaffs tragedy: Bad object type, -589822 != 0, for object 3864 at chunk 33792 during scan
[ 3.189275] <8>yaffs tragedy: Bad object type, -177179551 != 0, for object 3885 at chunk 34048 during scan
[ 3.197553] <8>yaffs_read_super: isCheckpointed 0
[ 3.202157] VFS: Mounted root (yaffs filesystem) on device 31:2.
[ 3.208148] Freeing init memory: 176K
[ 3.211783] Failed to execute /linuxrc. Attempting defaults...
[ 3.241269] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 3.252235] Backtrace:
[ 3.254654] [<c0038fcc>] (dump_backtrace+0x0/0x110) from [<c0534cf0>] (dump_stack+0x18/0x1c)
[ 3.263061] r6:c005be90 r5:c00083d4 r4:c077359c r3:00000002
[ 3.268680] [<c0534cd8>] (dump_stack+0x0/0x1c) from [<c0534d6c>] (panic+0x78/0xf8)
[ 3.276241] [<c0534cf4>] (panic+0x0/0xf8) from [<c00345e4>] (init_post+0xb4/0xdc)
[ 3.283684] r3:efc34000 r2:efe66600 r1:efe66700 r0:c06ba672
[ 3.289320] [<c0034530>] (init_post+0x0/0xdc) from [<c0008500>] (kernel_init+0x12c/0x170)
[ 3.297462] r4:c07c1900 r3:ef801090
[ 3.301021] [<c00083d4>] (kernel_init+0x0/0x170) from [<c005be90>] (do_exit+0x0/0x5f0)
[ 3.308900] r4:00000000 r3:00000000
[ 3.312440] Rebooting in 5 seconds..
[ 8.343115] Restarting Linux version 2.6.35.7 (root@forlinx) (gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67) ) #1 PREEMPT Fri Jun 21 16:33:18 CST 2013
[ 8.343127]
[ 8.358818] arch_reset: attempting watchdog reOK
SCLKA2M = 200MHz
Serial = CLKUART
Board: SMDKV210
RAM Configuration:
Flash: 0 kB
0 MB
In: serial
Out: serial
Err: serial
Boot with zImage
Starting kernel ...
SCLKA2M = 200MHz
Serial = CLKUART
Board: SMDKV210
RAM Configuration:
Flash: 0 kB
0 MB
In: serial
Out: serial
Err: serial
SMDKV210 #
SMDKV210 #
SMDKV210 #
SMDKV210 #
